2014 Grand Cherokee transmission failure - Page 2 - JeepForum.com
post #16 of 180 Old 12-05-2013, 06:09 PM
phil385
2014 WK
Originally Posted by 14summithemi View Post
Can't comment on that but you should know...the ZF tranny that comes in V6 equipped rigs has the 845RE version of the 8 spd tranny, V8's get the 8HP70 version. The difference being that the V8's ZF 8HP70 is made in Germany by ZF, whereas, the V6's ZF 845RE is made by Chrysler "under license" from ZF. There seem to be issues like this with the V6/Chrysler manufactured unit and nothing to speak of coming from the V8/ZF sourced units other than programming break-in. It was one of the reasons I opted for the Hemi.
This is a big time case for having an extended warranty on the V6 models if you are keeping long term, just sayin'...
Exactly! Sucks if you have a V6 and got the crap 8 speed
2014 SRT: Redline 2, Black Spiders
phil385 is offline
post #17 of 180 Old 12-05-2013, 07:27 PM
Dave2002ti
2012 WK
Germany vs US
No guarantee Germany trannie is any better built than the ones in SC.
V6 trannie isnt that bad in the 2014.
Dave2002ti is offline
post #18 of 180 Old 12-05-2013, 07:54 PM
GoPlzGo
formerly 14summithemi
GoPlzGo's Avatar
2015 WK
True enough. Not knocking the US made since they are all made by humans. I think the issue is that the V8 version is in many more vehicles and more proven in field.
White '15 JGC SRT Red Vapor...Borla ATAK Cat-back w/ ceramic coated axle-back, aFe Momentum GT Pro 5R Stage-2 Intake & Billet Tech Oil Catch Can
GoPlzGo is offline
post #19 of 180 Old 12-05-2013, 08:14 PM
jay-h
Typically failures happen either very early in the life or later down the road and the causes are different. An early failure like this tells you nothing about long term reliability.
BTW I believe Chrysler is also sourcing transmissions for ZF, so the distinction is not clear cut.
[But, then again, I'm a guy with the classic 3 speed Torqueflite, primitive but wonderfully trouble free]
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is online now
post #20 of 180 Old 12-05-2013, 08:37 PM
loveracing1988
So far on both forums I have seen 2 peopke have mechanical issues with either 8 speed. Not exactly crap if you ask me.
loveracing1988 is offline
post #21 of 180 Old 12-05-2013, 08:48 PM
Dave2002ti
2012 WK
V8 in many more vehicles? Numbers and cites to support this?
post #22 of 180 Old 12-05-2013, 08:49 PM
loveracing1988
The 8HP70 transmission is used in audi and bmw's as well as chrysler v8's.
post #23 of 180 Old 12-05-2013, 09:33 PM
tjkj2002
2002 KJ Liberty
Chrysler,Jeep,or Dodge V8's are all the same as they are the same company.
tjkj2002 is offline
post #24 of 180 Old 12-05-2013, 09:58 PM
loveracing1988
I know... I meant chrysler the total company, not just chrysler the brand.
post #25 of 180 Old 12-06-2013, 11:59 AM
GoPlzGo
GoPlzGo's Avatar
2015 WK
More subjective than pure numbers and also based on allpar.com, popular mechanics research, etc... The 8HP70 has been in BMW 7 Series, Rolls Royce Phantom, Range Rover, Audi, Chrysler for a few years and seemed to be more of a "design the car around the tranny" kind a thing where virtually nothing was mechanically changed in the tranny. It was just sourced directly from ZF and bolted in with application specific programming. It seemed to me that the 845RE was a tranny that began with the ZF 8HP45 and then Chrysler changed the design a bit, all for improvements granted, to better fit the application. This gave me less confidence in the proven reliability of it over the unchanged design of the 8HP70. Again, I was "looking" for reasons to justify why I HAD to get the Hemi
Also, I believe the 845RE is/will be built also/only? in the new ZF Kokomo US plant. I think it was a demand thing where Chrysler couldn't keep up with need.
GoPlzGo is offline
post #26 of 180 Old 12-06-2013, 02:25 PM
Qmulus
2014 WK
Well, I believe(d, incorrectly) that the 8HP70 used in the V8 is built at ZF's new transmission plant in Gray Court, SC, and the 845RE used in the V6 Grand Cherokees is made at the Chrysler transmission plant in Kokomo, IN. So, both are US made, although Chrysler buys the 8HP70 and makes the 845RE. Here is some good information: http://www.allpar.com/mopar/transmissions/ZF8.html
(The 8HP70 used in the Grand Cherokees is made in Germany, as corrected by subsequent posts from others. Had I just LOOKED on my window sticker, I would have seen mine was from Germany. Whoops, sorry for the incorrect info. I usually do a better job of checking before I make statements...)
Last edited by Qmulus; 12-25-2013 at 01:40 PM. Reason: Corrected incorrect info for future readers.
Qmulus is offline
post #27 of 180 Old 12-06-2013, 03:51 PM
loveracing1988
Originally Posted by Qmulus View Post
Well, I believe that the 8HP70 used in the V8 is built at ZF's new transmission plant in Gray Court, SC, and the 845RE used in the V6 Grand Cherokees is made at the Chrysler transmission plant in Kokomo, IN. So, both are US made, although Chrysler buys the 8HP70 and makes the 845RE. Here is some good information: http://www.allpar.com/mopar/transmissions/ZF8.html
I dont think they arr buying from there yet. The trans in my ram was made in Germany.
post #28 of 180 Old 12-07-2013, 09:12 PM
fun2drive
The transmission itself is fine. Like all other manufacturers ZF sources components from many locations. A couple of valve body failures doesn't constitute a catastrophy. ZF makes the best transmissions in the world. I have driven ZF transmissions and love them.
What I think we are seeing is the 6 sigma part of the curve.
As mentioned mechanical systems will fail once in a while even with 100% inspection.
I have a lot of confidence in Jeep...
Also not a fanboi of Jeep just practical...
fun2drive is offline
post #29 of 180 Old 12-08-2013, 06:43 AM
jay-h
There are different failure categories. Early failures are typically due an occasionally weak part of a bit of metal chip where it does not belong. They generally happen very early, and once fixed never recur.
Even a well engineered system will have some early failures, but once those issues are cleared, will not be problematic in the long run.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is online now
post #30 of 180 Old 12-08-2013, 11:15 AM
RB145
2014 WK
Has nothing to do with the ones built in SC. The V8 ones are built in Germany and the V6 versions come from a chrysler plant in Indiana.
RB145 is offline
