2014 WK2 Towing questions and hitch install - JeepForum.com
post #1 of 42 Old 04-14-2014, 11:16 AM Thread Starter
MWV247
Ive got a Laredo E, Im installing the Mopar class 4 hitch this weekend. Im wondering is the 7 pin connector would control trailer equipped with brakes through the vehicle somehow or is a brake controller required? Ive got the towing group just didnt get the hitch.
I read somewhere that after the hitch is insalled that the computer needs to be flashed to activate the wiring? -Not sure if thats BS or not.
Im preparing to tow my LJ with the Wk2 if I can aquire a trailer and just want to make sure the vehicle is prepared for that.
MWV247 is offline
post #2 of 42 Old 04-14-2014, 11:35 AM
FlyingDiver
2014 WK
You need a brake controller, if your trailer brakes need one. The OEM wiring harness does not include one. Many trailers these days have surge brakes that don't need a controller. If you don't already have a trailer, look for one that doesn't need it.
'14 Grand Cherokee Overland V8 4x4, ORA II, ATP, Blue Ox baseplate, SMI AF1 brake system
FlyingDiver is offline
post #3 of 42 Old 04-14-2014, 12:27 PM
chowner
2014 WK
Hope you are not pulling any major distances.
chowner is offline
post #4 of 42 Old 04-14-2014, 12:32 PM
FlyingDiver
2014 WK
What's the issue? Total weight? OP didn't say which engine he has, but he could have a max tow weight of over 7000lb, couldn't he? My Overland is 7200 - would have been 7400 if it wasn't a 4x4.
post #5 of 42 Old 04-14-2014, 12:36 PM
chowner
2014 WK
All Laredo's have the v6. He doesn't have the tow package so he has a 5000LB tow rating. A LJ+Trailer is going to exceed that 5000LB.
It's certainly not an impossible feat, it just doesn't sound like much fun.
chowner is offline
post #6 of 42 Old 04-14-2014, 12:37 PM
FlyingDiver
2014 WK
Ah, didn't realize the Laredo's couldn't have an upgraded engine. I guess that starts with the Limited.
post #7 of 42 Old 04-14-2014, 01:35 PM Thread Starter
MWV247
I have the tow package, the hitch was optional even though it came with the tow group. And I have a 6200lb capacity the jeep should be fine
MWV247 is offline
post #8 of 42 Old 04-14-2014, 01:39 PM
Trailguide
2012 WK
You will certainly need a trailer, if you get one, with its own brakes. You got the towing package with no hitch? Seems strange. Whoever is installing the hitch should insure that the connector is set up correctly and will control your trailer brakes. You will be at max or over with pulling the 4 door. Better check.
Trailguide is offline
post #9 of 42 Old 04-14-2014, 01:45 PM Thread Starter
MWV247
I've got a 2dr unlimited. I weigh around 3400lbs
MWV247 is offline
post #10 of 42 Old 04-14-2014, 01:50 PM
chowner
2014 WK
chowner is offline
post #11 of 42 Old 04-14-2014, 02:32 PM Thread Starter
MWV247
All the tow package has is an upgraded cooling system, heavy duty alternator, and hitch. I guess because I have the off road adventure group, I got the cooling system upgrade and alternator, and skid plates, however I didn't get the hitch. So I purchased the Mopar receiver
MWV247 is offline
post #12 of 42 Old 04-14-2014, 02:37 PM
chowner
2014 WK
rear suspension is different as well
chowner is offline
post #13 of 42 Old 04-14-2014, 02:49 PM Thread Starter
MWV247
Yes it has different shocks as well, I don't have those....
MWV247 is offline
post #14 of 42 Old 04-14-2014, 04:02 PM
SirWalter
So then you don't actually have the tow package
SirWalter is offline
post #15 of 42 Old 04-14-2014, 04:05 PM Thread Starter
MWV247
Lol, sure technically after I install the hitch and connector I won't have the load leveling shocks so I won't have the "complete" package.
MWV247 is offline
