I removed the under dash courtesy lights and swapped them with some LEDs. Here's a quick install write up.
First step is always to disconnect the battery.
Next I took off the cover to access the lights. Remove the two plastic flathead screws.
Next I unscrewed the courtesy light screw and snipped the wires.
Next I put butt connectors on the wires from the LEDs. Attach those butt connectors to the wires you snipped. Black is ground, yellow is positive.
