TIPM Relay Orientation - JeepForum.com
post #1 of 9 Old 09-22-2013, 04:41 PM Thread Starter
RKK
2012 KK Liberty
I wanted to make sure I aligned the Relays (K1-K12)correctly in the TIPM. I looked at the Jeep Owner manual and the picture gave me clue on the alignment, but it is lacking one relay when compared with my Jeep Liberty 2012 Sport TIPM. When I was inserting the relays I noticed there are 4 pins, and in the base there are 5 holes. And the Middle hole is usually aligned to 87A tip, but there is no pin. I just want to make sure my assumption is correct.
Any tips or pictures (jeep kk 2012) on how to make sure the relays are positioned correctly on TIPM is greatly appreciated?
Thank you
RKK
RKK is offline
post #2 of 9 Old 09-25-2013, 04:12 PM
JeepGeezer
2012 KK Liberty
Sorry, I'm next to clueless on this subject, but I found something on the forum here which I hope is of help: (probably not, because it is for Wrangler) http://www.jeepforum.com/forum/f96/o...study-1200238/
JeepGeezer is offline
post #3 of 9 Old 09-25-2013, 08:40 PM Thread Starter
RKK
2012 KK Liberty
Thanks for the link, need to see similar picture from another 2012 Jeep KK to be sure.
RKK is offline
post #4 of 9 Old 09-26-2013, 06:41 AM
Stang977
Stang977's Avatar
2012 KK Liberty
RKK,
Let me know if you got my PM. have the pic but having upload issues.
Me- 2012 KK, Latitude, Mineral Grey, "Cherokee" Moulding,
JBA Tommudd 3 1/2" Econolift
265/70R16 Nitto Terra's
Fuel Revolver 16X8
Rock Lizard Basket Rack/ 40" Rigid Lightbar
Her- 2011 WK2 Laredo X, Brilliant Black
Stang977 is offline
post #5 of 9 Old 09-26-2013, 09:14 AM Thread Starter
RKK
2012 KK Liberty
Thanks Stang977 for trying. If the image is too large (> 600kbytes) you could have problems uploading the picture. I had similar issue and I had to send the picture from iphone with smaller resoulution before I could upload the picture.
What do you think about the way the Relays were plugged in? Are they matching with your vehilce fusebox? These Omron relays are 4 pin relays and it is possible to plug them in the wrong way, when you look at the Fuse Box picture the "Omron" name could be up or down. I don't want to take chance of trying the wrong as it could damage the relay.
RKK is offline
post #6 of 9 Old 09-26-2013, 10:23 AM
Stang977
Stang977's Avatar
2012 KK Liberty
On comparison, I found 6 that are opposite (upside down from mine).
Edit: Here you go: My box. Hope this helps!
Fuel Revolver 16X8
Stang977 is offline
post #7 of 9 Old 09-26-2013, 08:38 PM Thread Starter
RKK
2012 KK Liberty
Does any one know what the rule of thumb when inserting these relays? I attached the base phone with 5 holes and the relay with 4 pins.
RKK is offline
post #8 of 9 Old 03-11-2014, 05:09 AM
deserthucker
The energising poles are diagonally opposite each other so are the switching poles.
So it does not matter which way they are inserted.
deserthucker is offline
post #9 of 9 Old 03-12-2014, 06:37 AM Thread Starter
RKK
2012 KK Liberty
Originally Posted by deserthucker
The energising poles are diagonally opposite each other so are the switching poles. So it does not matter which way they are inserted.
agreed, tested it today. Thank you.
RKK is offline
relay , tipm
