Trick to get to oil filter? - JeepForum.com
post #1 of 16 Old 11-02-2013, 10:18 AM Thread Starter
manny85
Has anyone else changed their own oil on the KK? I've got a 2012 and it's way way up at the front and top of the motor? Is there a easy way to get to it? I pulled off my skid plate and that did not help much. I got it of and put a new one on but there is very little room and you need a super skinny long arm. Any ideas ?
manny85 is offline
post #2 of 16 Old 11-02-2013, 10:54 AM
Ted15
2010 KK Liberty
VERY LONG extension and an oil filter socket. You can get to it from the front but it's a pita.
The last time I changed my oil, I laid under the front head first and was able to reach over my head.
2010 KK Sport, Detoures Knucklebone & backbone, smittybilt XRC 10, rigid led lights, R/L sliders & rack, cb, EMT2, R/K 15x7, OME, JBA, mopar skids & hitch, headlight covers, 4.10's and TruTracs
Ted15 is offline
post #3 of 16 Old 11-04-2013, 11:49 AM
Babaki
2012 KK Liberty
the only way i could get to it was from the front as well. i have a filter wrench and long extension but i dont get how that would help. i just reach my arm straight in through the fan shroud and grab it.
Babaki is offline
post #4 of 16 Old 11-04-2013, 08:42 PM Thread Starter
manny85
Thanks Guys.
manny85 is offline
post #5 of 16 Old 12-03-2013, 07:59 PM
quadracer512
2009 KK Liberty
Stupid Dodge! I wasted quite a bit if time trying to size up that oil filter. The only way i could get to it was from the front, only after I drove the front up on ramps. Again, stupid Dodge! So many places around that engine block they could have put it, but nooooo.
quadracer512 is offline
post #6 of 16 Old 12-04-2013, 08:36 AM
Havoc3D
2011 KK Liberty
Wow...I always did my own oil changes on previous vehicles, but it sounds like on this it might be worth it to buy my own oil and pay the local garage for their $13 oil change. Just give them my bottle of royal purple and a filter and let them have at it....
Havoc3D is offline
post #7 of 16 Old 12-04-2013, 08:52 AM
quadracer512
2009 KK Liberty
Just make sure you look to see what filter you do have. I at first had Walmart do my oil change. The next time, i did it. The filter looked suspect as in I'm not sure they changed it, dye to the difficulty.
post #8 of 16 Old 12-04-2013, 10:41 AM
Slayers
2008 KK Liberty
Just did my this last weekend.
Was not as hard as everyone says to take off I did struggle to put back on but it was getting dark at the time and I was struggling to find the right spot.
Slayers is offline
post #9 of 16 Old 12-04-2013, 05:44 PM
Afoos1
2010 KK Liberty
When I changed mine I just broke my forearm to give me another elbow. That gave me enough joints to be able to manipulate the filter. Actually I was just able to reach it but not without scrapes on my arms from the air dam. Definitely could have been better designed.
Afoos1 is offline
post #10 of 16 Old 12-04-2013, 09:22 PM
Poncherello
2010 KK Liberty
A while back I inquired about an oil filter relocation kit, but had received some negative feedback about it. I agree the oil filter is definitely not at the best spot. I under if it is an easier or difficult on the new Cherokees and Grand Cherokees?
When you get knee-deep in a situation, floor it.
Poncherello is offline
post #11 of 16 Old 12-04-2013, 10:18 PM
tjkj2002
2002 KJ Liberty
The oil filter has been in the exact same spot on the 3.7 since it 1st came out for the '02 KJ,and the same spot in 4.7 V8's since '99.One of the easier filters to get to them some.
The new 3.6's and 3.2's(assuming since it's a baby 3.6) use a canister filter located on the top of the engine.
tjkj2002 is offline
post #12 of 16 Old 12-05-2013, 03:05 AM
Ted15
2010 KK Liberty
I don't know why there was negative feedback, people have been relocating oil filters for a long time. I looked at doing that but couldn't find a good way to mount the part that replaces the OEM filter, it's really tight right there.
Ted15 is offline
post #13 of 16 Old 12-06-2013, 10:33 PM
Poncherello
2010 KK Liberty
Something about possible leaks between the lines and fasteners and the oil pump not being able to sufficiently pump oil through the motor with the extra line. Not certain how true both of those factors are.
post #14 of 16 Old 12-07-2013, 05:15 AM
josworth
2010 KK Liberty
That is what I was thinking as well. I am definitely going to try and find out. After performing my first oil change that was exactly the first thing that crossed my mind. "Wonder if they make a relocation setup for this". I think it is great that they went the "Mercedes" route on the 3.6 with a cartridge filter. My wife has a R350 and doing an oil change on that is a breeze, even with a lower panel to remove to get to the drain plug. Plus you never have to worry about the filter gasket sticking to the engine. Only thing that sucks there is that little old V6 takes 8 quarts of synthetic oil and a Mercedes oil filter cartridge.. On a good day an oil change on that costs me $80 in parts and fluid.
josworth is offline
post #15 of 16 Old 12-07-2013, 05:39 AM
Ted15
2010 KK Liberty
IMO, leaks aren't an issue it it's installed properly with quality hoses. The flow issue shouldn't be a problem either if the hoses are large enough to allow unrestricted oil flow. The oil pump is a positive displacement pump, the little bit of increased travel to the filter shouldn't matter just be sure to add the proper amount of oil to fill the filter assembly.
Ted15 is offline
