TPM System - JeepForum.com
post #1 of 7 Old 05-24-2013, 07:24 PM Thread Starter
99JeepGC47
2008 KK Liberty
TPM System
Today while driving to work my tire light started flashing, and then the dash read Check TPM System. I then tried to check the pressure in my tires and it was blank. I did a quick walk around and none were going flat.
When I left work all was fine and all my pressures were above 32 pounds. I will set them all to 35 in the morning, but is this a major problem? If it helps I just rolled over 100,00 miles.
I know were the sending units are in each tire, where is/are the receiving units at?
Thanks
99JeepGC47 is offline
post #2 of 7 Old 05-24-2013, 08:11 PM
_benjammin
2012 KK Liberty
What year? If you're sure all 4 are@32 psi you might have a bad sensor. Check your spare too.
_benjammin is offline
post #3 of 7 Old 05-24-2013, 11:37 PM
eoerikson3
2011 KK Liberty
There's a sensor in the spare?
-Oscar
Chrome may not get you home, but sometimes it looks nice.
2011 Liberty Sport
Added tow hitch, tow hooks, skid plates, foglight kit and headlight masks, remote start, chrome steps, and Cooper Discoverer A/T3 235/75R16.
eoerikson3 is offline
post #4 of 7 Old 05-25-2013, 12:54 PM
Drednot
Yeah, there is a sensor in the spare.
The main function of the TPMS is to alert you before the tire goes low enough where you would notice it. That is to prevent you from driving on a moderately low tire that builds up heat eventually blows out at high speed.
I think they start to indicate around 30 psi.
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35@3.07
12 Cherokee 4x4,3.7L,42RLE/MP1522, D30M/8.25@3.73
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
post #5 of 7 Old 05-25-2013, 04:00 PM
xxxxxxxxxxxxSmetna
Guest
2011 KK Liberty
There's only a sensor in a full size spare.
xxxxxxxxxxxxSmetna is offline
post #6 of 7 Old 05-25-2013, 04:45 PM Thread Starter
99JeepGC47
2008 KK Liberty
All have been checked and are now good. Even the spare.
post #7 of 7 Old 06-04-2013, 07:54 PM
usaretired
2008 KK Liberty
If you have the 18" chrome clad alloy wheel option, your cold tire pressure is 33 psi. The spare tire pressure isn't being received only the 4-mounted road tires. There's no reset button so you have to drive for 10 minutes above 15 mph to reset after correcting cold tire pressure. You can continuously monitor your active TPMS readings in the electronic vehicle information center (EVIC). The 4-mounted road tire readings are displayed in a submenu on the EVIC. FYI, the low pressure tire reading & road tire position flashes until the correct tire pressure is achieved. Your Owners Manual pages 357-366 covers TPMS. The tire sensor only transmits the current air pressure in the tire & will display that reading in the EVIC. When one or more sensors drop 3-4 psi after reset, the road tire position & tire PSI will flash until corrected again. Your Owners Manual pages 215-228 covers the EVIC menus & submenus. I hope this helps.
usaretired is offline
