2012 Laredo Rads are WEAK !! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > 2012 Laredo Rads are WEAK !!
FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectFS: Wranger BRIGHT License Plate LED! Just $3! Great valueThanksgiving/Black Friday/Cyber Monday Deals at JeepinOutf
Unread 11-24-2014, 02:52 PM   #1
zr2s10
2012 WK
My wife complained that the heat in her GC wasn't working right. I checked the fluid, and it was pretty low. Topped off with distilled water, heated it up, and saw the rad was steaming. I was hoping it would be covered under the powertrain warranty, but no luck. Jeep wanted $750 to change it out.
So I got one with a lifetime warranty from my buddy at Advance commercial, and swapped it out myself. The pics show just how much you have to pull apart. There is a thin slit in the bottom row from a stone hit (look to the left of the fly, lol). I'm very surprised that this is so weak. I think one of the issues is that the very bottom edge of the rad is exposed from behind the A/C condensor. If you look at the one pic, that thin silver strip is the bottom 2 rows of the radiator. I'm gonna pick up some SS mesh to fit into this plastic grille space to provide some real protection. For this to happen within two years, I don't trust it to stay safe again for very long. I doubt the warranty will cover rock hits, and I don't want to waste another 5 hours in the garage on something so easily preventable. Of course, to be fair, some of that time was figuring out how to do it, so next time would be faster. And I also pulled my washer reservoir and cleaned my sensor. (see washer fluid sensor thread for that pic)
zr2s10 is offline   Reply With Quote Quick reply to this message
Unread 11-25-2014, 09:39 AM   #2
kkreit01
That doesn't look fun. Great job on DIY.
kkreit01 is offline   Reply With Quote Quick reply to this message
Unread 11-25-2014, 10:10 AM   #3
zr2s10
2012 WK
Thanks. One other thing I'd like to note, is that the replacement radiator had a core that was twice as thick. It didn't interfere with the installation, and it seems to be working fine. I just thought it was odd. My guess is the aftermarket company has one part number for both the V6 and V8, where Chrysler wanted to save money by making a thinner one for the V6.
Unread 11-25-2014, 12:36 PM   #4
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Yes there are two radiators, the standard V6 and the V8 or V6 heavy duty cooling (in some trailer tow packages).
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote Quick reply to this message
Unread 11-25-2014, 01:08 PM   #5
zr2s10
2012 WK
Ah, ok. Well I added a factory hitch setup, so it's probably good to have the extra capacity. I usually tow heavier stuff with my truck over the Jeep, but it's good to have a backup.
