Super vs Turbo vs Alternative. Which would be better for max HP/TQ for a 2008 Liberty - JeepForum.com
post #1 of 46 Old 03-13-2011, 06:48 PM Thread Starter
BloodyShadow23
2008 KK Liberty
So I have a 2008 Liberty and have this idea to either Turbocharge or Supercharge it. I go camping in the Rocky Mountains and haul and tow a lot up to my camping site. My Liberty is "Trail Rated" and have the "Tow-Haul" package and must climb up to 10,000+ ft. Thank you for the advice and if you have any other suggestions they would be appreciated.
BloodyShadow23 is offline
post #2 of 46 Old 03-13-2011, 06:52 PM
Kitchen
with the money it cost to get a good turbo kit you could just buy a old dually if you tow that much
- 99 XJ
5 inchs on 33 kevlars
Locked F&R, bumper, winch, etc...
Build thread:
- 03 TJ Rubi
4 inches on 35 baja MTZs
Stock rubi stuff(D44s, lockers, skids, etc...)
Kitchen is offline
post #3 of 46 Old 03-13-2011, 07:02 PM
WhyJayPA
Being a VW owner with a turbo'd motor I can say that a turbo will give you a lot of torque in the mid to high rpm's and will help at high altitudes (thats what they were originally invented for). This also depends on the turbo you go with and how it is tuned because a smaller turbo will spool faster than a larger turbo. I do not know much about supercharging but you gotta keep in mind that supercharging takes power to make power. Personally, like the post above says, I wouldn't waste the money on a turbo/supercharger on that liberty motor. You would be better off buying another vehicle for cheap that can handle your towing needs.
WhyJayPA is offline
post #4 of 46 Old 03-13-2011, 07:08 PM
Kennedy
2008 KK Liberty
Or buy the CRD liberty and put a bigger fuel pump, injectors and turbo w/ tune on it and call it day.
2008 Liberty Sport- Mods soon to come.
2004 Wj Columbia Edition- Sold
Kennedy is offline
post #5 of 46 Old 03-13-2011, 07:28 PM
tjkj2002
2002 KJ Liberty
Regear the diffs,the best way.Also when venturing above 10,000' fill up with premium gas.I have gone well over 10,000' more times then I can count(some well over 12,000') and had more then enough power in 4low,4.10's,and 91 octane gas in the tank.
The 3.7 does not like boost,even low boost like 2psi due to the piston ring placement in the pistons for emission's.You will break your psitons under boost unless you get forged pistons made and installed.
tjkj2002 is offline
post #6 of 46 Old 03-13-2011, 08:31 PM
alex725
2009 XK Commander
Put in a HEMI!
alex725 is offline
post #7 of 46 Old 03-14-2011, 08:01 AM
SuperRliBerty
2008 KK Liberty
I agree. The 3.7 was not made for boost, but kenne belle got some impressive numbers from the 2 valve 3.7. Perhaps they had some issues regarindg engine drivetrain components, because they discontinued it.
http://www.kennebell.net/supercharge...7/libert37.htm
2008 Sport Liberty
Cold air intake*Trush (magnaflow) turbo muffler* Hypertech power program*
Hood Prop mod. Battery Quick Release mod.
Resonator removed (sounds like a V8 on start up)
SuperRliBerty is offline
post #8 of 46 Old 03-14-2011, 08:59 AM
VMF
2008 KK Liberty
yeah it is a known fact that if you boost your engine but dont do any transmission upgrades, and your tranny is auto, it will die relatively soon. ive seen that happen few times and here it happend to the fellow jeep owner http://www.clutchd.com/2009/01/921-h...smission.html/
___________________________
2008 KK limited 4x4. Inferno Red
2009 JK Rubicon. Black
2004 UCF31. Black
2001 EM2. Inca pearl
2012 UD Limited. Royal Gray
VMF is offline
post #9 of 46 Old 03-14-2011, 02:02 PM
SuperRliBerty
2008 KK Liberty
He got Nitrous xpress nos in that srt8. anything over 500hp, you MUST modify that tranny!
