Teraflex Level kit or lift boost will help my rubbing issue - JeepForum.com
post #1 of 22 Old 06-04-2013, 07:37 PM Thread Starter
SarOpsSix
2011 KK Liberty
I was wondering if anyone has either a Teraflex level kit or boost lift. I have 255/70/16 on a 16x8 blackrock rim and im getting a little rub on full choke. I was wondering will any of these two will fix my issue? Or will raising it not help cause its a width issue? Any help would be great.
Looking for people who have this tire size and rim size and have either of these solutions and it gave you the room you needed. Thanks
SarOpsSix is offline
post #2 of 22 Old 06-04-2013, 07:46 PM
tommudd
2004 KJ Liberty
8 inch wheels are killing ya for one thing, not knowing the backspacing could be another
Tire size as well to some extent
You could do a clevis lift of 3/8 of an inch and a 1/4 inch top plate to level the front with the rear pretty much
Not knowing how old you KK is / how much the springs have sagged its hard to say what else you may need to do
04 KJ WITH JBA 4 INCH COILOVER LIFT
03 KJ WITH JBA 2.5 TOTAL CONTROL LIFT
tommudd is offline
post #3 of 22 Old 06-04-2013, 07:52 PM Thread Starter
SarOpsSix
2011 KK Liberty
Sorry its a 2011 sport as far as the rims they are blackrock lobos 16x8 +13 offset with a 5 inch backspace.
post #4 of 22 Old 06-04-2013, 07:55 PM Thread Starter
SarOpsSix
2011 KK Liberty
Teraflex offer a level kit wich is 2 inch in front and 1 inch in back. The back wheels are fine plenty of clearence its the front. Its ok when wheel is staright having issues at full choke or sharper turns. I'm seeing the rubbing far back corner not bad but its rubbing
post #5 of 22 Old 06-04-2013, 08:03 PM
tommudd
2004 KJ Liberty
It would help possibly for a while until your springs sag more
tommudd is offline
post #6 of 22 Old 06-04-2013, 08:11 PM Thread Starter
SarOpsSix
2011 KK Liberty
You think the level kit will do the trick or do i need to go with the boost lift they have 1.5 and 2 inch. Thanks
post #7 of 22 Old 06-10-2013, 08:41 PM
Ted15
2010 KK Liberty
Yes it will help. No it isn't a good idea. I ran that for about a year. Got it from RRO. They market it under the over the top lift. You will bottom out the front shocks frequently and the rear shocks that came with mine absolutely sucked and you will need longer rear shocks, not to mention the upper control arm contact with the factory arms. For a few hundred more you could get OME.
What's the backspace on your rims? That probably has a lot to do with your rubbing issue. 5" is too much backspace with a wider tire, especially with an 8" rim. The most backspace you should run is 4".
The lift comes with a 2" poly spacer for the rear and a welded steel spacer (2") for the front. It's very difficult to install without a spring compressor because the clevis bolt won't line up by about 1/2".
2010 KK Sport, Detoures Knucklebone & backbone, smittybilt XRC 10, rigid led lights, R/L sliders & rack, cb, EMT2, R/K 15x7, OME, JBA, mopar skids & hitch, headlight covers, 4.10's and TruTracs
Ted15 is offline
post #8 of 22 Old 06-11-2013, 06:47 AM
Ted15
2010 KK Liberty
So it shows up now?
Ted15 is offline
post #9 of 22 Old 06-11-2013, 07:07 AM
tommudd
2004 KJ Liberty
Originally Posted by Ted15 View Post
So it shows up now?
Happens every now and again for some reason
tommudd is offline
post #10 of 22 Old 06-12-2013, 09:44 AM Thread Starter
SarOpsSix
2011 KK Liberty
This is the teraflex you are taliking about ist a 1.75 inch lift boost here is the link
http://www.teraflex.biz/kk-liberty-1...oost-2008.html
So im getting this thursday and you are telling me this will not fit?
post #11 of 22 Old 06-12-2013, 10:16 AM
tommudd
2004 KJ Liberty
It may fit but its a junk a** way to lift
You'll hate the ride and the way it handles
Save up the money and do it right
For what you are paying for that crap you're half way to a new full spring lift
tommudd is offline
post #12 of 22 Old 06-12-2013, 10:40 AM
Ted15
2010 KK Liberty
That's the one, same crap RRO sells and the only one teraflex makes for a KK. You'll need longer shocks for the rear as well. I posted my reply shortly after you asked the question in your first post. I don't know why it didn't show up until I posted again. I was trying to save you some money.
Ted15 is offline
post #13 of 22 Old 06-12-2013, 10:42 AM
Ted15
2010 KK Liberty
I called teraflex asking for a pair of 1" spacers for the rear but they don't have anything that'll fit a KK. I was told the market wasn't there. I tried to tell him some suggestions about how he could sell some smaller spacers to go with suspension lifts but he didn't even want to hear it.
Ted15 is offline
post #14 of 22 Old 06-12-2013, 12:58 PM Thread Starter
SarOpsSix
2011 KK Liberty
Well the guys a discount tire are willing to help me out that company really stands by there ****. So if i return these shocks and with a 245 will i be good? Like i said its almost there it barely rubs.
post #15 of 22 Old 06-12-2013, 01:02 PM
tommudd
2004 KJ Liberty
Part of the issue is till the wheels
throw them away and get 7 inches wide
tommudd is offline
