2012 GC Air suspension failure - JeepForum.com
post #1 of 10 Old 01-12-2014, 07:59 PM Thread Starter
chubbyhubby
2012 WK
Greetings All,
9000 miles on a 2012 GC Overland. The first time we had bitter cold (-10F), I had a warning along the lines of, "System malfunction....Must cool off before using....Immediate service required" when it tried to change height. Has anyone else had this problem? Also, since I don't have a lot of confidence in the air adjust system, is it possible to substitute with conventional shocks if worst comes to worst???
Also, in the cold, my tire pressures dropped by 10psi all around. I thought nitrogen wasn't supposed to be so temperature sensitive.
Any thoughts? Thanks, CH
chubbyhubby is offline
post #2 of 10 Old 01-12-2014, 08:16 PM
13ovsummit
2013 WK
^^^^ - You may find the following post helpful:
/http://www.jeepforum.com/forum/f309/...-snow-1954090/
13ovsummit is offline
post #3 of 10 Old 01-13-2014, 06:37 AM
TurboRush
There have been a handful that have seen this message when it got extremely cold. Once things "warmed" up they seemed to return to normal.
TurboRush is offline
post #4 of 10 Old 01-13-2014, 07:19 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Just an FYI-
SERVICE BULLETIN NUMBER: 08-034-12
GROUP: Electrical
DATE: May 10, 2012
SUBJECT:
Flash: Service Air Suspension Message And/Or U0415-00 And/Or C159E-15 Set
OVERVIEW:
This bulletin involves reprogramming the Air Suspension Control Module (ASCM) with new software.
MODELS:
2011 - 2012 (WK) Grand Cherokee
NOTE: This bulletin applies to vehicles equipped with Quadra-Lift (TM) Air
Suspension (sales code SER) built before May 1, 2012 (MDH 0501XX).
SYMPTOM/CONDITION:
The customer may experience a “Service Air Suspension” message. Upon further
investigation the Technician may find that U0415-00 Impliable Data Received From
Anti-lock Brake System (ABS) or C159E-15 Air Pump Temperature Sensor has been set active or stored.
Also if the vehicle is driven in extremely cold temperatures (-30C/-22F) the ASCM should be updated with the new software. The new software will allow the air compressor to continue to operate until -40C/-40F.
Updating the software will correct the conditions listed above.
JeepCares is online now
post #5 of 10 Old 01-13-2014, 03:48 PM
Alaska-HWY JK
Originally Posted by JeepCares View Post
Just an FYI-
GROUP: Electrical
DATE: May 10, 2012
SUBJECT:
OVERVIEW:
MODELS:
SYMPTOM/CONDITION:
-10 = Bitter Cold? We've had -40 and colder and it works alright. I think I've seen that message once in the 2 years my Wife's had her Overland.
Alaska-HWY JK is offline
post #6 of 10 Old 02-28-2014, 05:52 PM
sbarbjer
I had the warning "Service Air Suspension System" show up on my display on my 2014 GC Overland several weeks ago. Brought it in the dealer to repair it for the day (rental car). They called me up and told me to pick up the car, that they had to order a Air Suspension module. It's been 1.5 weeks since then. I called the dealer yesterday to get a ETA on the part. They said maybe by March 7th but no promises. I live in Orange County, CA so the weather isn't the problem. Hope it's the module.
sbarbjer is offline
post #7 of 10 Old 03-01-2014, 06:44 AM
briggsJeep
The air suspension on my 2011 failed two weeks ago during a snow storm. Mine was worst case scenario. By the time I got it to the dealership it was riding on the bump stops, looking like a lowrider. Apparently the module that controls the air suspension system failed, causing the compressor to run non-stop. The only way I could get the compressor to stop was to pull the fuse. They replaced the module and compressor, under warranty fortunately. It was a $5200 repair.
Interestingly, the service guy indicated that the problem was related to the cold weather, although it may have been 25-30 degrees when it failed. We don't see negative temps in NC. He claimed that the new system would not have this problem.
My warranty expires in a few months. I'm really concerned about the air system failing again.
briggsJeep is offline
post #8 of 10 Old 03-01-2014, 07:06 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
There are a lot of them on the road without issues, but you could think about chrysler's extended warranties.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #9 of 10 Old 03-01-2014, 07:32 AM
briggsJeep
Considering a warranty.
post #10 of 10 Old 03-01-2014, 06:36 PM
rsteps
Get the lifetime warranty. Piece of mind. I've had lots of issues with my 12 overland. Probably would have gotten out of it if I didn't have the lifetime warranty.
rsteps is offline
