Transmission issues on a 2009 Jeep Liberty Limited - JeepForum.com
post #1 of 11 Old 11-10-2010, 04:29 PM Thread Starter
csell
2014 WK
Has anyone been having any issues with the transmission on a 2009 Jeep Liberty? Mine's an automatic that makes weird noises when it tries to shift it's self into neutral or some times when it tries to down shift. The noise sound like a gun going off inside the transmission. I have taken it to the dealer multiple times but they can't find anything wrong with transmission or hear it act up. The weird part is that it doesn't do it every time .... so it's been impossible to show it to the dealer when it's acting up. Does anyone have ideas on how I could fix this problem.
csell is offline
post #2 of 11 Old 11-11-2010, 02:06 AM
marlon_jbt
2010 KK Liberty
Fast clicking sound?
That's normal, all Chrysler transmissions do that. That's why they can't find anything wrong.
Red Jeep Club member # 264
marlon_jbt is offline
post #3 of 11 Old 11-11-2010, 08:11 AM Thread Starter
csell
2014 WK
The transmission doesn't make a clicking sound. It more like a bang or somebody driving a stick that doesn't know how to shift very well.
csell is offline
post #4 of 11 Old 11-11-2010, 02:03 PM
marlon_jbt
2010 KK Liberty
Well it does make a clicking sound.
The transmission does make a loud "bang" when parked on a hill. That too is normal, is that the case here? If you're on flat ground then you're not going to be able to reproduce the noise.
post #5 of 11 Old 11-11-2010, 08:04 PM
Elt31987
Elt31987's Avatar
2008 KK Liberty
That's happened to me a few times. I've kind of learned how to avoid it with driving habits. The TSB i had done might have helped too
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #6 of 11 Old 11-12-2010, 07:25 AM
SCT100
2010 KK Liberty
Well, my company has had a small fleet of Libertys since they were introduced, and I can tell you that most of them do the same thing. They don't "bang" into gear when driving normally, but will do so under certain circumstances. Honestly, these trannys aren't that sophisticated, and it doesn't really seem to hurt them. It seems to be more of a lack of refinement. That said, we have had a few trannys die on us, but we use the Libs off-road quite a bit. They lead hard lives.
If yours does this on every shift or downshift, something may be wrong. One other thing to check would be your shift linkage. It may be misaligned, and may be causing the bang into neutral.
SCT100 is offline
post #7 of 11 Old 11-19-2010, 11:11 AM Thread Starter
csell
2014 WK
I would like note that the problem generally happen when driving and not when parking. It also happens at slow and fast speeds. I am going to get the shift linkage looked at thanks for the idea SCT100
csell is offline
post #8 of 11 Old 05-06-2015, 05:04 PM
UJK4678
same issue
I've had the same issue and have taken it to the dealer 10 times the past 8 months, I know but no other dealer wants to work on a warranty issue another dealer has touched
UJK4678 is offline
post #9 of 11 Old 05-06-2015, 05:06 PM
UJK4678
I'm experiencing the same issue. csell what was your findings?
UJK4678 is offline
post #10 of 11 Old 05-08-2015, 02:22 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
UJK4678,
Did the dealer provide you with a recommended fix from their diagnosis? Were they able to duplicate the concern?
JeepCares is online now
post #11 of 11 Old 05-08-2015, 08:44 PM
cutprogram
My 2008 had a clicking noise.It was a constant click that almost sounded like lifter tick. Was mis-diagnosed as a starter. Turned out to be the parking pin had sheared off and cut into my input shaft and acted like a lathe bit is what I was told. I was never able to view the parts though.Trans needed a whole rebuild. Less than 50,000 kms it needs another rebuild. That is happening next week.
cutprogram is offline
2009 jeep liberty - wont start / wont even crank aimetti KK Liberty Forum 38 02-19-2016 10:46 AM
Help: jeep liberty 2009 8" ROOF antenna NEEDED bobbarto KK Liberty Forum 25 09-09-2011 06:52 AM
2009 Jeep Liberty Issues JBWrangler2000 KK Liberty Forum 10 09-29-2010 10:55 AM
Inner tie rod Jeep Liberty 2009 KK suzuki_gixxer KK Liberty Forum 15 09-27-2010 03:30 AM
Prices Paid for 2009/2010 Liberty Limited britt22 KK Liberty Forum 10 06-14-2010 01:15 PM
