2012 Jeep Grand Cherokee Laredo with AC problem - JeepForum.com
post #1 of 6 Old 06-19-2017, 06:43 AM Thread Starter
sirmacer
2012 XJ Cherokee
I am having issues with my AC and from what I have found out it seems the evaporator is freezing up but how do I fix it so it runs normal? It will be running fine for a random amount of time then the fan will still keep blowing normal but minimal air will be coming out of the vents. I shut the jeep off for a bit and then it is fine again. There seems to be and excessive amount of water underneath after it sits. It's really cold air when it's working and sometime it takes just a few minutes and other times it takes an hour or more before it acts up. Please help.
sirmacer is offline
post #2 of 6 Old 06-19-2017, 01:55 PM
Blackshirts
2012 WK
Need to recharge the unit. Low refrigerant will cause it to freeze up.
Blackshirts is offline
post #3 of 6 Old 06-19-2017, 07:45 PM
newtoncd8
2012 WK
Make sure the TSB has been applied. On longer drives, mine would freeze up and the TSB fixed it.
http://www.wk2jeeps.com/tsb/tsb_wk2_2400312.pdf
newtoncd8 is offline
post #4 of 6 Old 06-20-2017, 05:13 AM
GregK340
2017 WK
Could be low on charge, another common cause is restricted air flow, if you have a cabin air filter, check it. or just change it, sometimes the evaporator itself is just dirty.
GregK340 is offline
post #5 of 6 Old 06-20-2017, 05:29 AM
jeepjeepster
While it may very well be that TSB, Ive had bad low pressure cut off switches cause this.
1994 ZJ-I6 w/216,000 mi
1998 ZJ 5.9 w/65,155 mi Slate Black
2004 KJ w/90,300 mi
jeepjeepster is offline
post #6 of 6 Old 06-20-2017, 06:24 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Hi sirmacer,
Sorry to hear about this! If you decide to visit your local dealership for further diagnosis I'd be happy to offer assistance if needed. Just PM our page with your VIN and let me know.
Andrea
Jeep Social Care Specialist
JeepCares is online now
