2011 Limited windshield wiper CRAZINESS! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > 2011 Limited windshield wiper CRAZINESS!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFLASH SALE! Open thread to reveil the Newest Sale @ ROCKRIFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 08-28-2014, 06:56 PM   #1
ajrunke
I bought a used 2011 GC limited roughly a month ago. Today was the first time I needed to use the wipers. They were possessed!! On the slowest speed, it would start off semi fast for 3 passes then suddenly it shot to super fast. Then it would slow down for a pass and then take off again. I changed through all speed settings and it was like every setting was wide open. I then switched to LO and they slowed down to a speed that I would describe as "medium"; definitely not slow. I pulled into my garage and tested each setting. The wipers would pass once on any setting and then not go anymore.
My wipers seem possessed. If there are no suggestions, I'll take it back to the dealer to look at. I was just hoping for a solution since the dealer is a decent haul away.
Thanks.
ajrunke is offline   Reply With Quote Quick reply to this message
Unread 08-28-2014, 08:00 PM   #2
13ovsummit
2013 WK
^^^ - Does the vehicle have the automatic rain-sense option? If so, that could be what is going on ...
13ovsummit is offline   Reply With Quote Quick reply to this message
Unread 08-29-2014, 07:21 AM   #3
kryogen
2011 WK
has automatic sensing.
clean the windshield around the sensor area, or just disable speed sensing.
I tend to not really like automatic anything, because, usually, it eventually fails at working properly and I get pissed.
kryogen is offline   Reply With Quote Quick reply to this message
Unread 08-29-2014, 08:05 AM   #4
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Yeah sounds like what happens when the windshield is dirty around the sensor area near the rear view mirror. Or Rainx got on that area, or the windshield was replaced.
You can disable the rain autosense in one of the EVIC settings menus.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote Quick reply to this message
Unread 08-29-2014, 09:36 AM   #5
kryogen
2011 WK
no rainx near the sensor?
Unread 08-29-2014, 10:05 AM   #6
ajrunke
I'm sure the dealership coated my car with RainX because the rain drop just balled up and rolled away. I'll check it out after work.
