Tranny leaking? (automatic; 3.7L) - JeepForum.com
post #1 of 8 Old 04-06-2014, 02:14 PM Thread Starter
Oban
2012 KK Liberty
Hi y'all,
As some of you may have seen, I have another thread open to verify some part numbers for the KK towing package. Well, I am getting ready to haul a trailer from GA to IL in a month and want to make sure the KK is in shape. I just did general maintenance (brakes, plugs, filters, oil, etc).
While doing that I notice some purple fluid on the floor of my garage (couple drops, maybe 3). I searched the underside of the car and found that the tranny pan was pretty oily. I also notice a drop hanging off of the side of the pan. Surely looks like it is leaking.
The danger is: I have no clue for how long it has been like this. I did not notice anything on the floor prior. I also have not noticed any tranny issues or the like. Sometimes a hard downshift uphill, but that is not new to KK's in general.
Now, with that said, I obviously don't want to drive to IL with a trailer and potentially kill my tranny. I did some research and have a couple questions that y'all are hopefully able to help me with:
1.) I understand that the KK has no tranny dipstick anymore. Thus, replacing the pan gasket, filter and refilling the tranny is almost impossible at home as due stick is missing as well as a computer is needed to monitor temperature?
2.) I bought my KK last March (2013). It is a 2012 model. Factory certified pre owned and has the 100k miles warranty. I usually have the "harder" maintenances jobs done by my local mechanic which I trust and not at the stealership, but in this case I figured it would be a warranty job? Any ideas?
3.) Do you guys have any other suggestions how I should approach this matter? The tranny has not been touched by me or any mechanic as I understand the fluid is a "lifetime" fluid. So to me this is clearly a warranty issue / defective seal.
Another idea I had was that I could torque down the pan bolts? I have a torque wrench and all, but I am not sure as to whether this would be actually a fix or just temporary? Any suggestions?
Thanks in advance. I appreciate all the help I can get on this.
-Oban
2012 Jeep Liberty KK, 4x4, Mopar Hitch, Hood Lift Strut Mod, OME Lift, Bilstein Shocks
Oban is offline
post #2 of 8 Old 04-06-2014, 04:47 PM
RENE65
2008 KK Liberty
Any leaks coming from higher up will likely end up around the pan.Make sure to inspect higher up for any oily signs, if any clean them with brake cleaner and road test and recheck to see where the leak originates from.Its not because the pan is oily that its the leak.
RENE65 is offline
post #3 of 8 Old 04-06-2014, 04:49 PM Thread Starter
Oban
2012 KK Liberty
That is a good suggestion. I will do that. In any case, should this be covered under the certified pre-owned warranty? I know the engine, trans case, tranny and all 4x4 components should be covered.
Oban is offline
post #4 of 8 Old 04-06-2014, 08:30 PM
Poncherello
2010 KK Liberty
Originally Posted by Oban
Hi y'all, As some of you may have seen, I have another thread open to verify some part numbers for the KK towing package. Well, I am getting ready to haul a trailer from GA to IL in a month and want to make sure the KK is in shape. I just did general maintenance (brakes, plugs, filters, oil, etc). While doing that I notice some purple fluid on the floor of my garage (couple drops, maybe 3). I searched the underside of the car and found that the tranny pan was pretty oily. I also notice a drop hanging off of the side of the pan. Surely looks like it is leaking. The danger is: I have no clue for how long it has been like this. I did not notice anything on the floor prior. I also have not noticed any tranny issues or the like. Sometimes a hard downshift uphill, but that is not new to KK's in general. Now, with that said, I obviously don't want to drive to IL with a trailer and potentially kill my tranny. I did some research and have a couple questions that y'all are hopefully able to help me with: 1.) I understand that the KK has no tranny dipstick anymore. Thus, replacing the pan gasket, filter and refilling the tranny is almost impossible at home as due stick is missing as well as a computer is needed to monitor temperature? 2.) I bought my KK last March (2013). It is a 2012 model. Factory certified pre owned and has the 100k miles warranty. I usually have the "harder" maintenances jobs done by my local mechanic which I trust and not at the stealership, but in this case I figured it would be a warranty job? Any ideas? 3.) Do you guys have any other suggestions how I should approach this matter? The tranny has not been touched by me or any mechanic as I understand the fluid is a "lifetime" fluid. So to me this is clearly a warranty issue / defective seal. Another idea I had was that I could torque down the pan bolts? I have a torque wrench and all, but I am not sure as to whether this would be actually a fix or just temporary? Any suggestions? Thanks in advance. I appreciate all the help I can get on this. -Oban
If you want to be safe than sorry I would say take it to the dealership let them check fluids and follow their recommendation. If any thing happens it falls on their hands and still covered under the warranty.
I towed some stuff recently, i had installed the Mopar hitch and had the dealership install the wiring and the flash. Only thing I want to do next is add the mechanical fan and a supplemental tyranny cooler,.
When you get knee-deep in a situation, floor it.
Poncherello is offline
post #5 of 8 Old 04-06-2014, 08:33 PM Thread Starter
Oban
2012 KK Liberty
But irrespective of me wanting to tow anything, shouldn't the dealer take a look at the tranny, see some fluid and be obligated to correct whatever and wherever it is leaking from? I mean it is after all not suppose to leak... right?
Now, regarding the towing, you mention something interesting... something about a flash? I thought I buy the receiver and the harness and I am good?
Oban is offline
post #6 of 8 Old 04-08-2014, 10:24 AM Thread Starter
Oban
2012 KK Liberty
So, quick update:
The KK is currently at the dealership. Leak was identified as the seal on the tranny side of the drive output shaft which comes from the transfer case. Small leak, but still. So the dealership is now dropping the transfer case and changing the seal.
I assume as part of the process they will hopefully also change the tranny fluid / filter / pan gasket? I guess my receipt will tell...
Oban is offline
post #7 of 8 Old 04-08-2014, 12:42 PM
lazybonz
I had the same problem with my 2012 liberty. The dealer replaced both seals on the shaft. There is no gasket on the pan, only sealant.
lazybonz is offline
post #8 of 8 Old 04-08-2014, 12:45 PM Thread Starter
Oban
2012 KK Liberty
Seems to be a quality control deficiency in the 2012 model year?
Oban is offline
