2014 Climate control - Page 2 - JeepForum.com
post #16 of 41 Old 01-08-2014, 06:44 AM
i20sailor
2014 WK
I found that turning off all the dash vents helped significantly since hot air is not directed right at the driver/passenger. I keep mine at 66.
i20sailor is offline
post #17 of 41 Old 01-08-2014, 04:47 PM Thread Starter
mrsc
2014 WK
I tried letting the system equalize and I used a thermometer. I set it at 60 and started the Jeep. It heated the interior until I was uncomfortable and after 5 minutes it cooled off till I was comfortable. The thermometer varied from 69 to 74 during the comfortable time. I don't know the temp before I was comfortable as my thermometer couldn't keep up. I think that Jeep's sensors can't keep up either and they don't detect the right temp. I hope a Jeep engineer (that cares) is reading this tread.
mrsc is offline
post #18 of 41 Old 01-16-2014, 06:25 PM
Gunny7
2014 WK
I think Sailor has it right.
We along with almost everybody had a real cold snap here--SE Texas.
AC would blow hot at first, too much.
I'd lower the set point and in a minute or two it would do fine.
I think the engine gets the Coolant hot faster than the Computer Guys figured.
Doesn't take long.
I had a
Ram Diesel would take 15 min to get hot.
So I figure a Re-Flash is on the way
Someday.
Gunny7 is offline
post #19 of 41 Old 01-22-2014, 03:38 PM
tinybook
2014 WK
Yes, I have the exact problem with my 2014 GC with 500 miles. Just purchased Dec. 23rd. Not sure build date. Brought it in for service for this, plus a larger problem, and the mechanic said "its probably because the outside temp is so low" He said he couldn't not find anything wrong. I will have it set at 68 and it blows out- feels like 78. Hopefully if enough of us complain they will fix the issue.
tinybook is offline
post #20 of 41 Old 01-22-2014, 04:35 PM
MJS
2014 WK
I have the same issue. I have it set to Auto and 68 degrees and it blows like crazy until it deems the temp is adequate. It definitely feels way hotter than 68.
Once it reaches what it thinks is the set temp, it settles down and then the temp feels normal.
Granted, we're seeing some really cold temps right now. -5 to 10 degrees F. So that's probably causing the issue.
MJS is offline
post #21 of 41 Old 01-29-2014, 04:34 AM
sixxshooter
I have the same problem with my 2014 grand cherokee summit . At lo it's very cold . At 61 or 62 degrees , it just switches right over to ripping hot . That is not normal . We should be able to regulate a mixture of cool air outside with warm air from the engine . Cars have offered this option in the past forever . I had a 2011 dodge charger with the same uconnect system and I did not have this problem . I think the system still thinks it's in auto even though we don't want it to be. I'll bring it up to the the dealer when I bring it in for the recall and transmission (Eco) flash update . This needs to be fixed .
sixxshooter is offline
post #22 of 41 Old 01-29-2014, 06:45 AM Thread Starter
mrsc
2014 WK
I had a Jeep tech tell me that the system in our Jeeps use infrared to determine inside temp. The surfaces need to warm up to the desired temp before the heater will reduce the heat coming in. This is why it overshoots. Even after it equalizes, the temp is 8 or 9 off. All of this can be fixed but only Chrysler can do it through programming. The dealer techs hands are tied. Everyone needs to write letters to Chrysler. I will be sending one every week until the problem is fixed.
mrsc is offline
post #23 of 41 Old 01-29-2014, 07:08 AM
Rdrakea
2011 WK
Ditto for my '14 GC Summit. LO is cold. 60, you can't breathe it's so hot for 5-10 mins before it stabilizes.
2014 Jeep Grand Cherokee Summit (2wd)
-Brilliant Black Crystal Pearl / Black
Rdrakea is offline
post #24 of 41 Old 01-29-2014, 08:22 AM
sixxshooter
This is rediculous
post #25 of 41 Old 01-29-2014, 08:23 AM
sixxshooter
[QUOTE="sixxshooter"]This is ridiculous !!!
post #26 of 41 Old 01-29-2014, 08:24 AM
sixxshooter
Ridiculous
post #27 of 41 Old 01-31-2014, 02:35 PM
Gunny7
2014 WK
In the scream of things
Small Potatoes.
It'll get fixed.
Gunny7 is offline
post #28 of 41 Old 01-31-2014, 05:32 PM
loveracing1988
Small Potatoes.
It'll get fixed.
What?...
loveracing1988 is offline
post #29 of 41 Old 03-28-2014, 01:26 PM
Kanab_ram
2014 WK
Ditto. Stupid thing seems to have a mind of it's own. Air temp and setting don't reconcile. Glad to see I'm not alone.
Kanab_ram is offline
post #30 of 41 Old 03-28-2014, 02:25 PM
chowner
2014 WK
I'd say I'm having the complete opposite experience. It seems to work great. Although I've only had it a week and I've never had a vehicle with auto climate control before.
chowner is offline
