'11 GC: TSB for Rough Shift From N-D (18-049-11) Not Fixed After Dealer Reflash?? - Page 2 - JeepForum.com
post #16 of 37 Old 05-21-2012, 02:04 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
Please update us when you have one.
JeepCares is online now
post #17 of 37 Old 05-23-2012, 11:24 PM
hobbie1
2015 WK
They got the part in. it did not fix the problem. Still banging from D to R - comes and goes. They called STAR and we're told to order and replace the transfer case. Not sounding good but they are trying to fix it.
15 Summit 4X4 Eco Diesel
14 RAM 2500 Cummins 4X4 Laramie CC
13 Mustang GT
66 Mustang Cp - 306 5sp
hobbie1 is offline
post #18 of 37 Old 05-23-2012, 11:31 PM
hobbie1
2015 WK
One other note - when in 4 LOW it is really bad so I'mthinking there is some merit in replacing the transfer case. Just curious - are all of the Jeeps here with the problem equipped with the 5.7 Hemi? Maybe this is a torque / power issue that is tearing up the transfer case
13 Mustang GT
hobbie1 is offline
post #19 of 37 Old 05-24-2012, 07:22 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Thanks for the update. Let us know if the transfer case works.
post #20 of 37 Old 05-24-2012, 11:28 AM
SixZeroFour
2011 WK
It does seem that its only a problem with the Hemi. Let's hope the transfer case replacement does the trick.
SixZeroFour is offline
post #21 of 37 Old 05-24-2012, 11:32 AM
SixZeroFour
2011 WK
Hi Lee,
Thanks for keeping an eye on this.
I was hoping you might be able to answer a question for me...
I live in Vancouver Canada and the one dealer I spoke with did not seem to know what a star case number was - is this a US only system? and is there any way to cross reference it so that I can point them in the right direction? or should I be looking for a new service department
Another highly informed member of another Jeep site posted yesterday saying that there is a new TSB in the works for this but that at this time it only mentioned the 2012 Hemi and not the 2011's... have you heard anything about this at all?
Thanks again,
"Quote:
Originally Posted by Milous
This issue will be addressed via an upcoming TSB. It will cover the 2012 Grand Cherokee and Durango. Scheduled release date for the bulletin is June 4, 2012."
post #22 of 37 Old 05-24-2012, 12:39 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
I'm pretty sure Canada uses DealerCONNECT/TechCONNECT.
I had put in the vehicle as a 2011 WK with a 5.7 (since I had no VIN) and did a search for "11721933." I don't know if this is actually a STAR case number or not, but it brought up the info.
post #23 of 37 Old 05-24-2012, 12:43 PM
SixZeroFour
2011 WK
Perfect - Thanks.
post #24 of 37 Old 05-24-2012, 12:54 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
There is a service bulletin scheduled to be released 06/04/2012 that involves 2012 WD, DX, DJ, D2, DS, WK, DD - Drive to Neutral Shift Shock. I have not seen the final approved version, so I do not know if it is applicable in this situation. Also, just because something is scheduled to be released on a certain date doesn't mean it will.
___________________________________________
There is a Bulletin number: 18-015-12 that came out April 20, 2012.
SUBJECT:
Flash: Bump Or Harsh Shift Neutral to Drive And Avoid MIL Illumination For Any P0032, P0038, P0052, P0058, P0031, P0037, P0051, P0057
OVERVIEW:
This bulletin involves diagnosis and selectively erasing and reprogramming the Powertrain Control Module (PCM) with new software or if necessary replacing the PCM based on the DIAGNOSIS. This new software once reprogrammed in the PCM will prevent the need to replace the PCM when the diagnostic trouble code (DTC's) listed below occur as a pair.
MODELS:
2011 (WD) Durango
2011 (WK) Grand Cherokee
NOTE: This Service Bulletin applies to vehicles equipped with a 5.7L engine (Sales Code EZH).
SYMPTOM/CONDITION:
The customer may experience a MIL illumination or a harsh shift from neutral to drive.
post #25 of 37 Old 06-08-2012, 10:29 PM
hobbie1
2015 WK
Lj
One other note - when in 4 LOW it is really bad so I'm thinking there is some merit in replacing the transfer case. Just curious - are all of the Jeeps here with the problem equipped with the 5.7 Hemi? Maybe this is a torque / power issue that is tearing up the transfer case
Got an update for everyone. Transfer case was ordered and replaced yesterday per STAR. Yes indeed the problem is gone! FIXED! Note when they had the case out they could feel the movement.
I also heard that several Hemi's taken to dealers in the San Francisco Bay Area have had the same issue and had to have the transfer case replaced.
Here's the parts list from the work order:
52119981-AA Valve Transmission
5010884-AA Sealer RTV 10
68055894-AA Fluid ATV + 4 10
52853664-AD Case NONE 21
Note the AD on the transfer case - could this be revision "D" ?
Anyway the noise is gone and the Jeep is back to normal.
Walnut Creek Chrysler - Jeep - Dodge - RAM are dialed in on the problem. They were great and stayed on the problem. Claudia kept me informed. Great service.
Hope this help.
13 Mustang GT
hobbie1 is offline
post #26 of 37 Old 06-08-2012, 11:57 PM
jarueda13
2011 WK
Sounds good awesome. Question you didn't have to pay for this right?
jarueda13 is offline
post #27 of 37 Old 06-09-2012, 01:23 AM
hobbie1
2015 WK
No cost, covered on warranty 21000 miles and I have a service plan to 7 years 100k
13 Mustang GT
hobbie1 is offline
post #28 of 37 Old 06-11-2012, 12:26 AM
hobbie1
2015 WK
13 Mustang GT
hobbie1 is offline
post #29 of 37 Old 04-29-2013, 09:32 PM
hobbie1
2015 WK
Hello everyone HELP! Its back the banging sound - my neighbors were laughing as they could hear it accross the street - sounds like the drive line is about to fall out on the street - the fix lasted 9000 miles - this is become a joke - just had the left front CV boot and axle replaced, water pump and now after 9000 miles the new transfer case is banging. Not to mention my 2012 RAM goes back in on Tuesday so an area tech can look at a problem that the dealer can duplicate but can not fix. Two new vehicles over $100K and they are both falling apart. If someone is reading this from Chrysler I really need some help here.
13 Mustang GT
hobbie1 is offline
post #30 of 37 Old 04-29-2013, 10:39 PM
hobbie1
2015 WK
When I get some time tomorrow I'm going to post this noise on youtube add some warm weather and it really gets loud.....
13 Mustang GT
hobbie1 is offline
Stupid dealer soulpatch WK2 Grand Cherokee Forum 28 01-23-2012 12:32 PM
TSB dealer help hutchison101 WK2 Grand Cherokee Forum 5 07-08-2011 10:08 AM
First Maintenance at Dealer - should I laugh or be mad? MaineJeep11 WK2 Grand Cherokee Forum 30 05-06-2011 10:43 PM
? about dealer mster WK2 Grand Cherokee Forum 16 04-12-2011 07:06 AM
Passive Entry Module not working - now fixed RRER WK2 Grand Cherokee Forum 3 10-27-2010 10:02 AM
