2011 WK2 Mygig RHR upgrade / install - JeepForum.com
post #1 of 10 Old 03-03-2012, 08:05 PM Thread Starter
Str8ngelybrown
Hey there,
New to the forum and Jeep ownership for that matter and am struggling with a recent Mygig RHR 730N install. I ordered the RHR, uconnect module (including mic), rear camera and ipod connector online and had my local Jeep dealer install it. After the 10 hour install, they were unable to get into the radio using the dealer provided security code and told me to come back at a later date. On the way home, I was able to get in using the 1,2,3,4 code but noticed that the ipod connector is not working and the voice recognition isn't working at all. I am not able to get another appointment until next week and quite honestly dont want to wait that long to have a fully functioning system. I really need the VR and handsfree features to work! I know that the RHR has uconnect built in but see that they installed the module anyway. Is this necessary?
Please help with any suggestions. The dealer seems lost and so am I...
Str8ngelybrown is offline
post #2 of 10 Old 03-04-2012, 01:04 AM
pschofie
2012 WK
No you do not need the module, you need to get a jumper cable from jeep to connect from the mic in the mirror to the RHR and you need an USB extension cable to connect to the USB connector I. The console to the back of the RHR.
The unconnect module should NOT be connected.
I fill find you the part numbers for the two cables and post them up.
Your dealer must not have a clue?
This is a really simple installation should take less than one hour MAX!
Regards,
Paul
pschofie is offline
post #3 of 10 Old 03-04-2012, 01:21 AM
pschofie
2012 WK
Hi,
The problem is that the dealer should have removed the Uconnect module and connected the harness that goes to the mirror microphone and the USB connector with special cables that jeep supplies.
The Uconnect module is NOT required with the RHR radio
Clearly the dealer has no clue what they are doing, the install should take 1 hour max!
The parts you need are
Microphone Harness 82211666
USB Jumper Cable 68068278AA
Hope this helps
Paul
pschofie is offline
post #4 of 10 Old 03-04-2012, 01:32 PM Thread Starter
Str8ngelybrown
Thanks for the reply Paul! This has been driving me crazy. I should have mentioned that I do not have the microphone mirror, just the standard mirror so i will need a mic. So, Just so I have it correctly and so I can let the dealer know...the rhr has the uconnect included so it simply gets connected to the original wiring harness and then Id just need a mic that goes directly into the rhr?
post #5 of 10 Old 03-04-2012, 03:04 PM Thread Starter
Str8ngelybrown
Ok, So I think I figured it out. At least I hope so...
From what I have gathered (Thorough research), I need to have the uconnect HFM removed. Then I need to have the factory wiring connected to the Mygig rhr. Then I need to add Mopar #82211743AB (Mic kit) and Mopar #82211853 (iPod kit) for iPod integration? Please let me know if this sounds correct.
post #6 of 10 Old 03-04-2012, 03:49 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
I believe the mic kit and iPod kit replaces the HFM and perhaps some of the existing factory cables. The remaining factory wiring would be connected through the mic/iPod kit to the radio.
ColdCase is offline
post #7 of 10 Old 03-04-2012, 04:41 PM Thread Starter
Str8ngelybrown
Thanks Coldcase! Ill give that a try and let you guys know how it goes.
post #8 of 10 Old 03-04-2012, 08:28 PM
pschofie
2012 WK
There souls be a mike there that connects to the existing unconnect module. That mic via an adaptor cable needs to go to the RHR it should be the same or very similar to the mirror adaptor cable.
pschofie is offline
post #9 of 10 Old 03-06-2012, 07:17 AM Thread Starter
Str8ngelybrown
pschofie, Im pretty sure the existing module is conflicting with the rhr and needs to be completely removed if theres no need for it anymore. My appointment is tomorrow, hopefully they can figure it out.
post #10 of 10 Old 03-06-2012, 12:34 PM
pschofie
2012 WK
Yes there is no doubt the module is conflicting, it should have been removed.
Let me know how you go.
Regards,
Paul
pschofie is offline
2011 Jeep Grand Cherokee MYGIG Upgade jsmith5915 WK2 Grand Cherokee Forum 5 10-26-2011 09:06 PM
MyGiG... HITMONEY WK2 Grand Cherokee Forum 12 02-15-2011 11:31 AM
2011 Grand Cherokee or 2011 Lincoln MKX Theodore42 WK2 Grand Cherokee Forum 70 01-21-2011 01:28 PM
Disappointed with MyGig RRER WK2 Grand Cherokee Forum 3 11-23-2010 05:02 PM
Adding NAV MYGIG wjs81866 WK2 Grand Cherokee Forum 0 10-29-2010 06:31 AM
