2014 Climate control - JeepForum.com
post #1 of 41 Old 01-06-2014, 06:29 AM Thread Starter
mrsc
2014 WK
I've had my 2014 Grand for 3 weeks and I'm not too happy with my climate control. I have it set on 60 degrees on the automatic setting. I have to turn the fan down manually or open the windows or it will sweat me out. Anyone else have this problem. Just thought I'd ask here before I take it into the dealership.
mrsc is offline
post #2 of 41 Old 01-06-2014, 06:38 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Nope, that isn't normal.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #3 of 41 Old 01-06-2014, 07:08 AM
PMHSLight
I'm having the same problem. THe climate control seems to be all over the place. At 60 dgrees it feels like full heat. I have to go to LO setting and then back up to 63 degrees before it cools off. But then it seems to always return to full heat. It is very hard to regulate. I have a 2014 limited, made in october. If you take it to the dealer, pleaes let me know what happens, as it is certainly happening to me and very frustrating that I cant regulate the heat.
PMHSLight is offline
post #4 of 41 Old 01-06-2014, 07:58 AM
ComfortablyNumb
2014 WK
I'm having exactly the same issue. It could very well be due to my lack of familiarity with this system, and I will admit that I've not studied it much. It seems to automatically blow very hot when the outside temperatures are low. I have to go to the LO setting to get relief and then slowly back up again. My 2014 Limited was built in September.
ComfortablyNumb is offline
post #5 of 41 Old 01-06-2014, 08:54 AM
Jeff_WK2
I have a June-built 2014 Overland and the automatic climate control seems to work fine. I typically keep it between 60 and 64 depending how cold it is outside. I can't recall ever manually changing anything. I know for sure that I have never manually changed the fan speed. I just set the temperature and hit the auto button and it is good to go.
Now if you want to gripe with me about how crappy the heated seats are...
Jeff_WK2 is offline
post #6 of 41 Old 01-06-2014, 10:13 AM
ydubbs4
2014 WK
I've got the same issue - blazing hot under manual control unless it's on 'Low'. Auto seems to work alright for now. I need to review the Owner's Manual DVD to see if there are any kernels of knowledge on this. I've also got a heated seat issue on the driver side - the bottom gets hot but the back doesn't work. Not bad for the first 250 miles (1 week old). Keep us posted as mine's likely to head to the dealer in the next week or so.
Will
ydubbs4 is offline
post #7 of 41 Old 01-06-2014, 10:16 AM
Medpilot
2014 WK
I have a similar issue when the temp is set manually to 70 it will feel like it's on full heat. Without changing anything, it will continue to blow hot air for around 3-5 minutes. After that it starts to behave normally. How much time do you let pass before changing the setting?
Medpilot is offline
post #8 of 41 Old 01-06-2014, 10:20 AM
onebluemcm
2015 WK
Mine's September built, no problems like that.
'15 Overland Diamond Black, 3.0L Turbodiesel, Quadra-drive II
onebluemcm is offline
post #9 of 41 Old 01-06-2014, 05:33 PM
Butterjeep
2015 WK
For short trips, I use the manual mode otherwise the climate control goes nuts trying to get to my preset temps ASAP. On longer trips, I use auto mode since the system has plenty of time to adjust the temperature and doesn't have to work so extreme.
2014 Mustang GT Track Pack
2015 WK2 Limited 4x4
Butterjeep is offline
post #10 of 41 Old 01-06-2014, 06:36 PM
sally14
I too have the "all over the place" climate issue. 70* feels like 90* for five minutes. What are we doing wrong ? It doesn't matter if I have it on auto or manual. This blows! Lol
sally14 is offline
post #11 of 41 Old 01-07-2014, 01:39 AM
TuckerDarling
2014 WK
I haven't paid very close attention, but I can say that when it is cold outside 70F feels very warm. I have to turn the temp much lower to feel cold. I think it may be that, even though I feel hot (sunny, etc), the inside temp of the car is actually lower than the temp I have it set to.
TuckerDarling is offline
post #12 of 41 Old 01-07-2014, 06:24 AM
i20sailor
2014 WK
I have the impression that the Auto calibration tries to get to set temp very quickly and the response time of the temperature sensors drives an overshoot. Once equilibrium is reached, it seems to control adequately. I had the opposite complaint with my 2011 Edge where the A/C in summer would take for ever to cool down the cabin. There I had to manually switch to Max A/C. I have not had a chance to try the A/C control on the Jeep.
i20sailor is offline
post #13 of 41 Old 01-07-2014, 07:54 AM
gabbagabba
2014 WK
Never noticed an issue summer or winter
gabbagabba is offline
post #14 of 41 Old 01-07-2014, 11:12 AM
JeepGC6855
2014 WK
I keep mine on 72 year round, but when it is cold, it will blow hot air, just the same as if it was set on 90, but once the interior reaches 72, then it backs off and keeps it at 72 degrees. Then in the summer when the interior is hot, that same 72 blows cold air and tries to get the interior to 72 as quick as possible. The air isn't any colder if it is set for 62 or 72, it will just maintain that temperature once it gets to it.
JeepGC6855 is offline
post #15 of 41 Old 01-08-2014, 12:14 AM
loveracing1988
I didn't read anything but the 1st post but that is a problem that is becoming more apparent on the other forum. Hopefully everyone will complain and they will come out with a software update to fix it.
loveracing1988 is offline
