Towing capacity... - JeepForum.com
post #1 of 15 Old 12-16-2011, 08:33 PM Thread Starter
vtjeepguy
Towing capacity...
So when i was at one of the local dealers they told me that all the libertys have a 5000 lb towing capacity. Is this true or is this only with the trailer tow class III group option? The trailer tow class option says that it comes with a heavy duty engine cooler, heavy duty power steering cooling and trailer sway control. So im assuming that the without this package that its not rated for the same weight? Or do all the libertys have this thing and i just need to add the hitch?
vtjeepguy is offline
post #2 of 15 Old 12-17-2011, 05:31 AM
jonrjen
2011 KK Liberty
Best I recall it is only with the Tow Pkg.
"If you have a difficult job to do....Give it to a lazy man....He'll find the easy way to do it."
jonrjen is offline
post #3 of 15 Old 12-17-2011, 07:00 AM
jsburton84
2008 KK Liberty
It may be different for later year models but this is the case for 2008 KK:
class II hitch, 2,000lb
class III w/ towing package and manual transmission, 3,500lb
class III w/ towing package and auto transmission 5,000lb
2008 KK sport 4x4
1998 XJ sport 4x4 (sold)
jsburton84 is offline
post #4 of 15 Old 12-17-2011, 08:18 AM
musclezmarinara
2012 KK Liberty
I just installed the 5k hitch with oem mopar harness
2012 KK Cherokee * Arctic * Mineral Gray
- Mods - See Build Thread..
musclezmarinara is offline
post #5 of 15 Old 12-17-2011, 12:02 PM
GoodPrepper
Looks like 5,000lbs with a class III every where I look. I plan to put one on, probably will never tow more than about 3,500lbs but good to know.
GoodPrepper is offline
post #6 of 15 Old 12-17-2011, 12:56 PM
jonrjen
2011 KK Liberty
Keep in mind, just because the hitch is rated for 5,000 pounds, does not mean that the Liberty is rated for towing the 5,000 pounds with out the brake controller, sway control, added coolers and so on.
jonrjen is offline
post #7 of 15 Old 01-02-2012, 09:56 PM
kmrcstintn
2011 KK Liberty
to have the 5,000 lb tow capacity you need the factory tow package which includes the hitch, wiring harness, electronic brake/sway control, full size spare tire, and 'heavy duty' cooling system; my '11 Liberty KK has this package
kmrcstintn is offline
post #8 of 15 Old 01-03-2012, 10:57 AM
fdkss03
would it be safe pulling my wrangler on a car trailer?
#SavvyUp
#MCEFenders
#ClaytonOffroad
fdkss03 is offline
post #9 of 15 Old 01-03-2012, 11:01 AM
95wrangler4life
my heep weights in around 4000lbs... with the 2.5 and 36's. most trailers weigh around 12-1500lbs empty... so your probably over... the uhaul trailers are lightweight, but no electric brakes.... so basically no.
95YJ 2.5 AX5 NP231 HP30 4.88 and aussie, 8.8 4.88 mini spool, 4" RC, 1.5" Boom shackles, 1" BL, 1" rear stretch, 36 12.5 15 TSL SX's, trimmed front fenders, bedlined exterior, comp cut coming soon!
Build thread:
95wrangler4life is offline
post #10 of 15 Old 01-04-2012, 07:09 AM
jeepster-d
2009 KK Liberty
I wouldn't pull anything heavy without the actual trailer package installed. It's an option on the Jeep site (I bought my Liberty used) for new vehicles. You could just add a hitch and pull something light (like maybe a personal water craft/jet ski trailer) but I wouldn't do any real hauling without at least the trans cooler installed. The only cooling system an auto trans has is in it's trans fluid - if that gets too hot you'll overheat the transmission and somethings going to get damaged.
jeepster-d is offline
post #11 of 15 Old 01-04-2012, 08:38 AM
jonrjen
2011 KK Liberty
I wouldn't do it, could turn out to be a case of the tail wagging the dog...not a good thing.
jonrjen is offline
post #12 of 15 Old 01-04-2012, 09:03 AM
mazza
2011 KK Liberty
When U-Haul says that they can install a 5000 pound hitch and light wiring for about $300, is that just the hitch or does that include the tow package? I'm not sure if my capacity is 2000 or 5000 and not sure if I have to take it to the dealer to have the 5000 package installed.
mazza is offline
post #13 of 15 Old 01-04-2012, 09:17 AM
jonrjen
2011 KK Liberty
That will be just the hitch and wiring for a four prong trailer light connection. It will not include a brake controller or the wiring to install a brake controller.
This will no raise your towing limits up to the 5,ooo pound tow rating.
jonrjen is offline
post #14 of 15 Old 01-04-2012, 09:17 AM
Jeepin11
2011 KK Liberty
The hitch itself ir rated for 5000 they put on. Your vehicle is not. I am pretty sure that you can have to tow package added after the fact. It is a factory option. The dealership can install the factory hitch and light harness but not sure about the anti sway or the cooler.
2011 KK- 265/75-16 Wrangler Authorities on 16x8 Racelin Assault wheels
Jeepin11 is offline
post #15 of 15 Old 01-04-2012, 09:18 AM
Jeepin11
2011 KK Liberty
That was can't have not can.
Jeepin11 is offline
08 KK Liberty COMMAND-TRAC Transfer Case capacity mjcougler KK Liberty Forum 48 11-29-2016 04:54 PM
2008 KK Limited towing capacity cdnqueen KK Liberty Forum 3 09-11-2011 12:14 AM
Towing with the KK jeepems KK Liberty Forum 6 01-24-2011 07:58 PM
rear axle oil capacity VMF KK Liberty Forum 3 10-30-2010 11:59 AM
Why is the Sport limited to only 3500lb tow capacity? KDOG2008 KK Liberty Forum 3 06-20-2010 06:18 PM
