The Photography Questions Thread - Page 2 - JeepForum.com
post #16 of 596 Old 02-27-2008, 12:22 PM
FmrVette
FmrVette's Avatar
2008 XK Commander
Originally Posted by Dimmy View Post
I have a question concerning photo editing software. First off, I'd rather shoot in RAW.
With my Nikon, I cannot convert to JPG with the software it came with....)
What software do you recommend?
Photoshop Elements - version 6 is released but 5 is available for $25 (plus shipping):
http://www.amazon.com/Adobe-Photosho...4139945&sr=8-4
Version 6 going for under 90 bucks.
I use ver 5 to open my Nikon D70s RAW files, under both XP and Vista.
Good stuff .
Jim
"Basically, I'm for anything that gets you through the night - be it prayer, tranquilizers or a bottle of Jack Daniels.” - Frank Sinatra
"When the last Blackhawk helicopter goes to the boneyard, it will be on a sling under a Huey." - Every Huey pilot that lived through it.
'95 YJ, '00 XJ, '06 TJ, (Current:) '08 XK
FmrVette is offline
post #17 of 596 Old 02-27-2008, 01:49 PM
Wamp
Wamp's Avatar
I use Photoshop CS. It has been great so far.
Wamp is offline
post #18 of 596 Old 02-28-2008, 12:09 AM Thread Starter
AlTheKillerr
AlTheKillerr's Avatar
well im back but my photoshop wont open for some reason so im going to try a restart and see what happens.
turns out "in the mountains" really wasnt in the mountains so i may have one or two pictures that i like
Edit: started to post some new pics in the picture thread
Photographer
AlTheKillerr is offline
post #19 of 596 Old 02-28-2008, 05:30 AM
Wamp
Wamp's Avatar
Looking forward to seeing your photos. Here's one of my mountain pics while we wait.
This is Mt. Wilson near Telluride Colorado. 2006
Wamp is offline
post #20 of 596 Old 02-28-2008, 08:04 AM
XJLI
XJLI's Avatar
1993 XJ Cherokee
Another vote for Lightroom. I'm using 1.3 and its awesome.
Factory Four Link
XJLI is offline
post #21 of 596 Old 02-28-2008, 09:01 AM
FmrVette
FmrVette's Avatar
2008 XK Commander
I just had to go and check out the specs on Lightroom after the recommendations in this thread.
Found a pretty good explanation of what it is, what it isn't, and how it differs from Elements and CS3 here:
http://www.photoshopsupport.com/tuto...lightroom.html
The interesting parts for me (quoted from website above):
"Lightroom is NOT an alternative to Photoshop CS3 or Photoshop Elements. It has no ability to edit multi layered images, use adjustment layer masks to enable localized editing, apply filters or convert images to CMYK for press, so its definitely one short of a six-pack in this department. Lightroom can optimize the appearance of an image but it does this globally. You want the whole image darker – fine, you want the bit in the bottom left-hand corner to be darker - forget it. You can target individual colors or tones within the entire image for special attention in Lightroom but you have no selection tools to allow you to target your adjustments to a localized area within the image."
Not good for me - I have Elements which will target localized areas, and do layers, etc.
However, a further quote from the website:
"...Lightroom actually is – a database with extras...A good photographic database will let you locate and see a full-screen preview of any image you have ever taken in seconds – even if the image file isn’t on your computer... To put it simply Lightroom is a database that can work with images spread across multiple discs and hard drives (internal or external)"
Now you have my attention; if one has only a few hundred images taken over a brief time period then organization of the files isn't too much of a task. But thousands of images taken over several years...that can lead to some issues in finding that photo of the tree on the hill that you took in 1998..or was it in '96?
I'm quite happy with Elements as my photo editor - but I'm gonna have to check Lightroom out.
Thanks for the lead! .
