Towing while lifted - JeepForum.com
post #1 of 6 Old 06-29-2014, 05:17 PM Thread Starter
lfhoward
2008 KK Liberty
Towing while lifted
I have a 4 inch lift and am running 30.5 inch tires, so my hitch is somewhere around 23-24 inches off the ground. I'm looking at towing a 5x8 (single axle) or 5x10 (double axle) U-Haul trailer soon, about 600 miles.
I'm thinking I might need a drop hitch. How far down should it go for a Jeep my height? Looking to get the best trailer angle to avoid sway on the highway.
Is it worth getting an aux transmission cooler? I have the HD cooling fan already.
Do you have any towing tips that apply to a lifted vehicle specifically? Of course I will use tow/haul mode, leave lots of space, keep the speed down, and plan on braking early. I've towed a trailer before, just not with a lifted Jeep.
Thanks all!
LFH
2008 Liberty Sport 4x4 Automatic
lfhoward is offline
post #2 of 6 Old 06-29-2014, 10:20 PM
Poncherello
2010 KK Liberty
I would do both. If you can stick with the single axle trailer it will also save you some money if you are driving over any toll roads or bridges. I didn't have hd cooling or a auxiliary tranny cooler - used a double axle trailer full of appliances, it ran pretty good but at around 200 miles sitting in traffic it had briefly shut down for a few secs then drove fine.
Be sure to have your fluids changed and full.
Good luck
When you get knee-deep in a situation, floor it.
Poncherello is offline
post #3 of 6 Old 06-29-2014, 10:56 PM
tommudd
2004 KJ Liberty
Lauren, I forgot to mention over on LOST, I have towed my 6 X 10 enclosed from Toledo to Boston a couple of times moving my wife, and also from Toledo to Orlando moving my nephew, plus all over Ohio moving myself. Made 23 trips so far between the old and new place in the past couple of months, 165 miles one way, fully loaded to the gills coming south
Like mentioned over there, call UHaul and ask their hitch height/ measure yours and see how much you need . Wish you were closer, I have 2 / 4 and 6 inch drops here, at least two of each one, I'd give you what you needed.
MUDD'S MOTORSPORTS
04 KJ JBA 4 INCH COILOVER LIFT
03 KJ JBA 2.5 TOTAL CONTROL LIFT
tommudd is offline
post #4 of 6 Old 06-30-2014, 07:26 AM
avatr
2012 KK Liberty
lfhoward - I can't speak to the need of a aux trans cooler. I towed the largest U-Haul enclosed trailer 1300 miles with an F150, 4.6, auto. the trailer was loaded as was the truck, to include my Harley Fat Boy. the truck did fine, however, I never pushed it. I'd gain speed on the downhill to aid in climbing uphill, and never got below 50mph.
my recommendation - make sure the rear of the trailer is level with or slightly higher than the ball. it not, then you open yourself to trailer wag. I know this from experience. load the trailer heavier in the front.
good luck with your tow.
avatr is offline
post #5 of 6 Old 06-30-2014, 08:03 AM
kew
Try to keep the bulk of the weight directly over the trailer axles. Make the trailer carry the weight not the rear axle of your liberty this alone will make the world of a difference with sway.
Depending on how much weight you anticipate carrying will determine the number of axles you will need for the trailer.
kew is offline
post #6 of 6 Old 07-06-2014, 08:43 AM
carlosburitica
2010 KK Liberty
the 6x12 needs 5 1/4" drop
and the 5x10 needs 6" drop
to have them leve and loaded with 300 pounds of thong
i have 4" as well.
i prefer the 6x12 uhaul trailer that is more stable
i have towed 4k pounds for 600 with no issues.
dual axle trailer drive better. they distribute weight better and have less sway and seem to me to have less drag. i feel my car work harder pulling single axle than a dual axle.
and recently towed a mini cooper on a car dolly for about 100 miles. total weight was close to 5k pounds, kk towed like a champ
don't have the pic with the mini on the trailer
carlosburitica is offline
