Is the 2014 Summit trail rated? - JeepForum.com
post #1 of 28 Old 11-12-2013, 04:09 PM Thread Starter
somewhereinla
I can't figure out if the summit is trail rated or not. Since it's the highest trim I assume it is, but the jeep website only mention the limited and overland to be trail rated with the off-load pkg.
somewhereinla is offline
post #2 of 28 Old 11-12-2013, 04:26 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
No its not, trail rating is a marketing gimmick... no rhyme or reason one model gets trail rated and another don't. If you want trail rated, buy yourself a badge and glue it on the fender
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #3 of 28 Old 11-12-2013, 05:16 PM
hemispin
2014 WK
I think the Jeeps are "trail rated" if they include a skid-plate package of some kind.
hemispin is offline
post #4 of 28 Old 11-12-2013, 05:45 PM Thread Starter
somewhereinla
I did some research and I think it is a combination of the skid plates and the fact that you can take off the lower front facia which you can not on the summit, and which probably would brake if one did any serious off-road.
post #5 of 28 Old 11-12-2013, 06:03 PM
ColdCase
ColdCase's Avatar
2011 WK
No, we've been around this circle a few times. You can find an exception to any rule. For example. our liberty is trail rated and the only difference between it and others not trail rated is that it has a touch screen radio.... there is no skid plates... go figure.
Bottom line, its a marketing thing, don't worry about it. There isn't anything special that makes a vehicle trail rated except Jeep gluing a trail rated badge on the fender
post #6 of 28 Old 11-12-2013, 07:22 PM
JeepGC6855
2014 WK
I thought the trail rated Grand Cherokees have the air suspension and 18" wheels. The Summit comes standard with 20" wheels. My limited has 18" wheels but no air suspension, thus not trail rated.
JeepGC6855 is offline
post #7 of 28 Old 11-12-2013, 07:37 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
No. Trail Rates is market BS as previously stated
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #8 of 28 Old 11-13-2013, 06:32 AM
ColdCase
ColdCase's Avatar
2011 WK
No technical or functional reason for why one jeep gets a sticker while another on doesn't. Perhaps look at it as jeep driving a model or two through the rubicon and putting a sticker on the same production configuration.
post #9 of 28 Old 11-13-2013, 06:48 AM
jim_in_PA
2012 WK
The bottom line is that the MY14 Summit is not marketed for off-road, but is certainly just as capable of the same level of off-road that other trim levels have, although it does require you to add certain things, such as skid plates, tow hooks (requires physical body modification) and more appropriate wheels/tires for that use beyond "very light" off-road. The "Trail Rated" badge is just a piece of plastic with a sticky back...
2012 JGC Summit Hemi
2016 Subaru Outback Limited
2011 Subaru Outback Limited
jim_in_PA is online now
post #10 of 28 Old 11-13-2013, 07:10 AM
NDSU_Bison
2014 WK
I looked at the summit and decided to go with the Overland so we can get factory tow hooks.
NDSU_Bison is offline
post #11 of 28 Old 11-13-2013, 07:15 AM
kkreit01
Do they add cost on sticker for "Trail Rated" versions? ...kind of like our wonderful "On/Off Road tire" $150+ option (Michelin Latitudes with white letters = joke). Those wonderful On/Off road tires alone should make it Trail Rated.
There isn't such a thing as a Trail Rated QT1, is there? I guess that would be the only requirement.
kkreit01 is offline
post #12 of 28 Old 11-13-2013, 08:37 AM
jacko15
2014 WK
I think the real trail rating comes when you take your vehicle off road and on the trail, have a bunch of fun, don't need towed out (of course you might need towed if the driver isn't trail rated), and make it back to the road.
Mine: 2014 Jeep Grand Cherokee Overland V/6
ORA II
Hers: 2017 Jeep Compass Latitude 4x4
jacko15 is offline
post #13 of 28 Old 11-13-2013, 08:41 AM
MickinNY
2013 WK
I can answer your ? when Jeep explains what "Trail Rated" actually means. Then again, you probably wouldn't have to ask.
MickinNY is offline
post #14 of 28 Old 11-13-2013, 01:28 PM
2014RedHemiGC
2014 WK
Either one of the Off Road packages "earns" the Trail Rated badge from Jeep
2014 Deep Cherry Red GC 4X4 V8 QDII
2012 Crystal Red Cadillac CTS-V Coupe
2011 Crystal Red Chevy Corvette Z06/Z07
2014RedHemiGC is offline
post #15 of 28 Old 11-13-2013, 02:23 PM
ColdCase
ColdCase's Avatar
2011 WK
Perhaps, but you don't need a ORA to "earn" a trail rating.
