2011 Hemi Cranks But Won't Start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > 2011 Hemi Cranks But Won't Start
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep parts, deals and more at JeepHut.comTJ BDS 2" suspension lift!! FINALLY a GREAT 2" l
Unread 10-13-2014, 03:12 PM   #1
scowman
When car is cold, I push the start button and the car cranks but does not start. It seems to have very small ignition but does not fully catch. I push it again and it stops cranking. I push the button again and it starts.
It did this once or twice a couple of years ago but did not think much of it. Now it's doing it all the time.
I am mechanically inclined and can do everything including replacing the motor and transmission if I had to. I'm looking for places to start or known issues.
I'm thinking O2 sensor, tps sensor, some other fuel impacting sensor or ECU.
All thought are welcome.
Car is out of warranty.
Cheers,
Ken
scowman is offline   Reply With Quote Quick reply to this message
Unread 10-13-2014, 03:21 PM   #2
2kg4u
2014 WK
Read this:
http://www.jeepforum.com/forum/f309/...80/index2.html
Roy
2014 Overland, 3.6 L
Fumoto Qwikvalve, Ionic CXV running boards, Michelin X-Ice Xi2 snow tires
2kg4u is offline   Reply With Quote Quick reply to this message
Unread 10-13-2014, 03:33 PM   #3
scowman
After checking the Hemi Truck forum maybe a crank sensor going bad? Thoughts?
Unread 10-13-2014, 03:51 PM   #4
scowman
Originally Posted by 2kg4u View Post
Thanks! That's it. Now if I can get it fixed in the P54 recall...
Unread 10-13-2014, 05:31 PM   #5
GreatDaneLvr
2011 WK
Yup, definitely sounds like the dreaded fuel relay in the TIPM. How many miles do you have on it??
2011 JGC Overland Summit Rugged Brown/Saddle OFII 5.7 HEMI
GreatDaneLvr is offline   Reply With Quote Quick reply to this message
Unread 10-14-2014, 06:22 AM   #6
Wavicle
2011 WK
Cheers,
Ken
My 2011 Overland started doing this in spring 2014. It was just turning 25K miles and I had all kinds of thoughts as to the source of the problem. Then I found this forum the day after I heard a snippet on the news about a recall. This is definitely part of the failed fuel pump relay and we should be seeing the [lame hack job] recall notice about October 24th.
Wavicle is offline   Reply With Quote Quick reply to this message
Unread 10-14-2014, 10:09 AM   #7
scowman
Recall Update
Here is a link to the DOT recall notice.
http://www-odi.nhtsa.dot.gov/acms/cs...4V530-5118.pdf
I called the Chrysler customer service number on it and was told the recall does not start until October 24, 2014 and if I want it fixed now I have to pay and seek reimbursement by faxing receipts to 877-768-5076 but ONLY AFTER the second recall notice is issued (no idea when that is).
So the recall has been announced but not started yet at the dealer. So if you go the dealer now you have to pay somewhere between $450-$550.
I called two dealers. The first didn't know about is (service manager level) but researched it and called me back saying $450-$550, no parts in stock, leave car 3-5 (working days) no loaner car.
Second dealer had another one, had no parts in stock, leave car 3-5 (working days) no loaner car. I made an appointment for next Tuesday with no guarantee they would get to it that day.
I had a similar problem with the air bag/passenger seat problem. They fixed it with a work around but it cost me about $500.
I had two previous Cherokees and they were bullet proof. These Mercedes Cherokees have too many expensive bugs and a very short warranty.
I may have to buy a Ford!!!!!!!! God that sucks
