2012 Antenna Base removal - JeepForum.com
post #1 of 7 Old 08-09-2015, 11:06 PM Thread Starter
Blackshirts
2012 WK
I broke the antenna off tonight. Unfortunately it actually broke off below the antenna screw so I need to replace the base unit.
I see a small hole where it looks like I should stick a driver in to pry it up.
Is this correct?
I saw a few pics on the internet of the underside of the base and it looks like the unit attaches through a small hole where some sort of expansion nub pushes through. Looks like 3 wires as well came with the unit.
Any help would be appreciated!!
Blackshirts is offline
post #2 of 7 Old 08-10-2015, 07:04 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
You have to get at is from the inside, pull the headliner down a bit, loosen one or two screws and the antenna cables. A procedure was posted her awhile ago, but I'm not in a good place for searching at the moment. You can't just pry.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #3 of 7 Old 09-14-2015, 05:38 PM Thread Starter
Blackshirts
2012 WK
Can anyone give me the part number for the antenna base unit for the 2012 JGC w/ satellite and GPS.
Thanks!!
post #4 of 7 Old 09-14-2015, 08:15 PM Thread Starter
Blackshirts
2012 WK
found it, no need reply.
post #5 of 7 Old 09-14-2015, 08:23 PM
ColdCase
ColdCase's Avatar
2011 WK
Its not clear which one you need. I'd go to forum sponsor moparonlineparts and navigate through the repair parts for a 2012 grand cherokee to the electrical/radio/antenna section. Its probably 5064771AC but I dunno. If your Jeep came from the factory with satelite and GPS, you can give them your VIN (or any dealer's part desk) and they can tell you what part number to order.
Otherwise, someone may look it up post here in a day or two.
The other option may be 68186122AA but that looks like satellite only.
post #6 of 7 Old 09-15-2015, 09:14 PM Thread Starter
Blackshirts
2012 WK
Mopar #5064861AD is the one i bought.
factory satellite and navigation.
going to see if i can replace it myself this weekend. looks like the trim at the top of the hatch comes off and I can get in-between the roof and the inside of the cabin. Looks like 3 connection points. Guessing its radio/satellite/GPS.
post #7 of 7 Old 09-15-2015, 10:50 PM
ColdCase
ColdCase's Avatar
2011 WK
Someone posted the procedure maybe a year or so ago. I don't recall if there are spring clips involved or just a screw or two.
Not so obvious but check here http://www.jeepforum.com/forum/f309/...=antenna+clips
