Widest (not tallest) Tire Without Lift? - JeepForum.com
post #1 of 28 Old 01-22-2013, 05:05 PM Thread Starter
My2Sense
Hi,
I'm looking to buy a set of Toyo Proxes S/T II tires for my 2011 Renegade. The need is for mostly for on-road driving with occasional sandy soil type excursions (in Florida).
As pictured, the previous S/T tires in size 275/60R16 were mounted without issue on my ex 2004 Renegade.
Anyone know if I'll encounter a problem? My concern is the rear trailing arms. They're a bit close but I'm only increasing the section width by about 1.5 inches (.75 per side).
Am I missing something?
Thanks!
Overall diameter of the stock 235/70R16 tire is 29" and the width is 9.5" according to Tire Rack.
http://www.tirerack.com/tires/tires....omCompare1=yes
The 275/60R16 Toyo's are 28.9 and 10.9 respectively.
http://toyotires.com/tires/pattern/p...l-season-tires
My2Sense is offline
post #2 of 28 Old 01-22-2013, 05:39 PM
AtTheHelm
I can't see how those wouldn't rub on the pinch weld and wheel well liner in the front.
AtTheHelm is offline
post #3 of 28 Old 01-22-2013, 05:50 PM Thread Starter
My2Sense
On which? Or both? I never had any rubbing problems on the '04. But then, my off-roading was mostly low-speed.
My2Sense is offline
post #4 of 28 Old 01-22-2013, 08:49 PM
AtTheHelm
On both, granted i'm not a kj owner but i would think a 275mm wide tire would rub like crazy.
post #5 of 28 Old 01-23-2013, 07:35 AM
huntb
2008 KK Liberty
I don't even know if those will fit on the stock rim
huntb is offline
post #6 of 28 Old 01-23-2013, 06:09 PM
tommudd
2004 KJ Liberty
have to remember that the KKs sit about an inch lower from the factory than the KJs did
So there lies one issue possibly
MUDD'S MOTORSPORTS
04 KJ JBA 4 INCH COILOVER LIFT
03 KJ JBA 2.5 TOTAL CONTROL LIFT
tommudd is offline
post #7 of 28 Old 01-23-2013, 06:40 PM Thread Starter
My2Sense
I was looking at this reference:
So, only a hair wider.
That's a good point, however, these 275s are actually shorter in height than the stock Goodyears.
It's the tire's width that I'm questioning.
My2Sense is offline
post #8 of 28 Old 01-23-2013, 06:45 PM
tommudd
2004 KJ Liberty
Just reading through that WIKI
so much misinformation in it that , ...well its not even funny
MUDD'S MOTORSPORTS
tommudd is offline
post #9 of 28 Old 01-23-2013, 07:49 PM
_benjammin
2012 KK Liberty
Do Spidertrax spacers enable a wider tire?
_benjammin is offline
post #10 of 28 Old 01-23-2013, 07:54 PM
tommudd
2004 KJ Liberty
That would make it worse
MUDD'S MOTORSPORTS
tommudd is offline
post #11 of 28 Old 01-23-2013, 07:57 PM
_benjammin
2012 KK Liberty
Ahhh...thanks for the reply. I had/have no clue about back spacing, clearance, etc.
post #12 of 28 Old 01-23-2013, 08:02 PM
tommudd
2004 KJ Liberty
By pushing the tire out further it changes the arc, thus making it hit the wheelwell when turning
MUDD'S MOTORSPORTS
tommudd is offline
post #13 of 28 Old 01-23-2013, 08:09 PM
_benjammin
2012 KK Liberty
Got it. Makes sense, extend the"radius" and the tire travel/arc would be longer/bigger. Thanks again.
post #14 of 28 Old 01-29-2013, 09:58 AM
LibertyRS
2012 KK Liberty
I have 275/45/20 on my jeep, I rub when im about to be a full lock, doesn't help that 1.5 inches lower than normal either. I think you'd be fine. My next set of tires are going to wider
2012 Jeep KK
Stormtrooped
ZZzz
LibertyRS is offline
post #15 of 28 Old 10-05-2013, 07:57 PM Thread Starter
My2Sense
Okay, I went ahead and bought the TOYO Proxes S/T II as planned (275/60R16). What a difference! The appearance and, more importantly, the ride has improved so much. Also, they're very quiet e.g. elevated highway speeds result in wind noise only (mostly from the door mirrors).
And... get this! Absolutely no rubbing whatsoever. Anywhere. Even when jumping on the brakes with the steering at full lock. Note: Everything is still stock; wheels, no spacers and no lift.
Lastly, these tires have the same outside diameter as the OEMs so no changes in the speedo, NAV, nada.
I'm happy!
My2Sense is offline
