Twin cluch automatic transmission in 2010 Liberty? - JeepForum.com
post #1 of 5 Old 04-07-2011, 03:17 PM Thread Starter
royhkeith
2010 KK Liberty
Somewhere I remember reading that the 2010 Liberty 4-speed auto transmission is a twin clutch design. Is this so?
1) I read that a twin clutch is much smoother and faster shifting due to the fact that one clutch handles odd numbered gears (1 & 3) while the other clutch handles even numbered gears (2 & 4). This way the next gear is already engaged before the opposite clutch engages.
2) I read that this reduces MPG somewhat.
3) My 2010 and previous 1997 Grand Cherokee both have 4 speed automatics. The 1997 would shift smoothly to 4th gear and then the torque converter would firmly lock-in. If a slow down in speed required a lower gear to accelerate, I was never sure when the torque converter would unlock or when a shift to the next lower gear would occur. The change might occur long after easy pedal pressure had been applied, resulting in an unexpected RPM increase and a rough gear shift. The 2010 RMP will increase with no feeling of a rough shift of any kind. This results in a marked improvement in smooth shifting especially when resuming speed after a slow down due to traffic or a turn. But, the torque converter lock-up is slow to occur compared to the 1997. It seems to have 2 RPM decreases between 4th gear and final converter lock-up unless I ease my foot off the accelerator. Is this due to the Twin clutch design?
2010 Liberty Renegade
royhkeith is offline
post #2 of 5 Old 04-07-2011, 03:59 PM
tjkj2002
2002 KJ Liberty
You have the 42RLE auto trans in your '10 KK,just a mordern version of the A604 trans that began in the 1st Chrysler minivans.
tjkj2002 is offline
post #3 of 5 Old 04-07-2011, 05:58 PM
allskiing
I tell you what....If the kk had a six speed I would be very happy.
allskiing is offline
post #4 of 5 Old 04-07-2011, 09:32 PM
BloodyShadow23
2008 KK Liberty
I have seen 2008 KK's have 5-speed manuals but I think that is only for international KK's. Shame
2008 Liberty Sport - Chrome Grill, K&N CAI,
BloodyShadow23 is offline
post #5 of 5 Old 04-07-2011, 09:41 PM
richd
2008 KK Liberty
Some 08 KK had a 6 speed(manual) here in the U.S.:
2008 Jeep Liberty
The six speed manual and four-speed automatic transmissions continue. The standard 3.7-liter SOHC V-6 engine produces 210 hp (157 kW) @ 5,200 rpm and 235 lb.-ft. (319 Nm) of torque @ 4,000 rpm. Fuel economy (with the standard - and only - V6) was improved by about 2 mpg with either stick or automatic; it is now an estimated 16 city (18 mpg using 2007 EPA standards), and 22 mpg on the highway (23 mpg based on 2007 EPA standards).
richd is offline
2010 Liberty transmission cooler. Krieg KK Liberty Forum 6 07-21-2017 10:29 AM
2010 Liberty in the shop... z06boy KK Liberty Forum 5 11-04-2010 09:35 PM
Little help with 2010 Liberty alex725 KK Liberty Forum 16 11-04-2010 09:31 PM
2010 Jeep Liberty with Sun Slider vs. 2010 4dr. Unlimited ?? britt22 KK Liberty Forum 20 10-08-2010 12:49 PM
2010 Liberty "Renegade" with Transmission Vibration davebwi KK Liberty Forum 4 08-09-2010 11:39 AM
