Trailer wiring harness - JeepForum.com
post #1 of 5 Old 04-29-2013, 05:58 PM Thread Starter
bullettm
I have a 2011 Liberty Jet. I installed the hitch and wiring myself about a year and a half ago. Last week I bought a boat and when I plugged the wire from the trailer into my hitch, I popped the fuse attached to the power wire next to the battery. The 4 prong plug on the boat trailer was pretty corroded so I replaced it along with the fuse by the battery but now the trailer lights don't work right. One light constantly stays on whether the key is in the ignition or not and the other one doesn't work at all. I tried plugging in my atv trailer and its the same thing, but opposite lights. Does anyone know whats wrong here? Thanks in advance
bullettm is offline
post #2 of 5 Old 04-30-2013, 01:53 AM
Drednot
Can we assume that the ATV trailer worked correctly for the last year?
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35@3.07
12 Cherokee 4x4,3.7L,42RLE/MP1522, D30M/8.25@3.73
Emission test=YES
"Non Vi Sed, Arte"
Drednot is online now
post #3 of 5 Old 04-30-2013, 06:36 AM
huntb
2008 KK Liberty
Did you install the factory wire harness or an aftermarket harness?
huntb is offline
post #4 of 5 Old 04-30-2013, 07:55 AM Thread Starter
bullettm
Everything worked fine for over a year before this. I believe the.harness is made by Curt
bullettm is offline
post #5 of 5 Old 04-30-2013, 08:30 PM
12SilverKK
Did you hide the harness is flexible plastic tubing? If not thr wires might have worn thru rubbing on the frame and then shorted out.
12SilverKK is offline
