2013 GC Overland rust already? - JeepForum.com
post #1 of 28 Old 04-21-2013, 12:35 PM Thread Starter
ps0831
2013 WK
Hello all. I have had my 2013 GC Overland for about 4 months and I am finding rust around the center caps of the wheels already. Is this something that anyone has seen this soon? I can't believe that this is normal. Thanks in advance.
ps0831 is offline
post #2 of 28 Old 04-21-2013, 03:04 PM
w1pf
Who, me?
w1pf's Avatar
2007 WK
rust around the centercaps? on aluminum wheels?
pix?
...tom
2014 WK2 Overland 5.9L
2007 WK Limited 5.7L
And some past Durangos
Red WK #19, Hemi #68.. I think..
Durango Owners Club DOTY 2011
"Must have been that yesterday was the day that I was born"
w1pf is offline
post #3 of 28 Old 04-21-2013, 04:34 PM
Jackal01
Jackal01's Avatar
2011 JK Wrangler
This thread is useless without pictures.
2011 Billet JKUS
Jackal01 is offline
post #4 of 28 Old 04-22-2013, 06:40 AM
GaryGC
You are getting rust coming from the drivetrain components behind the wheel. This is pretty common on most vehicles. The way to eliminate it is to remove your wheel and put a thin coat of permatex anti sieze (silver/gray in color) on those rusted components. Also, a very thin coating can be applied where your aluminum wheel touches the brake rotor. Doing so will prevent the wheel from bonding to the steel rotor, also common on modern vehicles. Use the anti sieze sparingly, a little goes a long way and do not get any on the actual braking surface of the disk.
GaryGC is offline
post #5 of 28 Old 04-22-2013, 08:51 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Is it on the surface? Can it be cleaned off?
JeepCares is online now
post #6 of 28 Old 04-22-2013, 04:29 PM
w1pf
Who, me?
w1pf's Avatar
2007 WK
no pix => isn't happening.
w1pf is offline
post #7 of 28 Old 04-24-2013, 05:14 AM
HEMIjeep360
2012 WK
It does happen. I do all my own maintenance and when rotating my tires, there was a lot of rusting going on behind the wheel where the nut attached to the end of the axle. I wire brushed it and put rust inhibitor on it.
Before this, after a rain, there would be rust draining out from behind the center cap and all over my black 20 inch rims. You would think Jeep would do better with this area. Brand new, rust draining all over the rims.......
HEMIjeep360 is offline
post #8 of 28 Old 04-24-2013, 05:33 AM
GU3R086
2012 WK
Same problem on my altitude. There is a snap ring that holds the center cap down and when it gets wet it rusts and leaks all over my wheels. Easy to clean, and I plan to spray paint it to stop the rusting on my next tire rotation.
GU3R086 is offline
post #9 of 28 Old 04-25-2013, 11:46 AM
Ben
I have this on my 20" Overland wheels.
Next tire rotation, I plan to spray paint the end of the unit bearing, and clean the inside under where the logo center cap is.
Ben is offline
post #10 of 28 Old 04-25-2013, 12:10 PM
WK2FAN
2012 WK
+1 Permatex anti-seize all four corners. I did this over a year ago when it was brand new and there is still no rust.
WK2FAN is offline
post #11 of 28 Old 04-25-2013, 07:18 PM
DigitalPhoenix
ALL Chrysler cars do this, not just Jeeps.
5.9 ZJ bone stock.
If it ain't broke, fix it til it is.
DigitalPhoenix is offline
post #12 of 28 Old 04-25-2013, 08:09 PM
Webb
Webb's Avatar
2012 WK
Like this ? This was from my JGC 2000.
2012 Limited 4X4 Hemi,Maximum Steel Metallic ,730n & 20's.Average 9K's a year.
Webb is offline
post #13 of 28 Old 04-27-2013, 04:39 PM Thread Starter
ps0831
2013 WK
Apologies for not including pics on my original post. Thanks to everyone that responded so far. What a shame, must be a Chrysler thing, my 2001 Ford Mustang has painted wheels with center caps and they still look brand new.
ps0831 is offline
post #14 of 28 Old 04-27-2013, 04:53 PM
LibGrandCher
2012 WK
That looks terrible !.
I just went and checked mine.
I have the same rims but no rust.
I'm also on my 2nd winter.
That rim looks kinda refurb.
You may have to get that one repainted.
Sorry man.
LibGrandCher is offline
post #15 of 28 Old 04-30-2013, 05:52 AM
MickinNY
2013 WK
I agree. That does look bad only 4 months into a new vehicle. That can't be normal. Are all 4 wheels that bad? I'd definitely discuss it with the dealer.
MickinNY is offline
