Transmission Cooler - JeepForum.com
post #1 of 12 Old 01-04-2011, 11:01 AM Thread Starter
theonlyMcG
2008 KK Liberty
Transmission Cooler
So I have the 08 Sport that didn't come with the towing package. Since buying it I have put on the hitch and the wiring harness and before I actually tow anything I want to put a transmission cooler on it. What do you guys recommend as far as transmission coolers go? I was on etrailer and saw that there were some options but was wondering what experience you guys had with different options.
theonlyMcG is offline
post #2 of 12 Old 01-04-2011, 12:57 PM
tjkj2002
2002 KJ Liberty
Unless you have a manual trans you already have a trans cooler,standard on all KK's.Now it's a stand alone cooler that does have a hard time controlling temp spikes that can be seen with towing and offroading.
The best setup is to have a in-radiator trans cooler then looped to a AUX trans cooler before returning to the trans.Sadly there no option for a in-radiator trans cooler for a KK.
tjkj2002 is offline
post #3 of 12 Old 01-04-2011, 07:04 PM
SuperRliBerty
2008 KK Liberty
The transmission cooler on the KJ and KK is very inefficient. this is a pic of the trans cooler on my KK. Only one row of cooling fins
2008 Sport Liberty
Cold air intake*Trush (magnaflow) turbo muffler* Hypertech power program*
Hood Prop mod. Battery Quick Release mod.
Resonator removed (sounds like a V8 on start up)
SuperRliBerty is offline
post #4 of 12 Old 01-04-2011, 07:08 PM
SuperRliBerty
2008 KK Liberty
This is a more efficient way of cooling the trans fluid
2008 Sport Liberty
post #5 of 12 Old 01-04-2011, 07:25 PM
SuperRliBerty
2008 KK Liberty
An efficient way is to upgrade to a larger cooler and install a cooling fan.
2008 Sport Liberty
post #6 of 12 Old 01-04-2011, 08:31 PM
tjkj2002
2002 KJ Liberty
Now you don't want to overcool your trans,well not one in a new Jeep as the TCM will limit it going into OD and such till the fluid temps are in the normal operating range.
Oh and any KJ with the 45RFE trans has a very efficient trans cooler compared to KJ/KK's with the 42RLE trans.
tjkj2002 is offline
post #7 of 12 Old 01-04-2011, 08:40 PM
SuperRliBerty
2008 KK Liberty
for long distance, full max towing I would upgrade,
the KJ also uses a double row Trans cooler though...
2008 Sport Liberty
post #8 of 12 Old 01-04-2011, 08:53 PM
tjkj2002
2002 KJ Liberty
Not a KJ with the 45RFE trans('02 and very early '03's).
tjkj2002 is offline
post #9 of 12 Old 01-05-2011, 01:50 PM
KISSlover101
2008 KK Liberty
I installed a B&M transmission cooler in my 08 KK
EDIT: http://www.amazon.com/70268-SuperCooler-Automatic-Transmission-Cooler/dp/B000CIGE9G/ref=sr_1_1?s=automotive&ie=UTF8&qid=1294257230&sr=1-1
KISSlover101 is offline
post #10 of 12 Old 01-05-2011, 04:52 PM
SuperRliBerty
2008 KK Liberty
The "Bar" type Trans cooler is a bit more efficient than the :tube and fin" trans cooler.
This is the KJ trans cooler.
2008 Sport Liberty
post #11 of 12 Old 01-05-2011, 04:53 PM
SuperRliBerty
2008 KK Liberty
[QUOTE=KISSlover101;10733013]I installed a B&M transmission cooler in my 08 KK
After the install did you check the fluid level?
2008 Sport Liberty
post #12 of 12 Old 01-05-2011, 07:05 PM
tjkj2002
2002 KJ Liberty
The 45RFE KJ's use a in-radiator trans cooler,better then any stand alone cooler.
tjkj2002 is offline
Liberty Transmission Dipstick SuperRliBerty KK Liberty Forum 4 03-18-2015 08:29 PM
2010 Liberty transmission cooler. Krieg KK Liberty Forum 3 12-06-2010 05:56 PM
Transmission and Acceleration Question rl1856 KK Liberty Forum 6 08-20-2010 08:49 AM
Drone hesitation or in 3rd gear from the transmission onegoodpunk KK Liberty Forum 3 07-16-2010 10:34 AM
Tranny Cooler x96mnn KK Liberty Forum 3 02-06-2010 11:02 PM
