2014 Overland - Clicking sound at low speeds - JeepForum.com
post #1 of 8 Old 05-05-2013, 09:18 PM Thread Starter
ImAnthony
2014 WK
When I drive at low speeds I hear a clicking sound that gets slower/faster with the speed of the car.
It sounds similar to a playing card in the wheel of a bike.
Anyone else hear something similar?
Originally I thought it was a rock or something stuck in the tire but I dont see anything.
Not sure of the exact location sound is coming from either.. sounds like it could be the drive shaft maybe?
Does it in gear and neutral as-well.
Sound disappears or fades away at higher speeds. (30+)
ImAnthony is offline
post #2 of 8 Old 07-18-2013, 04:31 PM
gc2014
My limited 4X4 has click sound when shift gears at low speed. Went to dealer and I am still waiting for message from engineer.
gc2014 is offline
post #3 of 8 Old 07-18-2013, 04:41 PM
hemispin
2014 WK
I had a noise similar to this on my previous car. It was the cotter pin blocking the axle nut. It's an easy fix. Remove and discard the cotter pin. Put a small amount of silicone sealant on a new cotter pin and install it. That should take care of it. The sealant is easy to remove if you replace a hub or bearing, etc.
hemispin is offline
post #4 of 8 Old 07-22-2013, 02:31 PM
Austinjlee1984
Mine also has that sound is any updates to this? 2014 limited 4x4
Austinjlee1984 is offline
post #5 of 8 Old 07-24-2013, 12:30 PM
gc2014
Dealer said the click sound is from transfer case. They compared with other two 4x4 2014 vehicles and stated they are identical, it is by design.
The click sound like a solenoid is on/off. It is really annoying. I can hear it obviously when window is down.
gc2014 is offline
post #6 of 8 Old 07-24-2013, 02:08 PM
rsteps
I have a 2012 overland with this sound. I had the regional tech rep from Chrysler diagnose this as transfer case as well. It's not a problem, it is normal according to Chrysler. We also drove three others with the same thing. Annoying but normal.
rsteps is offline
post #7 of 8 Old 07-24-2013, 08:24 PM
kayoticworld
2012 WK
Same sound in my 2012. Posted about it in another thread about a week back. Mines only seems to make the noise on cold starts. Even described it the same way.....like a card in a bicycle tire. Seems to be coming from the back passenger side in my case. So we buy $40 thousand dollar vehicles and this is considered normal? Geez!
2012 Grand Cherokee Overland 5.7L V8 - Bright Silver with New Saddle Interior
kayoticworld is offline
post #8 of 8 Old 07-25-2013, 01:37 PM
rsteps
I said the same thing. Didn't expect these types of things with an expensive vehicle but love it so I live with it.
rsteps is offline
