Tommudd vs. OME Lift Kit's - JeepForum.com
post #1 of 8 Old 04-21-2013, 05:13 PM Thread Starter
ghostimpala
I would like to buy a decent lift kit for my KK but as many of you have discovered there are varying kit's and opinions. I've narrowed my search to the Tommudd or OME kits from Jeepinbyal and or the skyjacker Plat kit. I'm not a serious off-roader and anticipate that the Jeep will only go on moderate trails if any. I'm more interested in an aggressive stance using bigger tires.
Does anyone have an opinion regarding the kits noted above and or that of another kit?
Will I have to purchase anything in addition to the kits (are they complete) and or change anything like the drive shaft, gear ratio or break lines with a 3in kit?
My KK has 18in wheels (about 29in stock w/tires). I see everyone key's in on 245/75r-16's but am skepticle 16in wheels will clear and 245/75r-17's place me at roughly 31in which may rub.
Thanks for the help all.
ghostimpala is offline
post #2 of 8 Old 04-21-2013, 06:42 PM
tommudd
2004 KJ Liberty
Stay away from the Skyjacker for one, the springs are rated same as stock and will sag just like stock ones do
As far as the other two you mention
OME is springs and shocks only
The Econo includes everything pretty much you need
so hard to compare when they are both different
04 KJ WITH JBA 4 INCH COILOVER LIFT
03 KJ WITH JBA 2.5 TOTAL CONTROL LIFT
tommudd is offline
post #3 of 8 Old 04-21-2013, 07:17 PM Thread Starter
ghostimpala
Tom, agree with your assessment of the OEM and TM packages. Regarding the Econo, you noted "pretty much" so I have to ask what's the addition required.
Also, if I buy the econo will I have to change my gear ratio, drive shaft or break lines?
Final question - will 16in wheels fit on a 2012 KK; I've only seen 17's and 18's.
Thanks for the info and thanks for putting together a kit with JBA.
post #4 of 8 Old 04-21-2013, 07:38 PM
tommudd
2004 KJ Liberty
Bumpstops
gear ratio - depends on what size tires you go with, 245-75-16s will work good with stock gearing
16 inch will work on a 12 KK
tommudd is offline
post #5 of 8 Old 04-21-2013, 09:02 PM
Poncherello
2010 KK Liberty
I would like to ask a quick question on this. If I wasn't look to lift my Lib but just improving the ride / handling would ome shock and spring do the trick vs replacing these part with mopar.
When you get knee-deep in a situation, floor it.
Poncherello is offline
post #6 of 8 Old 04-21-2013, 09:34 PM
tommudd
2004 KJ Liberty
Replacing the suspension ( springs and shocks) with aftermarket like OME would be 100 times better than Mopar parts
tommudd is offline
post #7 of 8 Old 04-21-2013, 10:04 PM
Poncherello
2010 KK Liberty
Thanks will do
post #8 of 8 Old 04-22-2013, 08:00 AM Thread Starter
ghostimpala
Thanks Tom, I will give Al's a call this week.
