Transmission Slow To Engage First Thing in the Morning - JeepForum.com
post #1 of 16 Old 08-26-2010, 06:41 AM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
So my house is on a hill. When i leave in the morning and i back out of the driveway i drive up the hill. So i back out, cut the wheel, put it in drive, wait a second then try to go but the vehicle doesn't move until the RPM is about 2000 then it then lazily engages then goes on its way. This is the only time this happens. Is it because the transmission fluid isn't warmed up and because I'm on a hill? Since there is not dipstick i cant even check the fluid. tjkj2002 where are you? lol
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #2 of 16 Old 08-26-2010, 10:59 PM
richd
2008 KK Liberty
How many miles on this.I know there is no dipstick,but fluid level would be the first thing to check.If you havent seen any leaks,then assume its OK.Next could be restricted filter,bad or leaking valve body,transmissiom pressure line,shift solenoid.You might need a trip to the dealer.
richd is offline
post #3 of 16 Old 08-27-2010, 03:45 AM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
34K, Ya i just hate having to wait for them to look at it, and they always find nothing wrong.
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #4 of 16 Old 08-27-2010, 10:16 AM
Nosights
Definitely a dealer only serviceable item (well shops such as mine can check as well but they have to be set up to service these newer Chryslers (need a StarScan and a trans dip rod).
I would have the fluid level checked as it sounds like it is starved for oil. What happens when you set in park or neutral for a minute and see if then it will take off normally once you have sat on level ground for a minute first. Also, does it only do it before warm up or will it do it when you do the same thing after full warm up?
Dan
Nosights is offline
post #5 of 16 Old 08-27-2010, 10:47 AM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
I remote start my KK for about 2 minutes before i leave, but my driveway is pretty flat, so when i put it in reverse to back onto the hill it does that fine. But when i put it in drive from reverse(At this point I'm on the hill) it will not go and i need to put the RPM up to about 2000 and it slowly will engage and go. I know its not Hill start Assist because i know how that feels. Ill try it when i leave work today, ill pull in the driveway, put it in park, back out and put in drive and see what happens and let you know.
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #6 of 16 Old 08-27-2010, 10:48 AM
swtrucker
2011 JK Wrangler
Sounds like a dirty filter.
Originally Posted by CCGRUNT0331 View Post
Last night I was staring at her basking in the moon light, I glanced at her, she grinned back and I thought... Man! I Freakin Love My Jeep!
swtrucker is offline
post #7 of 16 Old 08-27-2010, 10:51 AM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
I wonder if this will be covered under my 3/36K or my Lifetime Powertrain. Hopefully. I know the filter is like 30 bucks but i bet the tranny will have to be drained etc to replace it.
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #8 of 16 Old 08-27-2010, 11:57 AM
richd
2008 KK Liberty
The manual calls for fluid and filter change at 60k severe service and 120k normal service so this could be under warranty.34k seems to early for this to happen,unless it is just low on fluid.
richd is offline
post #9 of 16 Old 08-27-2010, 12:42 PM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
ya cuz i change all my fluids under severe and i knew i was only 1/2 way for the tranny. It seems like its low the way its acting but i don't see any fluid on the ground at home or work
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #10 of 16 Old 08-27-2010, 05:07 PM
richd
2008 KK Liberty
It looks like you wont have a choice but to bring it into the dealer,like someone mentioned you need starscan and special dipstick to check fluid.
richd is offline
post #11 of 16 Old 08-27-2010, 09:45 PM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
So when i got home i pulled in the driveway, put it in park, put it in reverse and put it in driveway just like when i leave in the morning but the transmission engaged just fine. So i went in the house for like 1 hour, came out to leave and it was slow to engage but not as bad as when it sits over night. I have to drop it off monday night with the dealer.
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #12 of 16 Old 08-31-2010, 05:10 PM
richd
2008 KK Liberty
Did you get your KK back?What was the problem?
richd is offline
post #13 of 16 Old 08-31-2010, 07:55 PM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
Dropped it off Monday night for Tuesday and the dealer said they needed it for one more day, they probably didnt look at it yet. So hopefully they will call tomorrow and i can go get it, then ill post up whatever it is they found or more likely didnt find.
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #14 of 16 Old 09-02-2010, 05:36 AM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
As i said ill post the lack of problems they found. They said the fluid was fine and they were unable to replicate the issue. They put the transmission into relearn and said to see if it improves. This morning it did not feel sluggish so we will see what happens.
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #15 of 16 Old 09-02-2010, 01:07 PM
richd
2008 KK Liberty
I hope it works out.I hate dealers when they say they cant replicate the issue.Good Luck.
richd is offline
Transmission and Acceleration Question rl1856 KK Liberty Forum 6 08-20-2010 07:49 AM
2010 Liberty "Renegade" with Transmission Vibration davebwi KK Liberty Forum 4 08-09-2010 11:39 AM
Drone hesitation or in 3rd gear from the transmission onegoodpunk KK Liberty Forum 3 07-16-2010 09:34 AM
Odd thing in 4 wheel drive bigcreekdad KK Liberty Forum 4 01-08-2010 05:37 PM
