2011 grand cherokee subwoofer install - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > 2011 grand cherokee subwoofer install
NEW Smittybilt Gen 2 9.5 winch at JeepHut.comEnd of Summer Sale, 20% OFF!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 07-29-2014, 11:03 AM   #1
Marcm514
2011 WK
Hello, I'm new to this forum so forgive me if this was posted before. Can someone direct me to a thread or a website that would have any information on installing the factory subwoofer and amp into a 2011 jeep grand cherokee that did not come with the sub installed? I have the my gig rbz 430 media center headunit and I would like to install a subwoofer but I want to keep everything factory (personal preference) If anyone knows of a site with information for the subwoofer, amplifier and wiring could you please share the link with me?
Thank you
Marcm514 is offline   Reply With Quote
Unread 07-29-2014, 11:43 AM   #2
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Wiring diagram here:
http://www.wk2jeeps.com/audio/2012_WK_audio_wiring.pdf
Dunno if the rbz is compatible. It is mostly a digital interface to the integrated amplifier in the rear seat area that connects to all the speakers, not only the sub woofer. In other words there is no separate OEM sub amp. Over the years several here have added a sub amp and sub in a couple different methods, however.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now   Reply With Quote
Unread 07-29-2014, 01:00 PM   #3
kkreit01
You will not be able to easily add the OE sub + amp. It will also be very costly. None of the wiring will be there, and I'm sure it would also require a reprogram at dealer. You are much better off going aftermarket. In the end, it would be much easier for the JL Stealthbox + an amp of your choice. It may also be cheaper. The OE amp+sub are nothing to brag about. I wouldn't pay more than $150 for them. You seriously can barely tell the OE sub is there.
kkreit01 is offline   Reply With Quote
Unread 07-29-2014, 02:25 PM   #4
Marcm514
2011 WK
I'm not to crazy about aftermarket and I like that the factory parts are hidden I had an aftermarket system in an older grand cherokee and hated the wires that connected to the battery and the big ugly woofer box in the trunk.
Unread 07-29-2014, 03:49 PM   #5
biker2k
2012 WK
jl stealth box is the way to go it goes in the factory location and makes the stock sub sound like a transistor radio
look it up
http://www.jlaudio.com/car-audio-ste...cherokee-11-up
biker2k is offline   Reply With Quote
Unread 07-30-2014, 08:11 AM   #6
kkreit01
If you install it correctly, no one will know. The Stealthbox is installed in the factory sub location. The amp can easily be hidden, and wiring should be invisible if you install correctly. Check out some stealth installs on diyma. Techflex can be added to make wiring look better than OE. You'd have to obtain power to a factory amp also, and I can guarantee that wiring will be more difficult install -- even if you can buy/obtain it.
Unread 07-31-2014, 08:35 AM   #7
Marcm514
2011 WK
Well I've decided to take the advice you guys have posted and go with the stealth box. You guys were right factory parts is just to complicated to install.
