2013 5.7 Fuel Pump - JeepForum.com
post #1 of 17 Old 03-28-2014, 10:42 AM Thread Starter
NickPsy
2013 WK
2013 5.7 Fuel Pump
My 13' Overland started making a horrible grinding/crunchy noise from the engine which turned out to be a faulty fuel pump. 24,000 miles and a bad fuel pump?! Glad I bought the extended warranty....
NickPsy is offline
post #2 of 17 Old 03-28-2014, 10:52 AM
LibGrandCher
2012 WK
Good for you on making the decision to get that warranty .
Do you have any idea what that would have cost you out of pocket (parts and labor)?
Thanks
LibGrandCher is offline
post #3 of 17 Old 03-28-2014, 10:55 AM
FlyingDiver
2014 WK
A '13 with 24k miles should still be under the original warranty, right?
'14 Grand Cherokee Overland V8 4x4, ORA II, ATP, Blue Ox baseplate, SMI AF1 brake system
FlyingDiver is offline
post #4 of 17 Old 03-28-2014, 11:05 AM
chowner
2014 WK
Exactly my thought.
chowner is offline
post #5 of 17 Old 03-28-2014, 11:18 AM
hemispin
2014 WK
Yea, you were cutting it close with the factory 100k mile powertrain warranty...
hemispin is offline
post #6 of 17 Old 03-28-2014, 11:52 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Driving with less that tank fuel is hard on the fuel pump, not as much cooling. Otherwise failures happen.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #7 of 17 Old 03-28-2014, 12:18 PM Thread Starter
NickPsy
2013 WK
Still under factory warranty for sure. Just surprised that a fuel pump would go this quick. That was the reference to the extended warranty as I have a bit more peace of mind with some anticipation that things may go bad on the car.
NickPsy is offline
post #8 of 17 Old 03-28-2014, 05:23 PM
chowner
2014 WK
I'd question the validity of this
chowner is offline
post #9 of 17 Old 03-28-2014, 06:50 PM
ColdCase
ColdCase's Avatar
2011 WK
You will see text like this posted on a number of enthusiast sites when discussing why fuel pumps fail, doesn't make it true however:
"Fuel Starvation
Fuel pumps are designed to pump fuel, not air. If your vehicle doesn't have enough gasoline, your fuel pump will be forced to pump air. If the vehicle pumps air regularly, the fuel pump will eventually fail. Your vehicle's fuel pump relies on the fuel that passes through it to provide it with lubrication and work as a coolant to keep the pump from overheating. If the pump is being starved for fuel, it stands a higher chance of overheating and burning up.
Drivers who regularly run their vehicle very low on fuel, or who periodically keep the fuel tank less than a quarter of the way full, will probably experience fuel pump failure earlier than drivers who keep a partially to fully filled tank."
"• Driving with low fuel level: Its durability depends on the lubrication and the cooling provided by the fuel. Running your vehicle on a low gas tank frequently, may heat up the fuel tank much quicker, ultimately overheating the fuel pump. As a result, due to the lack of lubrication, it becomes dry and gets damaged.
Article Source: http://EzineArticles.com/7193050"
"The largest cause of fuel pump failure is caused by the tank being run low, espesially in the winter. the pump has been installed inside the gas tank, in part, to try to keep the pump cool. when a car has been driven on a low tank, the pump will tend to get a little warm, then pumping cold gas on top of it, can sort of "shock" the pump."
"Most pumps are capable of going 100,000 miles or more, but depend on lubrication and cooling provided by the fuel itself. Frequent driving with a low fuel level may occasionally starve the pump for lubrication and cooling, which can lead to accelerated wear or even pump damage."
ColdCase is offline
post #10 of 17 Old 03-29-2014, 09:57 AM
chowner
2014 WK
Logic doesn't work with that quote.
I understand the theory behind this, but it doesn't really compute to me.
90% of time I never fill up with more than 1/8th of a tank left. I've drove multiple vehicles well over 100K and never had a fuel pump failure. Maybe I'm just lucky
chowner is offline
post #11 of 17 Old 03-29-2014, 11:26 AM
Racer83L
2014 WK
I have heard the same thing for many years from many different people.... I personally dont fill up until my light comes on, and I also have never had a pump fail.
I would still think its better to keep more fuel in the tank than what I do, but I try to go to the gas station as less often as possible which means I let it run very low.
Current- 14 White Altitude, 5.2 ZJ, past - 08 JKU lifted gears etc, 91 YJ lifted etc
Racer83L is offline
post #12 of 17 Old 03-29-2014, 01:43 PM
ColdCase
ColdCase's Avatar
2011 WK
Good thing you were not exceeding 200K miles, you would be in big trouble. At 100K miles, the Jeep is barely broken in .
I've only had one in-tank fuel pump fail, but that was a '85 Cheby at 40K miles (just outside the warranty). The dealer said it was probably caused by me running the tank down to low fuel often.
ColdCase is offline
post #13 of 17 Old 03-29-2014, 03:30 PM
hemispin
2014 WK
Not too sure about that. A quarter tank on the JGC with 25 gallon tank works out to be over 6 gallons. The needle is calibrated on the conservative side to effective have a "reserve", so figure another 2-3 gallons. If 6 gallons of fuel won't cool the fuel pump, then the the pump should be getting hot enough to ignite the fuel in the tank.
Agreed.
Same here. I've only replaced one fuel pump in my ~ 25 years of driving and vehicle ownership. It was when I put a fresh 302 engine in my 64 1/2 Mustang.
Pretty much the same for me.
hemispin is offline
post #14 of 17 Old 03-29-2014, 04:50 PM
ColdCase
ColdCase's Avatar
2011 WK
OK, OK, if you want to get precise, its 3/16 of a tank... and, if you want to get that picky, the larger the tank the more the fuel can slosh up the sides and uncover the fuel pickup... making the pump suck air... Not saying that I can confirm or deny that its more wear and tear on the pump, but thats what some of the folks with fuel system expertise and experience tell me. It could just be a hold over from the early days of in-tank fuel pumps, and the current pumps are less likely to be affected.... I dunno, but one can sure find plenty of current references to it. It appears to be common knowledge with techs, which doesn't make it right.
They are typically discussing, for those that have had fuel pump failures, what the failure modes and effects detectives determined was the cause.... not so much how likely there would be a failure.
ColdCase is offline
post #15 of 17 Old 03-29-2014, 06:35 PM
hemispin
2014 WK
I think this would be an accurate synopsis. I can't even remember any of my friends ever needing to replace a fuel pump. And I thought a lot about it!
hemispin is offline
