Trail Rated? - JeepForum.com
post #1 of 13 Old 10-18-2012, 06:01 PM Thread Starter
jsou
2012 KK Liberty
Trail Rated?
What makes a Liberty Trail Rated? I recently purchased a new Liberty Sport w/Latitude package. It has a Latitude badge where the Trail Rated badge would normally be. It has 4WD Low and I believe the Select Trac II 4WD system.
jsou is offline
post #2 of 13 Old 10-18-2012, 06:12 PM
Bmxer524
2011 KK Liberty
I thought Latitude was the new Limited, well either way, I think only the KKs with 16" rims are "trail rated." So no worries its the same thing besides a missing badge and bigger rims.
Bmxer524 is offline
post #3 of 13 Old 03-15-2013, 08:24 PM
27tubguy
2008 KK Liberty
trail rated, after many many Mods.
after lots and lots of mods, it is indeed trai rated.
Richie from Boston
27tubguy is offline
post #4 of 13 Old 03-15-2013, 09:55 PM
jonrjen
2011 KK Liberty
It is all a matter of tire and wheel size. Think taller sidewall for purpose of increased traction both from sidewall grip and the ability to be deflated to a lower pressure for improved traction.
Other than that there is no difference from being trail rated.
As for the "Believe Select Trac II System" you really should verify which system you have. There are differences in how you can drive both in 4WD. It can be a very costly mistake if you don't educate yourself.
"If you have a difficult job to do....Give it to a lazy man....He'll find the easy way to do it."
jonrjen is offline
post #5 of 13 Old 03-18-2013, 10:36 AM
huntb
2008 KK Liberty
Anything over 17" wheels loses its trail rating badges
huntb is offline
post #6 of 13 Old 03-19-2013, 03:33 PM
HMNG-Liberty
2012 KK Liberty
who wants to trade their 18" chrome NON Trail Rating wheels for my 16" Trail Rating Wheels? LMK.
HMNG-Liberty is offline
post #7 of 13 Old 03-20-2013, 06:39 PM
tqmonster
So what makes the Renegade trail rated? Thanks..
tqmonster is offline
post #8 of 13 Old 03-21-2013, 09:15 AM
AtTheHelm
Iirc the trail rated badge meant that it 'made' it through the Rubicon Trail in one piece, well sort of. Lots of body damage maybe, but made it eventually.
AtTheHelm is offline
post #9 of 13 Old 03-22-2013, 09:36 AM
tqmonster
That's not saying much.
post #10 of 13 Old 03-22-2013, 09:52 AM
AtTheHelm
Uh, have you seen the rubicon?
post #11 of 13 Old 03-22-2013, 02:41 PM
BettyHumpter
2011 KK Liberty
it is nasty, if you dont take the "options around stuff"
BettyHumpter is offline
post #12 of 13 Old 03-24-2013, 08:09 PM
Poncherello
2010 KK Liberty
I think with trail rating it has to do ground clearance, sidewall depth, approach and departure angles, articulation. They are different ratings with in a trail rated jeep. for example the Wrangler has a much more severe rating. I am sure it could also involve axle housing strength, torsional rigidity of the chassis. I think in a rubicon has underarmor added as part of the package as well as tow hooks. Jeep doesn't really give much information about how they trail rate becuase they want to keep their competitors in the dark.
When you get knee-deep in a situation, floor it.
Poncherello is offline
post #13 of 13 Old 03-24-2013, 08:21 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Even the bypasses on the rubicon could stop a stock jeep dead.
Luck Favours The Prepared
Anticanman is offline
