11 Hemi Overland Differential whine/ roar - JeepForum.com
post #1 of 13 Old 06-23-2013, 03:50 PM Thread Starter
elarm1
2011 WK
Hello, I am a proud owner of my 2011 Jeep Overland Hemi with the quadra trac suspension and I am having issues. I took the Jeep to a track day and towed two motorcycles with a enclosed trailer and had no issues yesterday. Today I took the Jeep for a little light off road trail I know at low speeds with 4 low on and hill descend on everything was fine with no unusual noises until I made it back to dry pavement. Now I hear a roaring noise whenever the speeds are above 40 mph. Anyone have the slightest idea where I should look? I power washed the undercarriage then hand washed the truck to make sure all dirt and mud was off. I also have no warning lights on.
elarm1 is offline
post #2 of 13 Old 06-23-2013, 04:26 PM Thread Starter
elarm1
2011 WK
It appears to be coming from the left wheel. I am taking it off now to inspect
elarm1 is offline
post #3 of 13 Old 06-23-2013, 06:14 PM Thread Starter
elarm1
2011 WK
Mud caked up and removed but I'm still hearing and feeling the noise on the left side. Going down the road and making left bend turns I hear and feel the noise but doing the same thing on right bends, I don't feel or hear it. Any suggestions?
elarm1 is offline
post #4 of 13 Old 06-23-2013, 11:33 PM
modernblueWK
Wheel bearing is the typical suggestion with your left/right description.
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
post #5 of 13 Old 06-27-2013, 09:48 PM Thread Starter
elarm1
2011 WK
I replaced the left front wheel bearing (where I was hearing the noise) and I STILL have the same noise! Around 30mph, it roars with a whomp whomp whomp not super loud, but definitely noticeable. Any other places I can look before I take it to a professional for an opinion?
elarm1 is offline
post #6 of 13 Old 06-27-2013, 10:03 PM
tjkj2002
2002 KJ Liberty
How about a alignment,could be tire noise caused by a bad alignment.
tjkj2002 is offline
post #7 of 13 Old 06-27-2013, 10:16 PM
CJATE
Breaks ok? They can make that but more frequently squeal.
Sure it's out of 4x4?
Sent from AutoGuide.com Free App
83 CJ-8 scrambler
SOA
Locked and Twin-sticked
35's, fenders cut
4.56
bad paint
leaks just about everything
CJATE is offline
post #8 of 13 Old 06-27-2013, 10:21 PM Thread Starter
elarm1
2011 WK
It's a 2011 full time awd. I can rotate the tires but I seriously doubt that is it. More suggestions please... I'm already in the ****e house with my old lady!
elarm1 is offline
post #9 of 13 Old 06-28-2013, 05:52 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Did you damage the tire? Roars are typically bearings, could be any one. Diff, transfer case. Most common is the wheel bearing you replaced, usually the easies least expensive bearing to get at. My Vette roared when a snap ring let go and got caught up in the overdrive bearing.
Roars could also be u-joint related, especially with the womp womp, but they typically are rumbles.
Some here have had issues with rear drive shafts, perhaps investigate that next.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #10 of 13 Old 06-28-2013, 09:30 AM
Dave2002ti
2012 WK
Rear driveshaft issues
Never really experienced any roar or whomp whomp when my rear driveshaft failed it will start to slip and make other noises.
Dave2002ti is offline
post #11 of 13 Old 06-28-2013, 10:16 AM Thread Starter
elarm1
2011 WK
The noise is definitely front left and NOT in the rear drive shaft. It will be going to the dealer next week hopefully to be covered by powertrain warrenty.
elarm1 is offline
post #12 of 13 Old 06-28-2013, 10:24 AM
Dave2002ti
2012 WK
Rotate tires
Goodyears could be the problem. Take the right rear tire and put it the left front and see if you get the same noise. Check any CV joint boots etc for holes.
post #13 of 13 Old 06-28-2013, 02:30 PM Thread Starter
elarm1
2011 WK
No holes in boots and no damage to the tires. Rotated and the noise is still there
elarm1 is offline
