'13 Transmission pulsation question? - JeepForum.com
post #1 of 4 Old 12-21-2015, 09:16 AM Thread Starter
roadkingg1
2013 WK
Hi Everybody,
Purchased a loaded, low mileage (18K) ’13 Laredo from a dealer in October. Coming from a fully utilitarian SUV to this was like night and day. The ride is fantastic, the V6 is as smooth as silk and I really like the interior. Here’s my question, never owning a Jeep before, I have this very slight pulsation from, I believe, the transmission when I accelerate from a stop to about 20-25 mph. The tech at the dealer drove it and said its normal “clutch pack” engagement. Has anyone ever heard of this? I guess I could find another “13 to test drive to see if it has this same sensation. Just checking to see what you thought. Thanks for any info.
roadkingg1 is offline
post #2 of 4 Old 12-22-2015, 06:44 PM Thread Starter
roadkingg1
2013 WK
Based on the response this must be an isolated case. Back to the dealer for the 4th time. Any stratiges for dealing with the dealer who tells me "it's a normal" and then says they can't feel it? Maybe I'll see if they'll buy it back. Thanks!
post #3 of 4 Old 12-23-2015, 07:14 AM
Lightninrod
2013 WK
Never noticed that on my 2013 V8 2WD Overland.
Dan
Lightninrod is offline
post #4 of 4 Old 12-23-2015, 08:34 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Hey roadkingg1,
TSB 21-003-13 may relate to your vehicle’s concern:
SUBJECT:
Flash: Drivetrain Control Module (DCTM) - Transfer Case Operational Enhancements
OVERVIEW:
This bulletin involves flashing the Drivetrain Control Module (DCTM)
MODELS:
2011 - 2013 WD Durango
2011 - 2013 WK Grand Cherokee
NOTE: This bulletin applies to vehicles equipped with the QUADRA-TRAC II 4WD
System or Two Speed On Demand Transfer Case (Sales Code DKA) and the
following:
• 230MM Rear Axle (Sales Code DR1) and Electronic Limited Slip
Differential (Sales Code DSF)
• 230MM Rear Axle (Sales Code DR1) without Electronic Limited Slip
Differential built after May 1, 2011 (MDH 0501XX).
• 195MM Rear Axle (Sales Code DRH) (all 3.6L engine equipped (Sales
Code ERB) built after May 1, 2011 (MDH 0501XX).
SYMPTOM/CONDITION:
Owners may indicate that they have experienced one or more of the following symptoms:
1. A driveline bump is felt during acceleration at approximately 10 mph (16 kph).
2. The SERV 4WD message appears and the vehicle shifts from 4WD to 2WD.
3. Binding of the front driveline while turning on steep grades at speeds around 3 - 5 mph
(5 - 8 kph).
JeepCares is offline
