U Connect not working? - JeepForum.com
post #1 of 6 Old 09-22-2012, 08:06 AM Thread Starter
tbenson
This was working fine, now nothing?
I had this issue once before, the battery disconnect method worked as a fix that time, this time, no such luck?
Outside of visiting the Dealer, any suggestions?
tbenson is offline
post #2 of 6 Old 09-22-2012, 08:09 AM Thread Starter
tbenson
Oh yeah, a "U Connect phone is not available" is the bubble displayed across the screen, or something similar to that...
tbenson is offline
post #3 of 6 Old 09-22-2012, 02:25 PM
MyJKU14
2014 JK Wrangler
Make sure your bluetooth is available on your phone. Sometimes mine gets turned off and I get that message. Also try re-pairing the phone to the car, that's helped me sometimes.
MyJKU14 is offline
post #4 of 6 Old 09-23-2012, 10:50 AM Thread Starter
tbenson
Bluetooth is on.
The system will not let me re-pair the phone, it will not enter the menu that allows phone pairing?
tbenson is offline
post #5 of 6 Old 09-24-2012, 12:03 AM
Zambonie
2012 KK Liberty
When you press the U-Connect button.. what happens?
Also... ensure that you're connected via Bluetooth after the car is started. There has been many times, that I will have Bluetooth on and U-Connect would not work. I had to manually go into the phone's Bluetooth settings and actually connect it. (if it's still paired, it should display the name in your paired list, where you can connect it)
Zambonie is offline
post #6 of 6 Old 09-25-2012, 10:02 AM Thread Starter
tbenson
I can press the U-Connect, or the Voice Command button, and still, "U-Connect phone not available" bubble displays, every time, no option menu is available at all.
Yes the same here, manually connecting the phone is necessary at times.
tbenson is offline
HELP: iPod Direct Connect Integration Cable hook up SquallSailor KK Liberty Forum 2 07-27-2012 03:44 AM
My $6.85 I-Connect phone mod. jonrjen KK Liberty Forum 5 04-03-2012 08:08 PM
a/c stoped working capsfloyd KK Liberty Forum 8 09-19-2011 12:16 PM
Uconnect connect to iPod? iviario311 KK Liberty Forum 1 09-03-2011 09:26 AM
U Connect slipperybrain KK Liberty Forum 12 02-05-2011 08:14 AM