2008 Sport Liberty
post #10 of 46 Old 03-14-2011, 02:08 PM
MONSooNmonkey
^ Is that seriously 2 30lb bottles on an SUV with low profile tires at a race?
Sadface :(
MONSooNmonkey is offline
post #11 of 46 Old 03-14-2011, 02:19 PM
SuperRliBerty
2008 KK Liberty
I say "Never cry over spilled milk, and don't wait for it to turn sour." Take out that stock tranny and put in a HD tranny.
HMS, have the automatic transmission upgrade as an option, but I would opted for all tranny upgrade.
HPE800 Twin Turbo Jeep SRT8 Upgrade
Power:
800 bhp @ 5,500 rpm
The HPE800 Jeep SRT8 Upgrade Includes:
• Low Compression 426 cid Stroker Motor
• Twin Ball Bearing Turbochargers
• Stainless Steel Turbo Y-Pipe
• Single 44mm Wastegate
• Front Mounted Air-to-Air Intercooler
• Polished Inlet Tube with Blow-Off Valve
• High Flow Cylinder Heads
• Polished Intake Manifold
• HPE800 Camshaft
• Upgraded Fuel Injectors
• Stainless Steel Exhaust System
• HPE Engine Management Calibration
• All Necessary Gaskets, Fluids & Hardware
• Professional Installation
• Dyno Tuning & Road Testing
• Hennessey Red Valve Covers
• Hennessey Premium Floormats
• Hennessey Embroidered Headrests
• Serial-Numbered Dash and Engine Plaques
• HPE800 Exterior Badges
• HPE Limited Warranty
Optional Upgrades Include:
• Lightweight Wheel & Tire Packages
• Suspension & Brake Upgrades
• Automatic Transmission Upgrades
• Polished / Coated Intake Manifold
• Interior Upgrades
• And More
Please Call Hennessey Performance at (979) 885-1300 for More Information.
Power numbers based on 93 octane fuel. Package contents subject to change and not all-inclusive.
2008 Sport Liberty
post #12 of 46 Old 03-14-2011, 02:41 PM
SuperRliBerty
2008 KK Liberty
Glad to see he has a roll cage in that srt8..... with 900+ hp he should use a trans blanket .
NHRA rules state hp over 600hp requires a trans blanket.
2008 Sport Liberty
post #13 of 46 Old 03-14-2011, 02:49 PM
VMF
2008 KK Liberty
i dunno why upgrade tho, originally i wanted to get the srt 8, but after test driving it i realized it would be a shortcut to heaven. thing is waaay to fast even stock, while it still handles like an suv....
2004 UCF31. Black
VMF is offline
post #14 of 46 Old 03-14-2011, 03:57 PM
SuperRliBerty
2008 KK Liberty
yes true, but with 900 hp that tranny and drivetrain is screaming bloody murder!!! Is that the tranny input shaft?
2008 Sport Liberty
post #15 of 46 Old 03-14-2011, 04:02 PM
onegoodpunk
2008 KK Liberty
watched a recent episode of Xtreme 4x4 and they supercharged a JK 4 door. It cost around 4500 for the supercharger plus some misc parts and install. And they got close to the same results from that than a JK with a swapped HEMI.
onegoodpunk is offline
2008 Liberty Skyslider Issues JFK2218 KK Liberty Forum 39 04-05-2012 11:31 AM
2008 Liberty - Preventative maintenance SuperRliBerty KK Liberty Forum 33 07-29-2011 12:54 PM
which lift for 2008 liberty kk flaglfr KK Liberty Forum 0 02-01-2011 08:53 PM
2008 Liberty mods for 2011 SuperRliBerty KK Liberty Forum 5 12-03-2010 05:35 PM
2008 Liberty mechanical fan noise JWMII KK Liberty Forum 2 11-21-2010 08:09 AM
