2013 GC a/c temp 48 degrees max - JeepForum.com
post #1 of 10 Old 08-07-2013, 02:55 PM Thread Starter
ajy926
Just curious to see what others are temping at their center vents. Mine maxes out at 48 degrees and seems it should be somewhere between 38-42 as the max temp.
Ive had GM cars my whole life and never had this problem of weak ac's.
Is this normal for these Jeeps?
Thanks in advance for your responses.
ajy926 is offline
post #2 of 10 Old 08-07-2013, 03:10 PM
Dave2002ti
2012 WK
Do you have the AC
on manual and not auto? Mine will cool my 2012 down at idle when the temp is in low 100's and dew points approaching 80.
Dave2002ti is offline
post #3 of 10 Old 08-07-2013, 03:30 PM Thread Starter
ajy926
Its on manual setting. I dont have the fancy digital one..
ajy926 is offline
post #4 of 10 Old 08-07-2013, 04:34 PM
Dave2002ti
2012 WK
Go see the dealer
While its still under warranty
post #5 of 10 Old 08-07-2013, 09:41 PM
tjkj2002
2002 KJ Liberty
All automotive AC systems are effected by outside temps and humidity.If it's 90 degrees outside a properly functioning AC system will drop the air temps between 25-35 degrees depending on the humidity level.Other things like speed your driving among other things can also effect AC performance.Your AC will work better while driving 65mph then at 15mph or stopped in traffic.Leaving the recirc mode on will also lower performance after some time.If you have a cabin air filter and it's clogged that also will effect the AC performance.
So depending on all conditions 48 degrees coming out of the center vents maybe where it should be given the conditions.
tjkj2002 is offline
post #6 of 10 Old 08-08-2013, 03:08 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
from the 2013 WK factory service manual:
Ambient Air Temperature (Apparent) - Maximum Allowable Air Temperature at Center Panel Outlet
70F - 48F
80F - 48F
90F - 54F
100F - 59F
110F - 65F
JeepCares is online now
post #7 of 10 Old 08-11-2013, 10:16 PM
Saltriverfolk
2013 WK
Between 54 and 57 degrees with outside temp of 92.
Saltriverfolk is offline
post #8 of 10 Old 08-19-2013, 10:46 PM
txguy67
The dealer I took it to claims 35 out of the center vent...No Way.....
txguy67 is offline
post #9 of 10 Old 08-20-2013, 02:28 PM
DangFoo
I have three Jeeps: 2008 JKU, 2013 WK2, and 2013 JK ... Ice cold A/C in all three. Have no idea what temp they run at and don't really care as long as they're cold. Even running in the high 50s is cold enough and it hits triple digit weather here in CA.
DangFoo is offline
post #10 of 10 Old 08-21-2013, 11:00 AM
overland_HO
2013 WK
No problems here and I have black leather interior and my Trailhawk keeps nice and cool and day long in 100+. Sounds like your AC is working as designed according to the spec's posted. You are only talking 6-8 degree's difference here..But I have noticed the GM's AC is generally a cooler running AC...
13 TrailHawk|HEMI|RubiRimsw/32"BFG MT|Intake
14 Silverado 3500|DMax|Allision|Z71|Tuned
overland_HO is offline
