Where to find 4.10 gears - JeepForum.com
post #1 of 22 Old 07-05-2013, 07:55 PM Thread Starter
shawnicles
I am having a hard time finding some new gears.
It seems like JBA has the rear but not the front?
Also I was told to get a kit so that it comes with a bunch of other things to fully replace it.
Where is a good place to buy them?
shawnicles is offline
post #2 of 22 Old 07-06-2013, 03:38 AM
Ted15
2010 KK Liberty
The front is the same as a JK has.
2010 KK Sport, Detoures Knucklebone & backbone, smittybilt XRC 10, rigid led lights, R/L sliders & rack, cb, EMT2, R/K 15x7, OME, JBA, mopar skids & hitch, headlight covers, 4.10's and TruTracs
Ted15 is offline
post #3 of 22 Old 07-06-2013, 03:57 AM
Ted15
2010 KK Liberty
If you've never done a ring and pinion before, it's probably better to have someone else do it or have them show you how. There are special tools needed and it can be a little tricky. Definatly not plug and play.
The Truetracs are AWESOME. I can't wait to try them out off road. They aren't lockers but they are very good limited slips. With the design of our traction control system, they should compliment it very well.
If the link works, this is a video of how it operates.
Ted15 is offline
post #4 of 22 Old 07-06-2013, 08:20 AM Thread Starter
shawnicles
Yeah I wasn't planning on doing it myself.
What websites did you buy yours from?
post #5 of 22 Old 07-06-2013, 10:52 AM
Ted15
2010 KK Liberty
I took it to the 4WD hardware store in Columbiana Ohio had them do it. Bought the parts there as well. Not sure but they may not have set the pinion properly, still trying to confirm the whining noise. It could be possible that the tires are turning at different rpm's due to uneven wear and inflation heights.
Ted15 is offline
post #6 of 22 Old 07-06-2013, 11:43 AM
Gyrocaptain
2007 KJ Liberty
Find a good tranny shop and get them to order one.
they are hard to find online in Canada,and duty from the US will be a killer.
When I had mine done back in March, there supplier only had 2, and both were in Calgary.
And make sure they order for a D30a/super 30,not the standard D30.
Gyro
Gyrocaptain is offline
post #7 of 22 Old 07-06-2013, 01:56 PM
Ted15
2010 KK Liberty
Gyro
Reverse cut, high pinion. Like the JK, same parts.
Ted15 is offline
post #8 of 22 Old 07-06-2013, 02:25 PM Thread Starter
shawnicles
Even though I live in Calgary I can still buy in the states. I just got back from montana where I picked up a bunch of stuff for my car and my hypertech programmer and saved a bundle on my car insurance! Eerrrrr I mean duty.
So that's not a big deal. Any sites that you know about would be great, I would rather order it online than at a shop. And get someone to install it.
What are the extra bushings and stuff one of my friends were talking about ? It had a name and said you migjt as well replace it while the whole thing was open.
post #9 of 22 Old 07-06-2013, 03:01 PM
Ted15
2010 KK Liberty
You need a master rebuild kit for each axle, ring and pinions and whatever lockers/limited slips that you want. Some decent conventional (Dino) oil. It would also be a good time to replace that stamped cover on the rear. If you get one with a drain plug you won't have to remove the cover every time you change the oil.
The master rebuild kit comes with bearings and shims for the installation. What do you want to do? Just gears?
Ted15 is offline
post #10 of 22 Old 07-06-2013, 06:05 PM Thread Starter
shawnicles
That's what I couldn't think of the master rebuild kit. Thanks for that.
I want to do the gears and add some limited slips diffs in. I dont really want full lockers yet.
post #11 of 22 Old 07-06-2013, 06:21 PM
Ted15
2010 KK Liberty
I've heard great things about the trutracs in the KK and having them now I believe them. I haven't tested them off road other than some old township roads around loudenville, and pulling my camper on soft terrain. They are impressive. My original plan was to put a Detroit locker in the rear but the shop talked me out of it because of the camper.
Ted15 is offline
post #12 of 22 Old 07-08-2013, 11:00 AM Thread Starter
shawnicles
Hey Ted, could you check your invoices maybe and get some part #'s for me? I'm having a hard time finding someone to supply these.
post #13 of 22 Old 07-08-2013, 11:39 AM
Ted15
2010 KK Liberty
I have an old quote;
2010 JEEP LIBERTY (KJ) SPORT
EAT912A553 1 1 0 0.00 618.520 T
CHRY 8.25inTRUETRAC 29SPL C-CLIP 1997UP
EAT912A585 1 1 0 0.00 410.990 T
D30 TRUETRAC 3.73U 27SPL
G/22-2029-410 1 1 0 0.00 198.941 T
CHRY 8.25in 4.10 R&P
G/235-2029 1 1 0 0.00 78.392 T
CHRY 8.25"
ALYD30410RJK 1 1 0 0.00 289.397 T
D30 REV 4.10 RING/PINION 07-10 JK
G/235-2050 1 1 0 0.00 109.809 T
DANA 30 FRONT JK
SHO4-1025-1 1 1 0 304.00 0.00 14.950 T
INSTALL RING & PINION FRT DANA 28-35 OR EQUIV
OILDISP 12.50 T
OIL DISPOSAL FEE
SHO4-1026-3 1 1 0 344.00 0.00 17.940 T
INSTALL RING & PINION REAR DANA 44-60 OR EQUIV
Hope that helps. Keep in mind that most shops think the KJ and the KK are the same, not so. The inside of the KK front differential is the same as the JK. 4WD Hardware calls the KK a KJ. They just don't even pay any attention the liberty, very few shops do yet you can get a crapload of stuff for a Suzuki Grand Vitra. I just done understand.
Ted15 is offline
post #14 of 22 Old 07-17-2013, 11:36 AM Thread Starter
shawnicles
That quote actually did work.
For anyone else looking:
EAT912A553 - Rear Limited Slip Dif
EAT912A585 - Front Limited Slip Dif
G/22-2029-410 - Rear Ring and Pinion
G/235-2029 - Rear Master Rebuild Kit
ALYD30410RJK - Front Ring and Pinion
G/235-2050 - Front Master Rebuild Kit
SHO4-1025-1 - Oil (forget the grade)
SHO4-1026-3 - Another Master Rebuild Kit we didn't need.
Price $1896 USD with free shipping to US with UPS.
post #15 of 22 Old 07-17-2013, 12:40 PM
Ted15
2010 KK Liberty
Sorry, I forgot to decode the quote. Add $350 per axle for labor. 8 hrs each. The limited slips are Detroit trutracs.
Ted15 is offline
