Won't shift out of park - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KK Liberty Forum > Won't shift out of park
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 10-08-2010, 04:08 PM   #1
otlip
Hello fellow KKers.
Here is a good one, took the jeep out to Montauk's Turttle Cove and did some fishing. Entering and exiting had to drive through a small puddle. No problems until I stopped and hit a few golf balls at Montauk Downs Golf Course. Clubs went into the car, key in the ignition and started the car. The front wipers came on so I try and turn them off and guess what.... the switch was off. Then tried to put the car in gear and it wouldn't shift out of park.
Long story short call the tow truck and was told 1.5 hour wait. Decided to disconnect the battery and then reconnect. It started normally, no wipers, and I could shift it out of park.
Drove it to Southampton to a dealer and was told that since I disconnected the battery the computer was wiped clean of any codes.
Seems to be running well now. Does anyone have any ideas or has this happened to anyone else. I'd love to hear!
If this happens to anyone, try disconnecting the battery, turning the ignition key on and then connecting the battery cable again (positive).
Rich
ps no fish, and hit the golf ball very poorly!
otlip is offline   Reply With Quote Quick reply to this message
Unread 10-08-2010, 04:19 PM   #2
richd
2008 KK Liberty
Here is something you can ask your dealer,why didnt they tell you that there is a TSB for this problem?Dealers amaze me how they act stupid.Here is your TSB,and ask them to do it:
Make : JEEPModel : LIBERTYYear : 2008Manufacturer : CHRYSLER GROUP LLC Service Bulletin Number : 07049Date of Bulletin : NOV 20, 2007NHTSA Item Number : 10023638 Component : ELECTRICAL SYSTEM: SOFTWARESummary :
UNABLE TO SHIFT OUT OF PARK OR FRONT WIPERS AND HEADLAMPS DEFAULT TO (ON).
richd is offline   Reply With Quote Quick reply to this message
Unread 10-27-2010, 04:45 PM   #3
SuperRliBerty
2008 KK Liberty
My ESP came on and could not be turned off, and went into limp mode where I could not drive over 45mph. Limped home, parked disconnected the battery, took me less than 10 seconds to do with the wing nut mod. (pictures below).
2008 Sport Liberty
Cold air intake*Trush (magnaflow) turbo muffler* Hypertech power program*
Hood Prop mod. Battery Quick Release mod.
Resonator removed (sounds like a V8 on start up)
SuperRliBerty is offline   Reply With Quote Quick reply to this message
