2014 limited problems - JeepForum.com
post #1 of 5 Old 11-07-2013, 07:48 PM Thread Starter
nattack
Few problems lol hopefully their nothing
Just bought a 2014 limited last week. 200 miles
1. started to notice a odd noise coming from the rear driver side tire/fuel door area. Kind of like a popping, ticking sound that eventually disappears but comes back after a minute. "Idle"
2. While driving at low speeds coasting..10-20mph Theirs another random flapping/ticking noise seems like it's underneath the passengers seat not sure. I only hear it while driving at low speeds..
3. Tire pressure sensor keeps alerting me my pressure is low even though I filled all tires.. Even added a little more psi but sensor still reading wrong psi
nattack is offline
post #2 of 5 Old 11-08-2013, 12:01 AM
shanhuber
The popping noise could be the DEF system. The owners manual says you may here a clicking noise, but it is normal. As far as the sound under the passenger seat, that is where your battery is located. Move the seat, and open the comportment. Check to see if something is loose or moving around. The PSI is a problem that is being addressed, and hopefully will be fixed in the next U connect update. Make sure your U connect is running version 13.38.52
shanhuber is offline
post #3 of 5 Old 11-08-2013, 05:26 AM Thread Starter
nattack
Thanks for your response! The noise sounds like it's coming from underneath the vehicle around the passenger area.. But I'll investigate!
Again really appreciate the response
nattack is offline
post #4 of 5 Old 11-08-2013, 05:43 AM
TurboRush
I know you said under the vehicle but just in case... there are several relays under the passenger seat that you'll here click when certain things occur, e.g., heated seat comes on. Probably not it, but figured I'd mention.
TurboRush is offline
post #5 of 5 Old 01-10-2014, 03:44 PM
Kanab_ram
2014 WK
I've noticed something similar but mine only happens when it's below 60 degrees and only during the first 5-10 minutes of operation. There's a distinct click/ticking sound while coasting to a stop and in gear below 20 mph. The sound goes away if I bump into neutral while coasting so it appears to be drive train related.
I'm keeping a record of it and will share with the dealer the next time I take in for service.
Kanab_ram is offline
