2014 Sway Bars - JeepForum.com
 1Likes
post #1 of 46 Old 11-18-2013, 12:38 PM Thread Starter
Gunny7
2014 WK
2014 Sway Bars
Will the 2014 SRT Front and Rear Stabilizer Bars fit the 2014 Overland?
Or other years?
Would it be a straight change out? Using the appropriate Bushings and brackets.
Would it need the end links also?
If so why?
Thanks.
Seems like almost every vehicle I ever had I changed Sway Bars around.
First car was a 66 GTO which must have affected my mind.
Gunny7 is offline
post #2 of 46 Old 11-18-2013, 01:46 PM
Kolak
Vendor
Kolak's Avatar
I have a set of SRT8 swaybars on order for a customer. We're going to do the swap and will report back on the handling improvement.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #3 of 46 Old 11-18-2013, 03:31 PM
MattXJ
2014 WK
The sways on my SRT seem huge. Was blown away the first time I crawled under there. I don't have anything to compare them to though.
89 XJ (Ltd): RE 3.5", full leafs, 3/4" coil spacers, RE monotubes, JKS Adj trac, tcase drop, OME steering stab., BFG AT 31x10.5xR15s on 15x8 3.75bs, Borla cat-back
14 WK2 SRT: DiabloSport catch can, Borla S-Type
MattXJ is offline
post #4 of 46 Old 11-18-2013, 04:07 PM Thread Starter
Gunny7
2014 WK
I know the handling will be better for me. street and highway.
just need to know if it is a straight swap.
like is there a difference in the way the bar is shaped.
not going to go off road .
ranch road maybe.
Thanks Kolak
Gunny7 is offline
post #5 of 46 Old 11-18-2013, 05:28 PM
BobsWK2
2014 WK
Originally Posted by MattXJ View Post
The sways on my SRT are HUGE. Was blown away the first time I crawled under there.
I read that the front SRT bar is only slightly larger.
2014 Summit 4X4 V8
BobsWK2 is offline
post #6 of 46 Old 11-18-2013, 05:41 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
The fronts don't buy you anything, but the rears provide a noticeable improvement. The links are shorter. I've read many have swapped them out.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #7 of 46 Old 11-19-2013, 01:16 AM Thread Starter
Gunny7
2014 WK
I wonder why the links would be shorter?
Maybe because the SRT sits lower than the others.
Overland has the air lift thing.
I think SRT also but does it change ride height too?
So maybe a swap out as far as the same shape?
New bushings and bushings brackets?
Keep stock end links?
What I'm getting to.
What have others found?
I've seen where the front is almost the same size.
Would then depend on how the front moved after the rear was changed to bigger.
Sometime it hunts around on some cars.
Gunny7 is offline
post #8 of 46 Old 11-19-2013, 07:59 AM
loveracing1988
I can see wanting better handling but if so why did you buy a overland? I have read on here that the air suspension rides better but handles a little worse than the coil springs. No changing the sway bars will not change ride height, I am guessing that the links are shorter because of the ride height difference, if so you may be able to keep the stock ones.
loveracing1988 is offline
post #9 of 46 Old 11-19-2013, 11:40 AM
ColdCase
ColdCase's Avatar
2011 WK
Not sure where you read that, and am not sure how you define handle better. I think the QL in sport mode (lower center of gravity) handles better in the twisties and on high speed highways than the std suspension. There can be more of a bounce feel over severe irregularities, however.
Sway bar links are shorter because shorter links work better for street transitioning and flat cornering performance. The WK2, like most vehicles, is set up for massive understeer. Putting a SRT sway bar on the rear will reduce understeer and reduce roll. Putting them also on the front will push the other way, perhaps a tad flatter on the corner but the vehicle will push much more. The best set up appears to be installing rear sway bars only.
The thicker sway bars will make off roading a bit more challenging, but those putting bigger sway pars on are not driving off road.
The SRT does not have QL, it has coil springs and active/adaptive shocks.
post #10 of 46 Old 11-19-2013, 05:52 PM Thread Starter
Gunny7
2014 WK
And the SRT cost 20K more than the Overland. Which has everything I need except --maybe---more buttoned down highway.
Maybe we'll see.
Handling is a Safety Thing I believe.
Avoidance, too much curve, things like that.
Not really going off roading with this thing. Very little, bad road maybe, kind of thing.
Just too specialized I think.
The Jeep for me is like a lot of things at my age.
Means something.
Gunny7 is offline
post #11 of 46 Old 12-28-2013, 05:38 PM Thread Starter
Gunny7
2014 WK
All right.
Our Overland came in the other day. Air Suspension.
I had already ordered the SRT --Rear bar.
An interesting piece. Had cushion brackets already installed. Pretty much non removable.
A couple of tabs for something on the ends of each.
25 mm.
Stock ride very comfortable with just a hint of "Tippy". But it catches itself with one movement. Really pretty nice ride.
The stock bar, on this v8, is 23mm. They may all be 23mm, v6 and v8, I don't know. Except SRT.
So no hurry to install.
Yesterday though I did. Might as well.
Very easy except the end link bolts, really the nuts, are just about the tightest I have ever seen. And small. Maybe 7mm or 5/16. Tight, tight.
But got the bar changed. Once the end links undone, easy out.
The little tabs retain the parking brake cables.
The ride after just perfect.
Goldilocks. Planted on the road just a little better.
No more Tippy. Moves down the road solid.
Gunny7 is offline
post #12 of 46 Old 12-31-2013, 02:59 AM
Medpilot
2014 WK
All right.
25 mm.
I'm going to have to try that on my Overland. Did you order the sway bar from your local dealer or online vendor?
Medpilot is offline
post #13 of 46 Old 12-31-2013, 11:32 AM
goonbash
Can someone elaborate on the negative effect an srt rear sway bar would have on off-roading?
And would the swap work on a 2014 diesel with ORA2 QL?
I would consider the swap for all the twisty road driving I do if it doesn't have too much effect on off-road capability.
Thanks
goonbash is offline
post #14 of 46 Old 12-31-2013, 12:00 PM
loveracing1988
Thanks
In theory a stiffer sway bar won't allow as much articulation in your suspension, but in a independent front and rear vehicle im not sure that really matters a whole lot.
post #15 of 46 Old 12-31-2013, 12:05 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
With solid axles the difference is very notable. However with IFS/IRS...
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