Jim
FmrVette is offline
post #22 of 596 Old 02-28-2008, 10:01 AM
XJLI
XJLI's Avatar
1993 XJ Cherokee
I haven't really used LR's databasing. I simply load my pics onto my external drive and arrange them by folders. I don't need another program to organize pics any other way.
So I simply "upload" them into LR (meaning, putting them into the database, LR doesnt copy the image into another folder) and edit. I then save the edited pic as a JPEG into an edits folder inside the main picture folder. For instance, say I have a folder titled "castle pics 1.20.2008." those are all my RAW uploads. In that folder theres an edits with all the JPEGs that are retouched.
Also, if you open the RAW image in LR after editing it, it opens with all the edited parameters from the previous edit. You need to delete the image from the "database" to start fresh. Or simply, set everything to "default."
And it definitely is NOT a replacement for Photoshop. I can start in LR, then simply open up the pic (either edited, RAW, or both) in PS through a command in LR.
When doing just photos, I prefer LR over PS. That is, until I start doing more crazy stuff, or adding text. The only thing I wish LR had was a burn/dodge tool. Otherwise I think its an awesome program.
Factory Four Link
XJLI is offline
post #23 of 596 Old 02-28-2008, 11:19 AM
actionplant
1992 XJ Cherokee
Shooting sometimes between 400-800 shots a day, yeah, you'd better believe I like Lightroom's databasing. I have nightly backups to an external drive and let it manage everything else for me. Where in other programs I'd be digging through dated folders trying to find a specific shot I love how I can select to look at my entire library, very quickly scroll through the thumbs until I spot the set I'm looking for, and select a specific shot to work on from there.
Also, I do concede that Lightroom isn't for heavier photo manipulation. My workflow is camera-lightroom-photoshop-print. Someone who needs a program for, "all I want to do is convert the file format, do some croping, and adjust tints, color, balance and etc." will find that lightroom does these things. If you shoot RAW it's a perfect extension of your camera's processing.
Also, because of the nature of RAW, the editing data is stored non-destructively within the RAW file so that you can revert back to the original shot at any time, even weeks later after mutliple saves. The same process would be a little convoluted in layered files.
So Lightroom and Photoshop are two different animals. Ultimately with enough plug-ins you could use Photoshop to arrive at the same results of what you do with Lightroom, but for ease-of-use and for the databasing feature I prefer running the two seperately. Also, for someone not looking to retouch photos but simply take advantage of the additional control RAW allows, Lightroom helps avoid some of the huge learning curves a newbie to Photoshop would be facing.
I consider myself fairly proficient with Photoshop, but lately if my photo is close to perfect already and I don't need the retouching, I've found that tweaking in Lightroom and going straight to print has given me stellar results. I even did my own wedding photos this way and everyone was perfectly delighted with them.
So I would say shoot RAW and use Lightroom, and for lots of folks it's a good solution. Powerusers, commercial editors and people who want to play more will find Photoshop is the next logical step.
actionplant is offline
post #24 of 596 Old 02-28-2008, 11:28 AM
sparkchaser
sparkchaser's Avatar
Actionplant, you have sold me on giving Lightroom a second chance.
"Sandstorms inflict damage of about $540 million per year, and losses of crops and forests due to acid rain amount to about $730 million per year. More serious are the $6 billion costs of the "green wall" of trees being built to shield Beijing against sand and dust, and the $7 billion per year of losses created by pest species. We enter the zone of impressive numbers when we consider the onetime cost of the 1996 floods ($27 billion, but still cheaper than the 1998 floods), the annual direct losses due to desertification ($42 billion), and the annual losses due to water and air pollution ($54 billion). The combination of the latter two items alone costs China the equivalent of 14% of its GDP each year." - Jared Diamond, Collapse: How Societies Choose to Fail or Succeed
sparkchaser is offline
post #25 of 596 Old 02-28-2008, 11:52 AM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
best SLR camera for the money?
