Super vs Turbo vs Alternative. Which would be better for max HP/TQ for a 2008 Liberty - Page 3 - JeepForum.com
post #31 of 46 Old 03-16-2011, 07:30 PM
tommudd
2004 KJ Liberty
right word is pure junk,
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
tommudd is offline
post #32 of 46 Old 03-16-2011, 09:08 PM
SuperRliBerty
2008 KK Liberty
It sounds like a walmart hair dryer
2008 Sport Liberty
Cold air intake*Trush (magnaflow) turbo muffler* Hypertech power program*
Hood Prop mod. Battery Quick Release mod.
Resonator removed (sounds like a V8 on start up)
SuperRliBerty is offline
post #33 of 46 Old 03-16-2011, 09:34 PM
tjkj2002
2002 KJ Liberty
http://www.youtube.com/watch?v=q5999...eature=related
No way could it create any boost when the engine is running.It would need to spin much faster then 20,000rpm's,more like in the 100,000rpm+ range.
tjkj2002 is offline
post #34 of 46 Old 03-16-2011, 09:54 PM
SuperRliBerty
2008 KK Liberty
I am skeptical too..... to make 5 pounds of boost it spins rather slow. wish the makers of that thing would dyno test before and after
2008 Sport Liberty
post #35 of 46 Old 03-16-2011, 10:00 PM
tjkj2002
2002 KJ Liberty
Somewhere there's a vid of someone dyno'ing one of those snake oil setup's and they lost major power after install as it became a gaint air flow obstruction when installed and running as it could not spin fast enough to keep up with the natural aspiration let alone create boost.
tjkj2002 is offline
post #36 of 46 Old 03-16-2011, 10:04 PM
SuperRliBerty
2008 KK Liberty
This gets the Snake Oil award.
The concept is good for efficient fuel burning in the combustion chamber but the hp gain is neglible... at least you won't "feel" a difference in hp:
3.7 V6 AIRAID AIR AID PowerAid Throttle Body Spacer
PartNumber: ARD310-618, 310-618
APPLICATION GUIDE - Does it Fit My Vehicle?
Back to Top 2007-2010 DODGE DAKOTA V6 3.7L
2007-2010 DODGE NITRO V6 3.7L
2007-2010 DODGE RAM 1500 PICKUP V6 3.7L
2006-2009 JEEP COMMANDER V6 3.7L
2005-2009 JEEP GRAND CHEROKEE (WK) V6 3.7L
2007-2010 JEEP LIBERTY (KJ) V6 3.7L
2006-2009 MITSUBISHI RAIDER V6 3.7L
PRODUCT FEATURES
PowerAidŽ Throttle Body Spacer
Easy To Install with Basic Hand Tools
Aircraft Quality Billet 6061-T6 Aluminum
No Drilling Or Cutting Required
Incl. Gaskets; Hardware; Precision Brackets
Installs In Less Than 1 Hour
Improves Intake Velocity/Part-Throttle Torque
Provides Stronger Mid-Range Power
The PowerAidŽ was developed to enhance your vehicle's off idle to mid range performance and efficiency. The unique "Helix Bore" design of the PowerAid creates a spinning action of the incoming air. As air passes through your throttle body, this helical effect causes the air molecules to organize and maintain high velocity. The organization and high velocity of the air is extremely beneficial because it helps to provide a superior atomized mixture of fuel and air all the way into the combustion chamber. The benefits you will see are tremendous torque gains between 800 to 2500 RPM, and potential increases in your fuel economy, depends on your vehicle.
WARRANTY ITEMS: Our company sells the highest quality products, most of which carry a manufacturer’s warranty. We will take care of the problem here at our store, or put you in touch with the manufacturer if the situation warrants.
2008 Sport Liberty
post #37 of 46 Old 03-16-2011, 10:06 PM
wj0313
2003 WJ
What a joke. No way it would work efficiently. Ok so back to the question. I think a re gear is your best option simply because your engine does not like boost. As far as turbo vs super charger. A super charger would be the best option in your case. Turbo. Set UPS are touchy after market and with the change in altitude, tuning and fuel trims would be a nightmare. Supercharging would be more consistant and easier in the long run.
wj0313 is offline
post #38 of 46 Old 03-16-2011, 10:11 PM
SuperRliBerty
2008 KK Liberty
This is get the grand daddy Snake oil Award.
Condition: 100% Brand New & Good Quality
This intake fuel saver duel fans system which rotate up to maximum Speed of 55,000r/min. this make Light weight aluminum design helps cooler air flows to the engine and more dynamic control over the aftermarket intake system.the intake fuel saver Length: 3 " / Inlet/Outlet: 2.5", whit 3 x Rubber Included the more air you can get into the cylinder, the more horsepower the engine is able to produce , The propeller sucks the airflow into the combustion chamber at a higher speed resulting atomized burning which Increase Horsepower Up To 7% more and Save Up To 24% On Fuel . Incrase Fuel Economy by up to 33% .
shown in the picture. . Exactly Same as the Picture, No instructions included.
http://www.youtube.com/watch?v=sVvsW...embedded#at=16
2008 Sport Liberty
post #39 of 46 Old 03-16-2011, 10:22 PM
Cnwxj
Total crap, look at the gap in the housing. REAL superchargers use very close tolerances, not 1/4" gaps. The filter is the only thing to give any( All be it small) gain in HP. These are made for dumb kids with no idea how a SC should work. I'll kick ya in the nuts for half what that cost. My .02
Cnwxj is offline
post #40 of 46 Old 03-16-2011, 10:30 PM
SuperRliBerty
2008 KK Liberty
2008 Sport Liberty
post #41 of 46 Old 03-17-2011, 11:43 AM Thread Starter
BloodyShadow23
2008 KK Liberty
Dude that's great. The funny thing is, I have only recently been looking into SC and TC. And just had a huge push to learn more about what im actually driving. So with all of that, I STILL know that "SC Turbine" crap is worthless! Thats just embarrassing.
