2011 Grand Cherokee Fobik keys - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > 2011 Grand Cherokee Fobik keys
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 12-22-2010, 02:24 PM   #16
2011Hemi
2011 WK
Originally Posted by john3r View Post
Anyone aware whether these keys are waterproof/weatherproof?....(i.e. if I was to accidentally go into water with it, is it going to 'kill' the key?)
I don't know how weatherproof it is but I do know that even if you kill it the fobik it will still allow you to start the jeep by placing the panic end of it in the switch behind the start button. That part works even if the battery is dead or removed. The RFID chip doesn't use the battery.
2011Hemi is offline   Reply With Quote
Unread 12-22-2010, 03:50 PM   #17
jeepsterguy
As long as the circuits for the RFID don't get damaged, it will keep RFIDing. I don't know what the fobic looks like on the inside, a remote for my other car has exposed circuits when opened.
jeepsterguy is offline   Reply With Quote
Unread 12-22-2010, 05:29 PM   #18
getoutandplay
2011 WK
One of my keys did not survive the washing machine. I am looking into ordering a replacement tonight.
getoutandplay is offline   Reply With Quote
Unread 12-22-2010, 06:04 PM   #19
2011Hemi
2011 WK
Ouch, I hear they aren't cheap.
Unread 12-22-2010, 09:28 PM   #20
john3r
2011 WK
Please post the cost when you find out as one of my keys has failed...enter-n-go module doesnt pick it up, keyless lock/unlock/trunk open/remote start/etc doesnt work...but, if i remove the remote start button and put it in, it will start...kinda weird.
john3r is offline   Reply With Quote
Unread 12-23-2010, 05:53 AM   #21
2011Hemi
2011 WK
Sounds like a dead fobik battery, try swapping the battery with your other remote to test it.
Unread 12-23-2010, 08:18 AM   #22
marquis
I gave up on the customer programmable key I bought on eBay. I'm returning it today. On other jeeps you can coax the car into programming mode and create a new key (providing you have two functional keys). But I can't figure out how to get the WK2 into programming mode. I guess it's irrelevant to the washing machine situation -- but maybe not. The washed key may be electrically kaput, but the transponder should be fine. It's the transponder that is needed to create a new key on the older jeeps. If only I knew how get it to program.
marquis is offline   Reply With Quote
Unread 07-21-2011, 08:45 AM   #23
Curtdri
reprogamming 2011 key
I am trying to understand how to reprogram a key for the 2011 GC. I do not see where to insert key behind start button. any help would be great appreicated.
curtis
Curtdri is offline   Reply With Quote
Unread 07-21-2011, 08:59 AM   #24
jeepsterguy
I read elsewhere that you cannot, take the key to the dealer, he will only charge for the programming.
Unread 07-21-2011, 09:07 AM   #25
Curtdri
2011 key programming
just went to work at a hotel where one of the Jeeps used to transport guest has lost it programming. i have three keys, noon work. anyone know how to reprogam one of the keys. have another jeep that has a working key for itself.
Unread 07-22-2011, 06:15 PM   #26
JeepOrvis97
JeepOrvis97's Avatar
Ours was waterproof lol, went through the wash and works fine.
More Orvis Edition Info Click Here
My Cars:
1997 Grand Cherokee Orvis Edition
1984 Alfa Romeo Spider Veloce
2011 Challenger R/T
1974 Mini Cooper
Family Jeeps:
2011 WK2 Overland
2002 WJ Limited 4.7HO
JeepOrvis97 is offline   Reply With Quote
Unread 07-23-2011, 07:36 AM   #27
sac01
2011 WK
curtis
Just pull the start button out and the ignition switch I'd right behind that...the button is just a cosmetic cover for the ignition. You can actually remove the button and still do push start by pressing in on just the ignition switch.
2011 GC Laredo X - Dark Charcoal Pearl
4WD w/ 5.7L Hemi
Off-Road Adventure I Pkg.
430N Media Center & Single Pane Sunroof
sac01 is offline   Reply With Quote
Unread 07-26-2011, 10:55 AM   #28
Canada1
Just in case some of you did not know this, using the fobik, you can lower your front windows.
here how it works... with the doors locked and windows up, unlock using the fobk then press again on the unlock keeping depressed... the two front windows will lower and stop when you take finger off the unlock.
Cheers,
Canada1
Canada1 is offline   Reply With Quote
Unread 07-26-2011, 06:49 PM   #29
webnel
2011 XJ Cherokee
I normally hide a key per vehicle. What options do we have now with the fob? Those things are about $140 from mopar new.
Also, does locking the door with just the hard key turn on the alarm?
webnel is offline   Reply With Quote
