2011 GC 5.7 HD brakes vs Standard?? - Page 2 - JeepForum.com
post #16 of 39 Old 02-08-2013, 07:55 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
In my 2011 parts book, there is only one master cylinder part number. There are a couple more ABS control unit part numbers than can be explained by left/right hand drive, however. None are coded BR1, BR6 or BRY, so probably nothing to do with HD brakes.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #17 of 39 Old 02-09-2013, 01:54 PM
barry1me
barry1me's Avatar
I used to design brakes for TRW so my guess is that the standard vs HD are the same size of piston in the caliper or they would have probably changed the master cylinder. I would suspect ABS tuning to be different from Standard vs HD brakes as they have a different amount of stopping force and contact area.
Sport TJ build
everything below has a hyperlink to the install/review
Before you ask about a product in the Technical forums check out the product review section!
barry1me is offline
post #18 of 39 Old 02-12-2013, 04:43 PM
barry1me
barry1me's Avatar
Ok im confused. I just picked up our brand new left over 2012 Laredo X 4x4 hemi with tow package. The rear rotors are not vented like every tow package V8 I have seen in the past. I dont understand.
Sport TJ build
barry1me is offline
post #19 of 39 Old 02-12-2013, 05:13 PM
ColdCase
ColdCase's Avatar
2011 WK
I learned recently that none of the Laredos have HD brakes (vented rears), just the Limited and Overland V8s.
ColdCase is offline
post #20 of 39 Old 02-12-2013, 05:35 PM
barry1me
barry1me's Avatar
Thats what I just found out too. Kinda a bummer.
Sport TJ build
barry1me is offline
post #21 of 39 Old 02-12-2013, 05:55 PM
LouC
2007 WK
I wouldn't worry too much about it, my WK with factory tow has solid rear rotors and it tows just fine. My boat trailer has surge brakes and you can't even feel it back there. I also towed a 3000 lb cargo trailer without brakes and it stopped fine even at highway speeds.
2017 JK Unlimited Sport 6 spd
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
post #22 of 39 Old 04-05-2013, 09:31 AM
zamerzant
2012 WK
i have a 2012 overland hemi but i dnt see any vents on the disks so are the vents are visible????
can any one post pics of hd brakes with vents???
thanks...
zamerzant is offline
post #23 of 39 Old 04-06-2013, 06:48 PM
WvTaco
2011 WK
Welcome to the ownership of cars.
Here.
http://auto.howstuffworks.com/auto-p...isc-brake1.htm
Your confusing slotted for vented.
WvTaco is offline
post #24 of 39 Old 01-06-2014, 05:01 PM
mx71
2013 WK
I have a 2013 Altitude 5.7L with the standard brakes. If I am gathering this all correctly...to upgrade to the HD package...all I would need is the two rotor adapters/brackets for the front, front rotors and rear rotors? Does that sound correct? I wouldn't be doing it until I needed a rotor change up front. Would I notice a 20mm difference in rotor size?
mx71 is offline
post #25 of 39 Old 08-31-2014, 10:09 AM
kryogen
2011 WK
So pads are the same for hd and non hd right?
What pads do you guys use after oem areworn?
kryogen is offline
post #26 of 39 Old 07-02-2016, 07:07 PM
dcarguy
Originally Posted by Jeep_addicted View Post
There are the three sales codes describing the brakes for the 2011-2013 WK2
- BRY - Standard Anti-Lock Brakes (Front-vented, rear-solid, for 17") 330mm rotors front and rear
- BR6 - Heavy Duty Anti-Lock Brakes (Front-vented, rear-vented, for 18") 350mm vented rotors front and rear
- BR1 - European Anti-Lock Brakes (Front-vented, rear-vented, for 18") 350mm vented rotors front and rear
So... the only difference between the BR1 and BR6 is one is for the European market? You can't get the BR1 package in the US?
Nice info on the brakes! Thanks very much.
dcarguy is offline
post #27 of 39 Old 04-14-2017, 07:32 AM
jedi_master58
I have the V6 Overland 2012 model year. The front are vented and the rear are not. Can i install vented in the front and back, and can I put in the bigger 350mm disks front and back?
2004 Jeep GC Ltd 4.7L V8
2012 Jeep GC Overland 3.6L
2016 Jeep GC Ltd 3.6L- lux pkg, tow pkg
jedi_master58 is offline
post #28 of 39 Old 04-14-2017, 08:25 PM
ColdCase
ColdCase's Avatar
2011 WK
I'm not sure if anyone has done it, some have put SRT brakes an but thats big money.
Early in the thread are part numbers. For the front I think you need the rotors and new caliper brackets. You can use the same caliper and pads. In the back I think its rotors and calipers, no need for brackets as the rotors are the same diameter.
ColdCase is offline
post #29 of 39 Old 04-15-2017, 06:39 AM
jedi_master58
Yeah def not doing the SRT brakes! I noticed that the front rotors are larger than the rear, and front are vented and rear are solid. I should just stick with the same sizes?
I would probably have to get the caliper brackets from the dealer, as I will probably get my independent dealer to do the install and purchase the brake parts online.
I want to put on cross drilled rotors and ceramic pads. Think that's a smart decision? lol
post #30 of 39 Old 04-15-2017, 07:51 AM
ColdCase
ColdCase's Avatar
2011 WK
The HD rotors are all vented, and the front rotors are larger diameter than SD but the same thickness, so you need the brackets. Off hand, I dunno how hard they are to find. The vented rear rotors are a lot thicker but the same diameter, so you need calipers to match. The larger front rotors make the most difference. I like the feel/bite of semi-metalic pads better than ceramic, but there is less dust with ceramic. I am using ceramic know, they are OK. There are a wide variety of pad choices.
Depending on your driving style, you may or may not see any difference, but you'll certainly have more fade margin.
Drilled or slotted rotors don't do anything for a WK2. Affordable drilled rotors have a tendency to crack. OEM rotors are a lot of money, Autozone sells decent rotors for a good price.
You may want to check vendor Kolak, he knows WK2s and may be able to set you up with all the parts you need.
ColdCase is offline
2011 wk2 DirtyTires WK2 Grand Cherokee Forum 59 07-01-2013 02:51 PM
Turn signal relay: standard or electronic? MI_Limited WK2 Grand Cherokee Forum 0 09-16-2011 07:12 AM
2011 Quadra-Drive II vs Quadra-Track II in 2011 WK MMACrypt WK2 Grand Cherokee Forum 13 02-09-2011 11:37 AM
2011 Grand Cherokee or 2011 Lincoln MKX Theodore42 WK2 Grand Cherokee Forum 70 01-21-2011 02:28 PM
Look at a 2011 JGC Ryan45 WK2 Grand Cherokee Forum 2 08-30-2010 03:16 PM