2008 Liberty Sport - Chrome Grill, K&N CAI,
BloodyShadow23 is offline
post #42 of 46 Old 03-17-2011, 05:32 PM
SuperRliBerty
2008 KK Liberty
This is a nice build... would love to see a before and after dyno sheet.
Do you want v-8 performance from your XJ without the cost and complexity of a V-8 swap? Are you tired of driving a slug on the highway, even though it's a great trail rig? The answer may be in the thin air you breathe, by simply packing that thin air into your engine with a supercharger designed to increase the ponies, the driveability, and the fun factor. If you stayed awake during auto shop and chemistry classes, you know there is an ideal ratio of air to fuel that makes an engine very happy. Too little fuel and you run the risk of expensive engine damage. Too much fuel is a waste of a valuable resource. To achieve the proper balance, since we are forcing more air into the engine with a blower, supercharger guru Rick Rimmer developed this kit using an auxiliary fuel system. Since the fuel-pressure increase only comes when the regulator sees boost, stock mileage is retained as additional fuel is only supplied as needed.
The candidate for this swap is a '98 XJ Cherokee with 120,000 on the clock, which is basically stock except for the 4-inch TeraFlex lift and 32-inch tires. Our goal was to be able to pull a small tent trailer up and down the hills of Utah and Colorado without being passed by every 18-wheeler on the road, while maintaining decent fuel economy and good daily driveability. The kit we installed is a Rick Rimmer-developed 4.0L non-intercooled supercharger kit. It fits under the hood of the XJ without a hole in the hood and with no modifications to the vehicle sheetmetal at all. So this kit is invisible from the outside, making it a true sleeper.
We were successful in our goals of more power, driveability, and fun. The mileage rose to 17 mpg, up from 14. It now pulls the tent trailer up a 6 percent grade at 60 mph, and even stays in lockup overdrive all the time at freeway speeds. On top of that, we can embarrass the black-cloud diesel pickups from 0 to 60 and still have fun getting to drive it every day. Follow along as we install a supercharger on a high-mileage XJ Cherokee.
The new supercharger kit includes an Eaton supercharger, a new intake manifold that has been modified to accept the adapter plate, and a box of brackets, hoses, and fittings. The intake manifold is a dual-plane design from an '06 Wrangler, so it does require you to have the latest style power-steering pump. Look at the photos here to see if you have the latest mounting design pump, and if not, visit your local parts store or Pick-n-Pull before taking your vehicle out of service. The Eaton supercharger has an internal oil system that is independent of the engine so there is no need to plumb in an oil-pressure or return line.
131_0803_02_z+40l_jeep_xj_cherokee+supercharger.jpg   131_0803_05_z+40l_jeep_xj_cherokee+engine.jpg   131_0803_06_z+40l_jeep_xj_cherokee+intake.jpg   131_0803_07_z+40l_jeep_xj_cherokee+remove_intake_manifold.jpg   131_0803_08_z+40l_jeep_xj_cherokee+fuel_line.jpg
2008 Sport Liberty
post #43 of 46 Old 03-17-2011, 05:35 PM
SuperRliBerty
2008 KK Liberty
supercharged...
131_0803_09_z+40l_jeep_xj_cherokee+throttle_body.jpg   131_0803_10_z+40l_jeep_xj_cherokee+power_steering_pump.jpg
2008 Sport Liberty
post #44 of 46 Old 03-17-2011, 07:25 PM Thread Starter
BloodyShadow23
2008 KK Liberty
That would be fantastic! But what is the difference between the TVS and the 3-lobe? I feel like I'm taking 2 steps forwards then 3 steps back!
post #45 of 46 Old 03-17-2011, 08:26 PM
SuperRliBerty
2008 KK Liberty
TVS stands for Twin Vortices Series. These Eaton superchargers have 4 lobe rotors with 160 degrees of end-to-end twist. The older “M” series superchargers had only 3 lobe rotors with 60 degrees of end-to-end twist. The TVS design allows for greater efficiency, higher pressures, and higher rotational speeds when compared to older “M” series designs
2008 Sport Liberty
2008 Liberty Skyslider Issues JFK2218 KK Liberty Forum 39 04-05-2012 11:31 AM
2008 Liberty - Preventative maintenance SuperRliBerty KK Liberty Forum 33 07-29-2011 12:54 PM
which lift for 2008 liberty kk flaglfr KK Liberty Forum 0 02-01-2011 08:53 PM
2008 Liberty mods for 2011 SuperRliBerty KK Liberty Forum 5 12-03-2010 05:35 PM
2008 Liberty mechanical fan noise JWMII KK Liberty Forum 2 11-21-2010 08:09 AM
