Traction Control Issue - Page 2 - JeepForum.com
post #16 of 27 Old 03-04-2011, 01:54 PM
Korruptor
I had the same issue with the TCS. It would intemittently ding and the light would illuminate and remain on while driving. Or would come on when the vehicle was started. Sometimes my cruise would not engage, or it would disengage if I had it engaged.
After a engine off/restart the light would almost always illuminate and disappear like it should. I was going to bring it in at my next oil change interval except one day I had the TCS, ESP, ABS, and the check engine light come on. I took it in the next day and they said that it was a sensor that monitors my braking. They told me that as far as the Jeep was concerned, I didn't have any brakes, so it could not use any of the systems.
Apparently this was the intermittent cause for my cruise not working, and apparently I didn't have any brake lights either because it didn't know I was braking. The part and labour cost me about $170CDN
I also had an issue, about 30,000km's earlier where the "serv4wd" light would come on for me intermittently and I took the vehicle to the dealer numerous times. Whenever they would go out the light wouldn't come on for them and they said there was no codes stored.
Finally one day it happened while I was driving by so I dropped in and left the engine running. They wound up replacing a sensor in the transfer case. The system was apparently engaging and disengaging normally even when it was saying there was a fault, and you could hear it working, but something weird was happening and it thought something was wrong.
"THIS is my BOOMSTICK! You can find it in Aisle 5 of the sporting goods department... Shop Smart, Shop S-Mart!"
Korruptor is offline
post #17 of 27 Old 03-04-2011, 02:16 PM
VMF
2008 KK Liberty
love the evil dead sig
___________________________
2008 KK limited 4x4. Inferno Red
2009 JK Rubicon. Black
2004 UCF31. Black
2001 EM2. Inca pearl
2012 UD Limited. Royal Gray
VMF is offline
post #18 of 27 Old 03-07-2011, 08:13 AM
Korruptor
Good... Bad... I'm the guy with the gun.
Groovy.
post #19 of 27 Old 03-07-2011, 08:09 PM
VMF
2008 KK Liberty
lol yeah, its one of my fav expressions
2004 UCF31. Black
VMF is offline
post #20 of 27 Old 01-05-2013, 08:15 PM
27tubguy
2008 KK Liberty
limited slip
anyone installed a locker or dana limit. slip and if so did it eff up the e.t.c??
Richie from Boston
27tubguy is offline
post #21 of 27 Old 01-05-2013, 08:18 PM
27tubguy
2008 KK Liberty
In the 8.25 rear, I meant.
Richie from Boston
27tubguy is offline
post #22 of 27 Old 07-27-2015, 05:21 PM
orionsbelt77
Traction control
I have an "11 Libby with the same stupid light and chime for traction control. I first noticed it in winter and found a large icy area in a parking lot. Even though the light was on, the traction control was working, in fact when I shut if off, it was still working. I am tempted to simply pull the fuse for the system and have it off permanently. I did change the diff oil and the light stayed off for a week, but then came back on again. When I shut off the ignition, it will reset itself and maybe stay off for days. I am not going to try to remedy this situation as there are no drivability problems and perhaps the bulb will eventually burn out....we can only hope.
orionsbelt77 is offline
post #23 of 27 Old 07-31-2015, 10:26 PM
PALiftedKK
2012 KK Liberty
I don't believe any one has posted about resetting the ecu.
to do so pull the battery over night. that's the first troubleshooting step to do. if the light is still on, go to an alignment shop. most do a free evaluation, and if not they'll charge a small fee. if alignment is on par or close to it, find a reputable dealership or mechanic to diagnose the issue.
though id be shocked if the issue was present after the battery is pulled.
PALiftedKK is offline
post #24 of 27 Old 08-01-2015, 03:49 AM
mikzor
A locker won't eff up the traction control because when locked the traction control won't have a chance to turn on.... there's no slip to trigger it.
mikzor is offline
post #25 of 27 Old 08-03-2015, 09:51 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Hello orionsbelt77,
Sorry to hear about the difficulties. If you could please PM me your contact info, VIN and preferred dealership, I could look into this further for you.
Thank you for reaching out.
Ryan- Jeep Social Care Specialist
JeepCares is online now
post #26 of 27 Old 08-09-2015, 06:30 PM
orionsbelt77
Traction control
Originally Posted by JeepCares View Post
Hello orionsbelt77,
I am not having difficulties, simply annoyances with the light and chime, as the vehicle does not display any drivability problems. I believe at this time, it is a glitch in the system and I am not concerned over it. If it develops drivability problems in the future, then I will be concerned. Until then, all is good, after all, I grew up driving rear wheel drive vehicles with no sensors or warning lights whatsoever and we got along just fine.......I do long for those days as there was less to go wrong, even though nothing was actually wrong.
post #27 of 27 Old 09-09-2015, 06:37 PM
Kylv
2011 KK Liberty
I have an '11 and I get the ABS/Brake/and TCS lights all coming on at once about every 1,500-2,000 miles. Started when there was only 12k miles on it. The lights will reset themselves immediately if you turn the ignition off and restart it. It happens intermittently and has been to the dealership multiple times for it. Every time they tell me there is no codes stored and they don't see a problem. The last time it happened I drove straight to the dealership with the lights still on, the technician plugged into the OBD port and even with the lights shining in his face told me there was nothing showing up as a fault. It happens so infrequently that I haven't bothered to throw a bigger fit about it, but it is annoying to say the least.
Kylv is offline
Keyless Entry Issue! itsgrooveybaby KK Liberty Forum 1 02-02-2011 12:20 PM
Help! 2009 Liberty Starter issue Jeff88 KK Liberty Forum 7 12-19-2010 03:21 PM
Got a rodent issue acasa521 KK Liberty Forum 1 11-21-2010 03:59 PM
weird tranny issue VMF KK Liberty Forum 3 07-20-2010 01:35 PM
KK 4x4 question (do I have an issue?) Dabitz KK Liberty Forum 2 12-20-2009 09:21 AM