1990JEEPXJ is offline
post #26 of 596 Old 02-28-2008, 11:59 AM
actionplant
1992 XJ Cherokee
OUCH!! Look around on the net and you'll see a lot of Nikon v. Canon wars with the occassional interjections from the Minolta/Sony/Pentax/etc crowd.
Depends on how much "the money" really is, and even then you'll find stiff competition that really all comes down to personal preference.
Not trying to cop-out, just saying they each have their own strengths and weaknesses and depending on the day of the week, hour of the day, and who happens to be around when you ask you could get a dozen different answers.
The field narrows if you ask for the best camera, period, but even then you'll get arguments from people shooting Mamiya (like me), Hasselblad (also like me), Leica (can't afford it), Rollei, and others.
The thing we gearheads tend to lose sight of is this: put the most expensive camera in the hands of an average shooter and you'll get average shots. Put the cheapest camera (and yes, I do shoot a Holga occassionally, and love it) in the hands of a visionary and you're likely to get something amazing.
In other words, as much fun as the toys are, it's really not about the gear.
EDIT - I realize that still looks like a cop-out so I'll just list the Hasselblad H3D as my dream camera. Right now my two favorites are my Mamiya 645 and my Hasselblad V-series, though both shoot film, not digital.
I'm looking around for a reasonably priced (sub-$6000) used digital back for the Hassy.
post #27 of 596 Old 02-28-2008, 03:46 PM
FmrVette
FmrVette's Avatar
2008 XK Commander
http://www.kenrockwell.com/tech/150-...lar-camera.htm
actionplant has it about right; it ain't so much the machine as it is the machine operator...
Jim
FmrVette is offline
post #28 of 596 Old 02-28-2008, 03:57 PM Thread Starter
AlTheKillerr
i agree
the equipment is more there to help aid in the prosses but if you give a truelly good photography a cheap little camera they should still be able to amazing pictures.
Photographer
post #29 of 596 Old 02-28-2008, 06:25 PM
Rezneck
Kind of what I think. Give me the best fitted custom golf clubs and give Tiger Woods a tomahawk and a rock and he still smokes me.
I wonder if a better approach would be to find a line of lenses you like first and then pick a compatable camera.
http://www.bhphotovideo.com/c/produc...AFS_ED_IF.html
BTW, I've got a Nikon D40x and I think it's way better than I am.
Throw the bums out!
48 CJ-2A, Bone stock except it has Allstate locking hubs.
86 CJ-7, 4.0 HO, AX-15, D-30, AMC-20
84 CJ-7, YJ tub and fenders, 258 ci, T-176, D-30, D-44 Trutracs F/R, 4.27s, 33s
77-90ish Wagoneer/TJ/CJ Yard Sale Special, 360AMC, TH400, Quadratrac, D-44s F/R, 3.07s, 34" LTBs.
Rezneck is offline
post #30 of 596 Old 02-29-2008, 07:17 AM
actionplant
1992 XJ Cherokee
That's kind of the route I went. I already shot Mamiya 35mm for years and know the older M-42 screw mount was Pentax, and easily adaptable (with a ring) to the Pentax K-mount bayonette. I loved my older Mamiya glass so a Pentax DSLR made sense for me, and that's the route I went. It's slightly more obscure, but you CAN find newer Zeiss optics with K-mounts and since optics are really where it's at (sensors change from year to year, glass is where you want to invest) I had no qualms buying one of the smaller brands.
Photography and the law AlTheKillerr Film, Music and Art 45 07-28-2009 08:48 PM
Photography 95ZJL Film, Music and Art 31 05-07-2007 12:46 PM
Night Photography Muddy Cherokee Film, Music and Art 23 03-07-2007 06:08 PM
The Jeep Photography Thread HeavyMetal Film, Music and Art 26 10-23-2006 02:22 PM
Photography Rasta_Coty Film, Music and Art 11 08-18-2006 01:38 PM
