2011 Grand Cherokee Fobik keys - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > 2011 Grand Cherokee Fobik keys
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!Rugged Ridge Modular XHD Snorkel Now for both 3.8L and 3.6
Unread 11-01-2010, 04:58 PM   #1
jeepsterguy
Any of you guys figured how to change batteries in the new Fobik keys that come with the key-less entry?
I was wondering because sooner or later the batteries will need replacement and this key doesn't have the usual notch for splitting the case open.
jeepsterguy is offline   Reply With Quote
Unread 11-01-2010, 07:11 PM   #2
mario figueroa
no and i was trying to figure this up to.
mario figueroa is offline   Reply With Quote
Unread 11-01-2010, 08:15 PM   #3
OBRN1
2011 WK
On page 28 of the downloadable manual from jeep.com, it shows that you remove the "key" from the fob and how to pry apart the Fobik.
OBRN1 is offline   Reply With Quote
Unread 11-01-2010, 09:24 PM   #4
jeepsterguy
And a lot more. Very nice!
Thanks.
Unread 11-01-2010, 09:53 PM   #5
OBRN1
2011 WK
Thanks.
Your welcome
Unread 11-01-2010, 11:06 PM   #6
mario figueroa
Thank you OBRN1,i did open mine all ready.
Unread 11-03-2010, 08:34 AM   #7
OBRN1
2011 WK
Your welcome. There is a ton of information in the online manual that isn't in our glove box manual. Someone on here directed me to it when I had a question about snow chains.
Unread 11-03-2010, 10:13 AM   #8
SPL170db
Yup, I accidentally took mine with me in the, errrr ocean, so I had to open it up and make sure it was good and clean and dry. Its not that tricky to pop it open.
SPL170db is offline   Reply With Quote
Unread 11-03-2010, 11:54 AM   #9
jeepsterguy
Somehow I took the User's Guide to be the manual. I thought you always get a paper manual. Times change.
I was looking yesterday about a procedure to replace the battery, didn't find any. I guess I'd have to remove the bolts/nuts that hold the seat to get to it. I keep thinking that they may be an easier way. A search in the pdf manual for "battery" didn't show anything, or I missed it.
Unread 11-03-2010, 04:36 PM   #10
OBRN1
2011 WK
See if this link helps: Jeep Grand Cherokee WK2 - AGM Battery
Unread 11-03-2010, 05:14 PM   #11
JoeSchmoe007
Does it mean that you have to remove the seat? Or just moving forward is enough?
JoeSchmoe007 is offline   Reply With Quote
Unread 11-03-2010, 06:17 PM   #12
OBRN1
2011 WK
I went out and looked at mine, seems the seat would move forward enough. My Mercedes GL450 has it in the same spot and moving the seat forward is more than enough.
Unread 11-03-2010, 11:03 PM   #13
jeepsterguy
A lot of new things in my new Jeep. My older Jeeps are old technology. Thanks for the help.
BTW today I did my first remote start, just to try the system. Worked great, I'll be using it this winter quite a bit.
Unread 12-22-2010, 08:15 AM   #14
marquis
Speaking of FOBIK, does anyone know if the customer can program a new key for the 2011 GC? I know the customer could do so in older Jeeps (as long as they already had two functional FOBIKs). Seems like this may not be the case in the new Grand Cherokee (at least when I attempted to create a new FOBIK). Anyone have any experience in this area.
marquis is offline   Reply With Quote
Unread 12-22-2010, 08:24 AM   #15
john3r
2011 WK
Anyone aware whether these keys are waterproof/weatherproof?....(i.e. if I was to accidentally go into water with it, is it going to 'kill' the key?)
john3r is offline   Reply With Quote
