Throttle Body Cleaning - JeepForum.com
post #1 of 8 Old 04-05-2014, 10:26 PM Thread Starter
xxxxxxxxxxxxSmetna
Guest
2011 KK Liberty
Just had a Jeep mechanic tell me that my throttle body and plate are filthy. So I'm going to unbolt it and hit it with some throttle body cleaner spray and a tooth brush.
But
What else should I look at? The intake manifold? It's made of plastic, I wouldn't feel good using abrasive solvents in there. Any suggestions? Or just a new air filter and throttle body cleaning and call it done.
xxxxxxxxxxxxSmetna is offline
post #2 of 8 Old 04-06-2014, 04:31 AM
brucecadieux
2011 KK Liberty
Seafoam for the intake.
brucecadieux is offline
post #3 of 8 Old 04-06-2014, 05:24 AM
tjkj2002
2002 KJ Liberty
Do not use TB cleaner on the your TB,it has a special coating,use only soapy water.
Also do not use seafoam,not really a good cleaner and just makes smoke and that is about it.
tjkj2002 is offline
post #4 of 8 Old 04-06-2014, 03:27 PM Thread Starter
xxxxxxxxxxxxSmetna
Guest
2011 KK Liberty
What does the special coating do?
post #5 of 8 Old 04-06-2014, 04:20 PM
DarkSport11
2011 KK Liberty
+1, I am also interested in knowing about this. I have an '02 and an '11 and have used it both with no ill effects.
2011 KK Sport 4X4 in Dark Charcoal Pearlcoat
DarkSport11 is offline
post #6 of 8 Old 04-06-2014, 04:29 PM
tjkj2002
2002 KJ Liberty
On electronic throttle bodies(your '02 does not have this) they use a special coating since there is no IAC and to help reduce carbon build up.That coating is very easily washed off by harsh chemical cleaners.
The Chrysler's with the 5.7 HEMI's have it the worst since it will actually set codes that can not be erased till the TB is replaced.
tjkj2002 is offline
post #7 of 8 Old 04-06-2014, 09:49 PM Thread Starter
xxxxxxxxxxxxSmetna
Guest
2011 KK Liberty
What an IAC?
and also
This coating did not help at all to keep carbon from building up. So I don't really care if it's gone. I'll just use TB cleaner every 10k miles. Not like its a difficult job
post #8 of 8 Old 04-07-2014, 03:06 AM
bsad67
2012 KK Liberty
[QUOTE=Smetna;21928273]What an IAC?
Idle Air Control (solenoid)
2012 KK Latitude Chrome grille, chrome bug deflector, chrome door handles,
chrome mirror caps, chrome gas door and Jeep Cargo Area Liner.
AVS vent shades and factory dealer installed remote start.
http://www.forjeepsonly.com/jeep-forum/showthread.php?108-Member-from-FABO
bsad67 is offline
