2011 Overland Summit - 2nd Water Pump Replacement? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > 2011 Overland Summit - 2nd Water Pump Replacement?
Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEYukon Ultimate 35 axle kit for c/clip axles with Yukon ZipNitro Gear Packages Now Available at Rockridge 4wd
Unread 10-17-2014, 10:49 PM   #1
hazards280
2011 WK
Hi Folks,
A few months back I posted about 2011 Overland Summit (5.7 L) leaking coolant. You can see the thread here. http://www.jeepforum.com/forum/f309/...-help-2414113/
In the end (May 2014) the dealership ended up replacing the water pump under the powertrain warranty and the problem was gone...for a while. Today while I was checking all my fluids for a road trip I have in the morning I noticed some dried up coolant specs on some of the hoses near the water pump.
It appears as if the water pump is leaking a small amount of coolant again although not nearly as bad as it was before. This is somewhat concerning for me as my GC is now at 83k miles and I planned on keeping well beyond the powertrain warranty expires. If these water pumps are in fact this unreliable I may look into replacing the vehicle with something else. The problem is I don't really like any other SUV as much as the GC and I'm not a big fan of the 2014 front end.
Any thoughts or opinions on this issue?
2011 Jeep Grand Cherokee Overland Summit - Black, Stock. Daily Driver
2009 Pontiac G8 GT - Not even close to stock. Weekend Fun
2008 Kawasaki KFX450R - Stock
hazards280 is offline   Reply With Quote Quick reply to this message
Unread 10-18-2014, 07:52 AM   #2
jim_in_PA
2012 WK
I've not seen anyone else post about this problem in the several years I've been on Jeep related forums. In thinking about this, is it a water pump issue, or is there a problem with what the water pump mounts to that is causing the leak that subsequently causes failure? The seals or the machining on the engine where the seals and pump mount...
2012 Grand Cherokee Overland Summit 5.7L V8 - Winter Chill with New Saddle Interior - Nitto NT421Q
jim_in_PA is offline   Reply With Quote Quick reply to this message
Unread 10-18-2014, 08:25 AM   #3
hazards280
2011 WK
Agreed. When I get back from this trip I will be taking it to the dealer for a follow-up to see what they think is the causation for a second failure. I'll have them take a look at the mount that the water pump bolts to for any defects that may be causing coolant to pass through.
Unread 10-18-2014, 03:29 PM   #4
jim_in_PA
2012 WK
Yea, it doesn't make sense that the "pump" is leaking...most often, leaks are at places where two things are joined together ineffectively.
Unread 10-21-2014, 12:07 PM   #5
unobtanium
2010 WK
My 2010 had the water pump replaced at something like 62K miles. Just as a datapoint. My WS.6 Trans AM had a water pump die at about 83K miles. My mustang 5.0 with a flex-fan and a 7K rpm revving cammed up 302 with aftermarket heads at water-pumps like candy. One every 5K miles or so.
No repairs in 30 days and counting! Nirvana!
*Scratch that, 7/30, HEEP broke again. Fail.
unobtanium is offline   Reply With Quote Quick reply to this message
